FINALLY - C7 3.90 and 4.10 Differential Gear Sets
Old 02-15-2019, 07:57 AM
Pumba
Support Corvetteforum!
Pumba's Avatar
With the M7 transmission you do not need to recalibrate the speedometer.
Old 02-16-2019, 02:14 PM
Bubbletop409
Bubbletop409's Avatar
However your speedometer will be reading slightly higher than your actual speed.
Old 02-16-2019, 09:45 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
Originally Posted by Bubbletop409
The point being competition gear sets are not recommended for street use, and visa versa, So again what grade of steel are these made of and for what venue were they designed? Street or true competition? And as a side note these are gears for the rear differential, not the transmission as some are assuming.
i think you are confusing these with drag only gear sets which are made if a softer alloy which makes them less brittle and allows the gears to absorb the shock of a launch. The downside of these gears is that they wear quicker. These gears don’t appear to be drag only gears.
Old 02-16-2019, 09:56 PM
phantom1
phantom1's Avatar
How will it read the correct gear ratio without recalibrating the ECM?
Old 02-16-2019, 10:28 PM
Higgs Boson
Higgs Boson's Avatar
Received 2,379 Likes on 1,238 Posts
Modern vehicles use wheel speed sensors. The only thing that will change your speedometer is tire height. Since the C5 for sure, not sure about the C4.
Gear ratios are pre-programmed into the engine and transmission calibrations and the gear position indicator is set and can be learned with a GM tool (but isn't needed).
phantom1 (02-17-2019)
Old 02-18-2019, 08:30 AM
VERBOTEN
VERBOTEN's Avatar
Subscribed.
Old 02-18-2019, 10:09 AM
lobsterroboto
lobsterroboto's Avatar
2020 Corvette of the Year Finalist (track prepared)
C7 of Year Winner (track prepared) 2019
I’m interested and n the 3.90 but why different recommendations between the stingray and GS?
Old 02-18-2019, 01:31 PM
Bubbletop409
Originally Posted by Higgs Boson
Modern vehicles use wheel speed sensors. The only thing that will change your speedometer is tire height..
Then why is it that only the M7 equipped cars automatically adjust?
Old 02-18-2019, 01:37 PM
Bubbletop409
I'm not confusing, I know well the difference, hence the question. I guess the better question would then be why would one desire them for street use?
Old 02-18-2019, 04:17 PM
acroy
acroy's Avatar
Received 1,386 Likes on 836 Posts
Originally Posted by devnull
HECK YEAH DUDE!
Been lurking this topic since 2015... THANK YOU!!!
same here!
Old 02-19-2019, 10:59 AM
Higgs Boson
you adjust the autos so the shift speeds are still correct.
Old 02-19-2019, 06:58 PM
thrilled
thrilled's Avatar
I'm thinking that as low as it is I can start out in 2nd without clutch burn.Thats a plus.
Old 02-19-2019, 07:44 PM
  #33
blue_bomber697
blue_bomber697's Avatar
Received 1,296 Likes on 479 Posts
2018 C7 of Year Finalist
Out of curiosity, Lets say I am trapping 140-141 consistently in the 1/4 with my M7 Stingray. Is there any kind of guess what this would raise my trap speed to with a 4.10 set? Purely speculative, not looking for an exact scientific number. Just trying to gauge the expected performance gain from going to these gears.
And any estimate on labour time? My car is going into a shop for a month and will already be on a lift with the motor out....
Old 02-20-2019, 01:40 PM
  #34
robz
robz's Avatar
It all depends on setup and power curve. With most cars you want to shift several hundred rpm above peak hp and go through traps above as well. This will yield the best et and mph provided traction and that your car can handle it and run stable at those rpms.
So, you can do a comparison with your current gears vs. 4.10 gears on a spreadsheet based off the data from a dyno graph to see which one will work better.
Old 02-20-2019, 01:50 PM
  #35
blue_bomber697
My issue is though, if I were to go to 4.10 gears, that limits the top of 4th to ~145mph @ 7200rpm (my redline) and if my trap were to increased too much, I would run into the issue of hitting redline right before the 1/4 mile traps. I'll give RPM a call and see what they think. 3.92 might be the safer route to go?
Old 02-20-2019, 03:45 PM
  #36
blue_bomber697
Talked with RPM today and they said Trap speed shouldn't change too much, might pick up in the 1/8th but lose on the back half for instance, but we really won't know till some cars get out there and try them out. But the gear sets are $850 and about 15 hours of labor to install for all of you interested.
Old 03-14-2019, 05:46 PM
  #37
phantom1
phantom1's Avatar
I have 3.90 gears in my C7 M7 and it doesn't seem like the ECM is learning the new gears. I'm about 90% sure it's 5-7 mph higher. I've made three 20 mile trips in the process of breaking-in the gears. Is there a certain amount of miles it needs, to learn?
Rpinaiii (09-28-2020)
To FINALLY - C7 3.90 and 4.10 Differential Gear Sets
Old 03-14-2019, 06:56 PM
  #38
Higgs Boson
no there should be no learning needed. unless something changed with the C7, I don't think anyone has been swapping gears in manuals until now.....maybe I am wrong about it.
Old 03-14-2019, 08:13 PM
  #39
phantom1
phantom1's Avatar
There wasn't anybody around when I took the car out today. I'll coast with someone side by side and compare mph asap.
Old 03-14-2019, 09:02 PM
  #40
blue_bomber697
Should look into getting a Dragy, or borrowing a Dragy/Vbox from someone else who has one. That will tell you for sure and then you can also compare performance data.
Quick Reply: FINALLY - C7 3.90 and 4.10 Differential Gear Sets
