2019 redline curiosity
St. Jude Donor '08-'09-'10
So, this is kind of a weird issue, that i am not sure if it is an issue or not. I have an appointment saturday to get this checked out, but wanted to run it by the forum first..
So: '19 pretty well base model stingray.. (+ nav)
During the break in period, The electronic tach has a "redline" of 4500 rpm, with blue up to around 4000, then yellow to 4500, and red above.
Once i hit 500 miles, blue all the way up to 6500 rpm, then red beyond that (i assume break in was complete here).
Now for the issue..... Every time i start the car, it reverts back to the pre-break in 4500rpm redline. Sometimes it lasts 15 seconds, this morning it lasted maybe 10-15 minutes.. Has anyone else noticed this? is this supposed to happen while the car warms up?
Not my picture but this shows the warning colors from 3.5 to 6.5
As stated, absolutely normal. It’s the car reminding you the oil is not
up to temp.
up to temp.
Received 8,928 Likes
Bill
The following 3 users liked this post by Bill Dearborn:
I have an appointment for other reasons (clunking on start up). but i am glad to know this is normal. I thought that might be the cause, but have not had opportunity to check it while the vehicle is warm.
clunks, like shifting into gear. The whole vehicle jerks with it. They were unable to replicate it on saturday after letting it sit for a couple of hours (i guess it is only on cold start), so i will be leaving it over night on thursday. One tech said it might be the torque converter draining.
Sr.Random input generator
Are you sure? You might be right of course, but It looked more like it waits for 100 degrees oil to me. Have you read that somewhere?
I am certain, but admittedly by observation only by monitoring oil and water temperature, together with the incremental steps advancing the redline.
It actually has to do with peak piston speeds. The BMW engine is a shorter stroke design, (S65, 92 bore, 75.2 stroke, ratio 1.22:1, 8400 red line) whereas the C7 (lt1 b4.065, s3.622” ratio 1.112:1). The higher the ratio the more it can rev. A Yamaha R1 (79x50.9. Ratio 1.53:1) has a red line of 14,500...
also your S65 eats rod bearings if you visit redline often. Then again so does the S54..
Unfortunately, I'm yet to see a reliable high revving engine, except Honda S2000's engine. When run hard, they all fail. Perhaps some of Porsche's high rev GT engines are good, too, but people just don't use them enough at the track (they usually sell within a year) to come to a conclusion.
