Is there any need for the brake booster to be connected to the manifold?
As far as I can see, the C7 has a very good electric vacuum pump. The same pump used by EV's and Diesel vehicles that have little/no engine vacuum available. I'm also running a big cam, so I probably don't have much engine vacuum either.
Therefore, is there any reason why the brake booster needs to be connected to the intake manifold?
The reason I ask is that I'd ideally like to use the port on the back of my intake manifold for my IAT sensor (rather than right after the throttle body) for a more accurate air temp reading when spraying meth.
Received 5,207 Likes
Carefully, try and see.
Received 8,926 Likes
If it wasn't needed I doubt GM would have used it. It costs money for auto companies to do something and if they don't have to do it they don't spend that money. Basic rule of thumb to apply is if it cost them something to install they did it for a reason. If it looks like there isn't a reason for something rethink what you are doing since they don't do stuff they don't have to do.
Bill
Bill
Bill
Bill
