95mm TB; what adapter are you using?
Supporting Vendor
As many of you know we have already released our Modified 95mm (100mm Effective) TB, while working on it we realized that the 3rd party Adapters we were using were defeating the purpose of modifying the TB to some extent. That is, we are opening and smoothing the flow path on the TB and the Manifold only to find that these 3rd party Adapters were closing down area and posing restrictions downstream of the TB. See figure 1 (straight bore adapter).
Every time the airflow finds an abrupt change of area, it tends to create vortices, these create centers of low pressure where the air recirculates and losses density, exactly what you don't want to happen inside the manifold or at the inlet of your supercharger.
Having seen that, we went with our own Adapter design, and the results were great see figure 2 (Soler Performance Tapered Adapter). But we did not stop there, we also made one for 103mm Manifolds. We can also make them match your own ported Manifold/SC internal diameter size.
The results were great, our screw hole pattern perfectly centers the TB on the Manifold to avoid steps due to bore mismatches. The smooth tapered transition allows the air to accommodate to the contour without causing large pressure drops. The contours of the TB, Adapter, and Manifold coincide edge to edge all around, zero steps.
The same philosophy "one-size-fits-only-one". Once again the once-size-fit-all Adapters don't fit any in reality.
These Adapters are not about gaining power, the point is making them right (TB and Manifold Specific), so you don't lose any of those hard-earned HP's you attempted with your Mods.
95mm Throttle Body with Straight Bore Adapter, on a Stock Manifold causing vortices and pressure drops at Manifold inlet.
95mm Throttle Body with Soler Performance Adapter on a Stock Manifold, allowing a smooth/efficient transition at the manifold inlet
Soler Performace 95mm (100mm Eff.) Throttle Body and Adapter Kit.
Soler Performance 95mm to 103mm (MSD) Adapter Kit
Soler Performance 95-87 Design Features
Soler Performance 95-103 Design Features
Thanks,
Thanks,
Rob Petyo (12-30-2019)
Supporting Vendor
That would likely be the 95-Custom option, let us know the size of the internal diameter of your snout. If it is 103 mm, we can simply modify our standard 95-103 and perhaps remove the bull-noses.
Received 1,762 Likes
ttt
Nice piece you can also re-drill the bottom two holes on the T.B. and dont have to use the spacer at all. I had to do this due to the A/A TI head unit I have on my car. The spacer pushed it out just enough are the plug that has to plug into the T.B. to hit the pulley on the blower. But it works 100%.. Also I have a MSD intake on my car also..Robert
Supporting Vendor
Thanks, Robert. That is true, some folks do that. We thought about it, but didn't like the way it looks (thin walls on the mounting legs of the TB), it accomplished the mounting part of the job, no doubt.
Another detail to take into account is that in that case, it will also see a sudden increase in area, see pic below, it also creates recirculation and pressure drops, no as bad as when it sees a sudden decrease. This is why we have the 95mm-103mm adapter, and also because of the MSD manifold has material protruding into the bore at 4x places to allow for screw holes. The seal also runs inwards there. The bull-noses catch the Seal there and allow the flow to smoothly go over those protrusions. The Adapter outlet matches the Manifold inlet edge to edge all around (see pic below).
Recirculation on a sudden increase in area. (No Adapter)
103 mm Manifold Snout Contour.
Thanks,
Thanks,
I have a Lingenfelter adapter plate on my stock 95mm TB and yes, the adapter defeats the purpose of the 95mm tb. My blower is also ported, not sure to what size tho. It would be nice to get me another adapter that eliminates this necked down restriction. When I get my car back from the shop, I'll see if I can take a pic.
Do you have a pic of a 95mm tb with your adapter mated to the back of it, so I can see the smooth transition? Thanks,
Supporting Vendor
GeorgeR_Zed06 (01-02-2020)
The following 2 users liked this post by ssmith512:
GeorgeR_Zed06 (01-02-2020),
Mike@SolerEngr (01-02-2020)
Supporting Vendor
Thanks, George. They are $65. Available here: https://www.solerengineering.com/store
They all start at 95mm on TB side, and end either at 87mm (PN SE9871-95-87) for stock manifold/SC, or at 103mm (PN SE9871-95-103) for MSD manifold. If you have the stock manifold/SC and the snout has been ported, please order PN SE9871-95-87 and tell us the size of your snout internal diameter and we'll customize it it for you.
