2 oz. of coolant from over flow tube
After a 2hr spirited driving through cannons with no overheating issues I lost about 1-2oz of fluid. Car ran under 220 the whole time. Coolant tank is at normal level and has not burped any more coolant. Should I be concerned? Any Ideas? Thanks. Out side temp was 62 degrees
It’s either too full, got too hot, or got air in the system.
Air in the system would be a head gasket situation or lifting a head.
Have you filled it recently?
Never had to fill, I'm not even Shure in was 2 0z.
It just got too hot. It’s fine.
