Z06 heat exchanger retrofit
I am installing a afco Z06 heat exchanger into my C7 to be used with my intercooled intake manifold. Can someone explain how the system flows on the Z? With specific reference to the four outlets on the heat exchanger?
jcdives (06-21-2019)
Thanks for the feedback. So for my purposes maybe I should connect the ports on the passenger side effectively creating a dual pass setup?
I just ran hoses to the trunk. I was able to run two 3/4" hoses into the trunk without having to cut or drill into the car
Supporting Vendor
I have a solution that would work well. Our heat exchanger I can setup with a loop to make it easily dual pass in your type system. It's what we do on our A2w setup. My hx also has swappable fittings so you can do any size up to 16 an with no welding. Than our trunk tank is a design that allows you to keep the targa in place too. If you have any questions let me know.
https://cordesperformanceracing.com/...eat-exchanger/
