2014 brake fluid level low
Old Jul 8, 2025 | 12:53 PM
HappyGen06's Avatar
HappyGen06
Cruising
Default 2014 brake fluid level low
After my car sat undriven for 10 days, I took it out and my "brake fluid low" warning came on the dash. I checked the reservoir and the level is below the MIN level. I see no leak under the hood. I had the brakes checked a month ago for a squeak noise and they said my brakes had plenty of pad left, and in fact I should use the brakes more to burn them in to eliminate the noise. I've got 19k miles. I see no fluid on the garage floor. Question - could there be a leak that occurs only when I drive the vehicle? But I smell nothing burning while I'm driving. Thanks.
Old Jul 8, 2025 | 01:54 PM
96GS#007's Avatar
96GS#007
Check around the master cylinder and check inside the car near the firewall.
Sounds like a seal failed on the master cylinder. However, also carefully check the front and back of all calipers for evidence of leakage.
Old Jul 8, 2025 | 02:01 PM
HappyGen06's Avatar
HappyGen06
Cruising
Old Jul 8, 2025 | 08:05 PM
RonC7's Avatar
RonC7
Have you EVER checked the brake fluid level? Buy some Prestone DOT 3/4 brake fluid and fill about 25% between min and high. If you fill all the way, the fluid will likely overflow when the calipers are compressed to do brake work.
Monitor the fluid level using a bright work light so you can see fluid level through the reservoir. Avoid opening the reservoir cap as the brake fluid can absorb moisture. Obviously if the fluid level is not stable have your brake system looked at.
Ron
Old Jul 9, 2025 | 12:08 AM
aklim's Avatar
aklim
Ron
Not according to the AI search.
Search Labs | AI Overview
No, the brake fluid level does not rise when braking. When the brake pedal is depressed, the brake fluid is pushed from the master cylinder into the brake lines, causing the brake calipers to engage and slow the vehicle down. The level of brake fluid in the reservoir may slightly drop as brake pads wear down, because the caliper pistons extend further to compensate for the pad wear, but it does not rise.
Here's a more detailed explanation:
  • Braking Process:
    When you press the brake pedal, a piston in the master cylinder moves, pushing brake fluid into the brake lines.
  • Fluid Movement:
    This pressurized fluid travels to the brake calipers, which then clamp down on the brake rotors, slowing the wheels.
  • Fluid Level:
    As the brake pads wear down, the caliper pistons extend further out to maintain contact with the rotors. This movement creates a slight drop in the fluid level in the master cylinder's reservoir.
  • No Rise in Level:
    The fluid does not rise during braking. The fluid is being displaced into the brake lines and calipers, not back into the reservoir.
  • Importance of Fluid Level:
    If the brake fluid level is too low, it can indicate a leak in the brake system or worn-out brake pads, and it's important to address the issue promptly.
Old Jul 11, 2025 | 05:44 PM
88redconvert's Avatar
88redconvert
The only thing I can add to what has already been said is to look at the inside of your tires. Sometimes a leak at one of the calipers will drip to the wheel and the centrifugal force will throw it on to the tire. Good luck.
Old Jul 11, 2025 | 08:22 PM
HappyGen06's Avatar
HappyGen06
Cruising
thx
Old Jul 14, 2025 | 01:35 PM
h422694's Avatar
h422694
Originally Posted by HappyGen06
thx
I don,'t trust AI 100% yet. Have gotten some pretty dumb answers
Old Jul 14, 2025 | 01:39 PM
aklim's Avatar
aklim
Fair enough. If you have a better source of information, I'd like to look at it.
To 2014 brake fluid level low
