New Battery - no remote start
Old Oct 30, 2022 | 02:24 PM
Professor G's Avatar
Professor G
8th Gear
Default New Battery - no remote start
Had a new battery installed on my 2019 Corvette C7 Grand Sport, as the old one had a bad cell. So, now the "check engine" light is on, AAA said it's normal and will go out.
Ok, BUT the remote start no longer works. Car starts fine with starter button on dash, but nothing happens with the remote. Any ideas??? THANKS
Old Oct 30, 2022 | 03:39 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Did they break the little black wire that attaches to the negative battery post on the battery?
It would be better to trouble shoot if you would read the code with a code reader.
Elmer
Old Oct 30, 2022 | 04:05 PM
laserdude2215's Avatar
laserdude2215
The remote start is disabled if the check engine light is on.
Old Oct 30, 2022 | 08:38 PM
Professor G
8th Gear
Ah, yes, that makes sense. I'll give it some time to reset itself hopefully. THANKS
Old Oct 30, 2022 | 10:31 PM
mharris1984's Avatar
mharris1984
I've never heard of a check engine light coming on after a battery replacement. Yes the computer has to go thru its entire drive cycles and learn to be emissions compliant again, but that never activates the check engine light. Sounds like a copout from the person installing to get you off their back. Check the codes, find out what the check engine light is on for. Once you post that, we can help. And like said above, as long as check engine light is on, remote start is disabled. So if we fix check engine light, remote start will miraculously return.
Old Oct 30, 2022 | 11:35 PM
Professor G
8th Gear
I see, since I did not have the check engine light on until the battery was changed, I assumed it was the battery change that made it go on. I will try and see what the code is then. Thank you as well.
Old Oct 31, 2022 | 05:56 AM
mdformula350's Avatar
mdformula350
yeah i would check the battery area connections, especially the smaller negative one that Elmer mentioned. if that gets ripped out of the terminal which happens all sorts of gremlins come out at night.
but i took my battery out and in with no check engine light or "resetting" period... if anything it clears out the codes and then you need to relearn emissions stuff and other factors.
https://www.corvetteforum.com/how-to...battery-368194
Old Oct 31, 2022 | 08:35 AM
Professor G
8th Gear
AAA tow truck driver was right! Second start today IT RESET ITSELF AND REMOTE WORKS!!! Nothing wrong 👏
To New Battery - no remote start
