Headers with stock NPP?
Old Oct 4, 2020 | 09:20 PM
dankhts's Avatar
dankhts
Default Headers with stock NPP?
My new to me '17 Z51 with NPP is too quiet for me compared to my heads/cam modded C5, thinking about headers and X pipe with the stock NPP mufflers.... To get some sound out of it...Anybody running a similar set up? I'm considering TSP headers and X pipe....
thanks for any input / thoughts!
Old Oct 4, 2020 | 10:21 PM
123sugey's Avatar
123sugey
Dig
You should be happy adding the headers and x pipe with your NPP. Sounds great no doubt. I have more mods than that but again... it will be louder and quiet when you need or want it. Added power is a + 😃
Old Oct 5, 2020 | 07:39 AM
Karallam's Avatar
Karallam
I just installed TSP headers and x pipe and i have NPP. The sound is beautiful man!
Old Oct 5, 2020 | 08:29 AM
dankhts's Avatar
dankhts
thanks for the replies....was considering the TSP headers with the stock NPP as long as I can get some acceptable sound out of it.....less expensive than some of the aftermarket NPP cat backs available plus there's more HP increase with the long tubes than an axle back muffler system...
Old Oct 5, 2020 | 08:59 AM
99vetteran's Avatar
99vetteran
Just put it in the track mode in your settings and its plenty loud, at least for me it is.
Old Oct 5, 2020 | 02:04 PM
C7&7's Avatar
C7&7
You’ll be happy with headers and X pipe with factory NPP. Ran that setup on my 14 and it sounded amazing. It’s very common actually.
Old Oct 5, 2020 | 06:54 PM
Stackenali's Avatar
Stackenali
2" Long tubes and stock exhaust is deafening at WOT
Old Oct 5, 2020 | 09:24 PM
shayan55's Avatar
shayan55
Cruising
I have 1 7/8 longtubes on my 15 with NPP and when the valves are closed its honestly pretty tame and quiet, but at WOT with the flaps open i feel like its pretty loud, at least for my taste.
Old Oct 5, 2020 | 10:08 PM
99vetteran's Avatar
99vetteran
Mine is very loud at WOT in the track mode, especially when you first start in the garage.
Old Oct 5, 2020 | 10:43 PM
Fast6.3's Avatar
Fast6.3
I ran the tsp 17/8 with offroad xpipe and npp sounded good and still had control went to magnaflow comp exhaust and got super loud even in stealth mode
now have corsa extreme its pretty tame but the exhaust note and volume are great
Old Oct 6, 2020 | 07:19 AM
99vetteran's Avatar
99vetteran
Plenty loud for this old turd with my 1 7/8 headers and X Pipe.
Old Oct 6, 2020 | 04:41 PM
cstapp99's Avatar
cstapp99
I'm running ARH long tubes with the hi-flow cats and the stock NPP mufflers. I added a mild to wild switch for maximum control. It's pleasantly loud with the valves open and really quiet with them closed. I switched my engine sound management to stealth mode to allow for "full on" and "full off" with the MTW switch. I really like the setup.
Old Oct 8, 2020 | 04:50 PM
Mpgslol's Avatar
Mpgslol
I've got tsp long tubes (hi flow cats) with stock npp mufflers.
They are LOUD! The car sounds absolutely amazing. The best way to explain the sound is like an American ferrari. They do cause a check engine light though. I had to tune the car to remove the CEL.
My car made 435/440 with headers and a tune.
Old Oct 9, 2020 | 12:24 AM
ricmalaz's Avatar
ricmalaz
2016 Z51 with NPP, Corsa 1 7/8 long tube headers, with the Corsa offroad x-pipe, and Mild2Wild NPP switch. It's very loud when I want it which is almost always, and very quite when needed (early morning starts without waking the neighbors). 638 whp which is a ton of fun!
Old Oct 9, 2020 | 02:23 AM
charlezthegreat's Avatar
charlezthegreat
I have catless headers on my cammed out c7 z06. Its loud as f#ck. lol.
I would keep the NPP stock mufflers for now. The NPP is a nice function because you can always silence it when you have to. Get an aftermarket or muffler delete later if you want to be louder.
Old Oct 9, 2020 | 07:31 PM
KemahGT's Avatar
KemahGT
Get headers and keep the NPP. It will be plenty loud with valves open and you’ll be able to close them when you pull up to the drive through at McDonalds to get that coffee. NOBODY wants to hear that loud **** ALL the time. Except maybe those Mustang guys. It really gets annoying. And by the way, aftermarket deletes or mufflers would only add about 2 horsepower. You’d save enough for coffee for the next 5 years if you keep the NPP.
Old Oct 10, 2020 | 11:50 PM
Denny Velez's Avatar
Denny Velez
7th Gear
Excuse my ignorance but what's NPP?
Old Oct 12, 2020 | 08:21 AM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
It's an oem exhaust option on the C7s which allows you to operate the sound of the exhaust sytem by manually operating the valves to various settings.
Old Oct 12, 2020 | 08:23 AM
Shirl's Avatar
Shirl
This is a great thread btw. I always have mine in track mode and it's too quiet for me. I'm working on installing the mild to wild but that still won't be enough. My C5 with Bullets, headers and high flow cats sounds amazing compared to my C7.qaaaaaaaw
To Headers with stock NPP?
