SDM Airbag module conceptual question
Old Aug 26, 2020 | 07:54 PM
mityaz's Avatar
mityaz
Default SDM Airbag module conceptual question
Hi Guys,
As some of you may have seen the dealership "diagnosed" my car to having a faulty SDM module because it intermittently throws the airbag light while on the track. (I've removed seats to check for wiring and cannot find anything that would cause that). But anyway, the part number for the SDM module for my car 2019zr1 is out of stock in the entirety of USA. Now, i was able to source a 2017 Z06 SDM module (used) from a part out. The module looks physically the same (but part number on it is different)
Here is the question: Is this something that will work across the years? Let's say even if i get the dealership to flash the latest calibration if needed for example. Has anyone done this?
Thank you
Old Aug 26, 2020 | 11:43 PM
TheRobSJ's Avatar
TheRobSJ
They changed some of the wiring in 2019. I would imagine the SDM has a specific part number for 2019 because of that.
The connectors may be the same, but the terminals may not go to the same circuits. You plug that sucker in and all hell might break loose.
Old Aug 26, 2020 | 11:48 PM
X25's Avatar
X25
Sr.Random input generator
GM is known to modify the calibration of these controllers per capabilities of the car. In short, they want the airbags to deploy as quickly as possible, and they change the thresholds per car's own capabilities. If it were me, I'd be hesitant.
Old Aug 27, 2020 | 11:16 AM
Jeff V.'s Avatar
Jeff V.
Is your car an early build? GM recalled 500 ZR1s over this exact issue. The car could generate higher g-forces than the SDM was calibrated for, which caused errors.
https://jalopnik.com/gm-recalls-almo...-ri-1826992819
Inline with what the other two guys said, I wouldn't go mixing and matching modules. It could be a subtle difference, or it could be a totally different processor inside and won't work at all. Just hold out for the right part.
Old Aug 27, 2020 | 12:53 PM
mityaz's Avatar
mityaz
So, i have confirmed from 2 sources that all c7 corvettes form 2017 -2019 use the same new part number for the SDM module. Which is the same module that is on national backorder. The 2017 module that i got is not that part number. My running theory is that sometime after 2017 GM came up with a different part number (for whatever reason) for the 2017+ C7s. Do you guys see what this means? I am pretty sure that the modules are interchangeable (obviously i will need the calibration flashed). But as far as wiring goes, I am 99.9% sure that it should be the same.
I am waiting on my source from the dealer to confirm that the 2017 part number that i got from a 2017 car is indeed superseded by the new part number.
Old Aug 27, 2020 | 01:18 PM
Jeff V.'s Avatar
Jeff V.
There's still a potential issue. The SDM carries data related to the car's electronic security system. Not the key fobs, but codes that prevent it from starting if it detects certain modules have been incorrectly replaced with used ones. It's called an environment variable. It may not be reinitialized during a reflash. Some of GMs documentation is contradictory on that point.
Read more here: https://www.camaro5.com/forums/showthread.php?t=448794
Old Aug 30, 2020 | 07:09 PM
mityaz's Avatar
mityaz
Quick update for everyone. As mentioned above, i got a used SDM module from a 2017 z06. The numbers printed on the module itself (there are a total of 2 "part numbers" printed on each module) are not actual part numbers. And as long as the unit came out of the 2017-2019 corvette it is the same part number. I spoke to my dealer and told them that i am willing to install this myself if they are willing to flash it for me. The service advisor (whom i know personally) spoke to the corvette tech (whom i also know personally) and told me that it is safe to plug in the module and that they will try to reflash it. He did warn me that sometimes the module will not take the flash. So i will be going to the dealer in a few days to try and flash it.
To SDM Airbag module conceptual question
