'17 C7 PDR updates to add '18+ features?
Hey gang. I have searched the postings but could not find info that would answer my questions on the PDR.
GM made some enhancements to the PDR functionality reporting on more variables when they announced the '18 MY.
Would these enhancements be available as a no cost update for owners of a '17 C7 with the PDR option? In other words, was it just software or were hardware updates required for the new functionality?
Also, the Cosworth Toolbox. Is this a Windows application that can read the PDR data? Do you get free updates over the life of the software and did the new features in the '18 version require a new update to this software?
Reason I ask is that I am considering my first Vette and looking at new '17 or '18 models. The PDR is fast becoming my #1 options requirement but need to understand if the '18 offers a way better PDR or if there's not much difference or an upgrade path should I purchase a '17.
I have always wanted a Vette ever since my first ride in my aunt's '78 Silver Anniversary edition. Ironically, she took me to see Corvette Summer in her Vette. It was the best day for an 8 year old!!!
Thanks in advance gang!
42ZED (02-21-2024)
Holy crap I thought I was the only one who saw that movie. LOL
42ZED (02-21-2024)
Received 8,928 Likes
Cosworth Tool Box is a free Windows program from Cosworth that you can download from their web site. I don't know if it is updated to include any more data streams or not. Since the PDR is a Cosworth Product I imagine they will keep the tool up to date with the current PDR being sold. They also offer a tool called Pi Tool Set which permits more detailed analysis. There are two versions of the tool set, a free version that is limited in the data that can be tracked and a $1500 Pro version which can track more data at one time. Poor-Sha a forum member uses this tool to help himself and others understand what they did or did not do when on track. His YouTube account is Hi-Po Driver if you want to see some of the analyses that he has done to date: https://www.youtube.com/channel/UCDS...IkweraNN2199tg
If you aren't going to track the car I doubt the extra data would be worthwhile to you. I have a 2015 that is missing the new data but even the new data doesn't have what I am looking for (IAT3 or Manifold Temperature).
Bill
Bill
Marc3 (03-14-2019)
Would it have killed them to let you put a config file on the SD card where you could pick and chose which PIDs or CAN IDs you wanted to monitor?
Bill
If there was a config file on the SD card when you put it in the car, the PDR would read it on start up, log those parameters during the drive, and write the data to the video file as normal. It's not that far fetched at all. There's a PC based scan tool / data logger I've used that works on exactly the same concept (minus the video part). You set up an XML file with all the PIDs and scaling factors, and the softwarw logs the output to the screen and a CSV file.
It's academic though. They're sure as hell not going to add it now that the system is end of life, and we can't add it ourselves because the firmware is secured on the PDR module.
Bill
You are assuming they use the same hardware interface to access the data as the PC based scan tool. The scan tool goes through the OBD port with its messaging protocol. The PDR talks to the BCM through one of the secondary busses and gets the data through the BCM from the modules on the high speed LAN including signals that aren't from the ECM. I think the EBCM has sensors that measure vertical acceleration and that is one of the data streams used for analysis of what my car was doing on track. Universally available OBD II Software that talks to the OBD II Data Link may do squat for the other interface.
Bill
Bill
The PDR has this 'secret decoder ring' internal to its software. That could just as easily be moved off to a customer modifiable config file on the SD card, but that would either require GM to share their bus message format (hell will freeze over first) or at least allow us to discover it for ourselves and reconfigure the PDR to fit our own needs. Which also didn't and won't happen.
If you want to log raw IAT3 and manifold temp, AND that data is exposed to other modules via the HS-GMLAN bus, then it will be loggable via the OBD port if you've got the right hardware and software. If the PCM keeps that data internal to itself, then pretty much nothing can log it.
The additional channels were available on some 2017 cars, my 2017 Z07 actually had them even though it was advertised as a 2018 feature. There is the GM Cosworth Toolbox which is the one GM points you at. It will show you some of the data but it is very fixed in what it displays and I've not seen any of the additional 2018+ channels in this tool. Then there is Cosworth Pi Toolbox which has 4 different SKUs from a free lite version to the Ultimate version. If you're interested in doing real data analysis I'd spring for the Plus version at a minimum (I run Pro). Pi Toolbox let's you add different displays with the channels you choose and also more advanced things like math channels. It just reads whatever is in the data file so the software doesn't need to change. I've read older and newer PDR files as well as data files from 991.1 and 991.2 Porsche GT3 Cup cars without any software changes other than picking the right channel names.
Cosworth Pi Toolset is a different tool that is used on some cars (like the 911 Cup cars) to configure which channels get logged and at what frequency. I've asked Cosworth engineers if there was a Toolset equivalent for the GM PDR module and was told that what gets logged is defined by GM and locked down so you can't change it. Now could you swap out your PDR module with the one from a 2018 car and it might give you the extra channels but I don't know. If you try it and it works please do let us all know.
Three are a bunch of videos on using Pi Toolbox on my YT channel.
Marc3 (03-16-2019)
Has anyone tried to swap the PDR module in a pre-2018 C7 with the latest one and see if it makes a difference to capture the extra data from 2018+ or is it all the software calibration so the hardware upgrade wouldn't be enough?
@Jeff V. sorry to pull you into this thread after a while. Do you think it would work to buy a PDR module with a later part number like 84246362 and obtain a later software version? It seems the Recorder Assembly P/N is correlated to the versions you posted in another thread (https://www.corvetteforum.com/forums...post1598524185).
anyone have a way to remove the sd card module to replace it? mine is broken . I have a replacement but dont see how to get it out. glovebox removal doesnt get me to the module
bick333 (02-29-2024)
