C7 Corvette Stingray DBA Brake Rotors available at RPI Designs
Platinum Supporting Vendor
As you know Brake pads and rotors on your Corvette Stingray will eventually need to be replaced. Rather than replacing them with factory brake rotors why not upgrade to a set of DBA 4000 Series rotors.
4000 Series DBA Rotors For the Corvette C7 Corvette
The DBA 4000 Series is an excellent mid-series street legal brake rotors for your Corvette C7 that is an excellent upgrade from the OEM Rotors. The DBA 4000 Series Rotors that we offer are an exact match for OEM equipment for the Corvette and can easily be installed without any additional components or modifications to your Corvette.
DBA’s 4000-series enhanced performance rotor features Thermal Stability Profiling for improved heat handling. This unique process provides greater thermal stability than standard street discs. TSP enhances the microstructure of the disc rotor for performance applications. Greater thermal stability allows your discs to take more heat, making them more stable under heavy braking for longer. TSP also means improved brake pad and disc rotor life and delayed brake fade.
Also unique to DBA Rotors, Thermo-Graphic paint markings are used for effective heat monitoring which changes color at specific temperature thresholds. By monitoring the markings, drivers can check their braking performance quickly and easily.
4000 Series DBA rotors are available in slotted or slotted and drilled configurations (XS), The unique 6x6 Wiper Slot is designed to efficiently clear the gasses, dust, and debris, resulting in a cleaner disc surface for better braking while maintaining maximum friction.
4000 series rotors also incorporate the innovative Kangaroo Paw ventilation design, which runs cooler, stronger and outperforms traditional straight vane disc rotors by up to 20%.
Designed for the performance street and motorsport enthusiast.
C7 Corvette DBA 4000 Series Cross Drilled/Slotted UniDirectional Front Rotor
Item # DBA42760BLKXS
website link : https://www.rpidesigns.com/shop/item.aspx?itemid=5296
C7 Corvette DBA 4000 Series Cross Drilled/Slotted UniDirectional Rear Rotor
Item # DBA42761BLKXS
https://www.rpidesigns.com/shop/item...lack-hub-rear/
Item # DBA42762BLKXS
Website link : https://www.rpidesigns.com/shop/item...ack-hub-rear-/
C7 Corvette DBA T3 4000 T-Slot Uni-Directional Slotted Rotor Front
Item # DBA42760S
Website Link : https://www.rpidesigns.com/shop/item...slotted-rotor/
C7 Corvette DBA 4000 Series T-Slot Uni-Directional Slotted Rotor Rear
Item # DBA42761S
https://www.rpidesigns.com/shop/item...ed-rotor-rear/
Item # DBA42760S
Item # DBA42761S
__________________
I take it these are only Z51? Do you carry DBA for Grandsport iron brakes?
Thank you for asking and yes the above rotors would just be for the Stingray models. DBA does not list a rotor yet for the Grandsport, they are only showing a rotor only for a 2016 Z06 model that you would have to reuse the stock rotor hat. Thanks, Don
Do you have a link to the Z06 iron rotor? I can't find it on your site.
