Serpentine belt question
I have a 2017 base model 12k miles, it has always had a belt squeak when cold. I was cleaning my car today and under the hood, then I noticed that the 6th tooth on the belt is missing. What caused/causes this?
Change the belt. I had a squeaky serpentine belt on my 1K resurrected Tahoe. Before I found it was the belt I re-greased all the bearings in the idlers and made sure it wasn't a power steering or water pump, or the alternator. Changed the belt, and squeak was gone. That belt looks tired, though with only 12K on it that seems low. Did the car sit for a while? I think that's what killed my belt.
badhabit_wb (05-17-2019)
Received 5,202 Likes
Absolutely crazy bit of bad luck, but on the other hand... now you KNOW!
