AlloyGator Wheel Protection
Former Vendor
What Does the AlloyGator Do?
Potholes, curbs and a bevy of other hazards can scratch and/or destroy your alloy wheels.
If you have ever scraped your wheels against anything and have wished that you did not do so then you might love AlloyGator.
It protects your wheels by taking the damage from the curb and allows you, for the most part, to wipe away the evidence after it happens.
See the video on our page here
Keep in mind that they do not show you cleaning the product after a mishap. However, you can and should do that after contact.
Are your wheels already damaged from the curb?
Check this out: AlloyGator Wheel Protectors cover about 1/4 of an inch of the edge of your wheel.
Hide the curb rash you already have while preventing it from happening any more!!
"What Do I Get When I Buy This Product?"
Here is what you get inside the box:
Set of 4 Alloygators
6 matching joining clips
Stainless-steel securing clips
A tube of high quality glue
A key-ring clean-up tool
A suitability gauge
And fitting instructions and care advice
You can have a look at what is in the box on our page here
"Can I Get a Set of AlloyGators that Glow in the Dark?"
The answer is yes.
Have a look at the video on our page here to see what it looks like when you drive by.
"Is it easy to install? How does it work?"
The answer is that it is very easy to install. You can see how easy it is to install and how it works by watching the videoon our page here
Simply select your car, wheel and AlloyGator color to view your style.
You can even configure your own color scheme here by choosing the (relative) color of your car, and then wheel color, and test each color combination!!
A suitability gauge
The answer is yes.
Former Vendor
I'm getting them installed on my 2011 GS this week and I'll post up some better pics
Former Vendor
FREQUENTLY ASKED QUESTIONS
What material are the rim protectors made of?
The AlloyGator product is made of a “Super Tough Nylon” which is flexible and wont damage your alloy wheels during fitting, but tough enough to give superior protection.
How Permanent is the Colour?
Consistant colour is maintained thoughout the product, which means that the colour is fully maintained after damage has been rectified. We recommend you regularly clean your wheels and AlloyGators with normal car shampoo or universal wheel cleaners suitable for delicate finishes like chrome. Avoid the harsh cleaners and thick, brush-on tyre shines used by some hand car-washes.
How do I remove my alloygators?
To remove the profile simply jack up the car, fully deflate the tyre, remove the plastic joining clip and carefully prise the profile up around the joint area. Firmly tap the face of the AlloyGator using a rubber mallet on the side which has the hole in it. This will then release the glue and open up the joint. Once the joint is open carefully prise the profile out of its seated position from the tyre side of the wheel, starting with the end without the hole and using a tyre lever or flat bladed screwdriver along the side and under the profile, prising in an upward motion. Once the end of the profile is free from the wheel and tyre then carefully pull it out from its position across the tyre wall in an outward motion in order to prevent any damage to the wheel from the stainless steel clips
What is the fitting method?
The AlloyGator is locked to the wheel over 360° using highly robust patented technology. Please view our fitting video on our home page for further advice.
Have they been tested at speed?
They have been tested under normal driving conditions and within the legal speed limit.
p.s. I have them on my C6 Corvette Grand Sport and have had no problems with spirited driving
Former Vendor
Check out how you can get 5% off your order during the month of May!!
5% Off Storewide Sale ~ Guide Dogs For The Blind Donation
Former Vendor
There's always the alternative......
Former Vendor
Former Vendor
There's already some bids going on our donated $250 gift card with all proceeds going to st. jude,
Join in on the action before it ends on 6-26!
Use this link here :
https://www.corvetteforum.com/forums...post1594973988
Former Vendor
Former Vendor
Special promotion for forum members who change their own oil at home. We are offering you a Buy 3, Get 1 FREE promo on your oil filters.
Simply visit our store at the link provided, add 4 oil filters into your cart, and enter promo code "PF64" and you will get 1 FREE!!!!
ACDelco PF64 Professional Engine Oil Filter - GM (12640445)
https://www.youtube.com/watch?v=y5E_M0FFV8A
http://www.trunkmonkeyparts.com/
Former Vendor
Filter Cap - GM (12593356) is what members have been installing for the dry sumps until now
LT1 WET Sump Engine Mobil 1 Oil Cap from GM
I will have a full shelf tomorrow, and pictures to follow their arrival!
Also now available is a Corvette-designed oil cap for the LT4/LT1 Z52, LT4/LT1 DRY Sump Engine Mobil 1 Oil Cap from GM
Pictures will be available soon.
Also, will have the Mobil 1 Spec Engine Label available soon too,
once part number has been verified for that.
Former Vendor
I want to apologize for the delay to those who have ordered the new oil cap
GM backordered the caps right away after we placed our order for stock,
and we were able to fill the first set of orders right away,
but there are still orders "awaiting shipment"
We are working closely with GM to get at least a few hundred in stock of each cap
Thank you everybody for your patience!
