C7 Vendor for Sale Exclusive forum for vendors to list C7 products, services and promotions.
AeroForce OBD2 Gauge Specials
Old 02-25-2019, 07:13 PM
RDP Store
Supporting Vendor
RDP Store's Avatar
We wont be beaten by any competitor and we also offer discounted installation rates as well, and all products we sell come with Full Manufacturer Warranties
RDP Store is offline
Old 02-26-2019, 12:24 PM
RDP Store
Supporting Vendor
RDP Store's Avatar
Deal with the Guys that Not only sell the parts but install tune and race them on our own cars
Old 02-27-2019, 05:42 PM
RDP Store
Supporting Vendor
RDP Store's Avatar
RDP Store is Proud to Offer Great Savings on Aeroforce Gauges for your Corvette.
The Interceptor gauge is 52mm (2 1/16") in diameter and will fit in all standard gauge pods of this size. A 5' cable is included with appropriate OBD2 connector. A splitter cable is included with the dual Interceptor units. Gauges come with a black bezel with polished silver center ring with a black face as shown on right. An extra white face is also included and can easily be swapped since the bezel screws on/off. Optional black, polished silver, and brushed silver bezel along with various other face options can be purchased separately from the accessories page.
A function menu is available by pushing both buttons simultaneously. One menu option allows you to enter a record mode. Once selected, the Interceptor will return to normal scan mode, but will start recording the displayed data automatically when the throttle exceeds 60%. Approximately 60 seconds of data will be stored. Returning to the menu screen, you can choose to replay the stored data on the Interceptor display.
The gauge displays 2 parameters at a time, but can be programmed to cycle through up to 8 parameters during a user determined period of time. This way you can monitor several items without taking any other actions.
Has high intensity warning lights that can be set using a 1 or 2 parameter algorithm. P1, P1 or P2, P1 and P2. For example, trigger the lights when rpm exceeds 6000 rpm, or when trans temp exceeds 230 F and coolant exceeds 210 F, or when air fuel ratio is above 12.5 and throttle is above 75%. Due to the gauges extremely fast update rate, this light is very accurate and easy to set. Once you try it you'll find you can't live without it!
Another menu option offers the ability to swap the foreground and backround colors of the display (as pictured below). Using this feature, for example, the gauge with a black backround and blue characters (negative image) becomes a blue backround with black characters (positive image). Not only can this be visually appealing but beneficial in changing lighting conditions. Positive images are easier to read in bright sunlight, negative at night.
The Interceptor's scan rate can also be adjusted through a menu function.
DTC's (Diagnostic Trouble Codes) can be accessed and cleared via menu options.This essential feature will help the gauge to pay for itself the first time the check engine light comes on. Those that have modified their vehicle will find this very handy when a sensor, vacuum line, etc. has been inadvertently left disconnected, or something was just not put back together properly.
The two analog inputs can be configured through menu choices. A linear conversion can be entered so that an analog signal connected to the gauge can be read in appropriate units. These inputs are handy for pressure signals such as those from MAP and oil pressure sensors, analog outputs from Air/Fuel ratio kits, etc. These signal can then be read and recorded along side the other parameters obtained on the vehicle's bus.
The gauge has bi-directional controls allowing for manual control of the low and high speed fans, CASE relearn and ECU reset on GM vehicles, and on most Chrysler vehicles the transmission controller can be reset and Electronic Stability Program can also be completely turned off to improve track performance.
New optional relay output module allows you to control a 12v relay based on values of OBD2 or analog input data.
Last but not least, the Interceptor will measure 0-60 times, as well as 1/8 and 1/4 mile time and speeds. This is accomplished through a simple menu selection. This function is not available on the ISO based (older imports) due to slower bus speeds.
Installation in most cases is accomplished by simply plugging the supplied connector into the OBD2 port below the steering wheel. Literally plug-and-play! Some vehicles such as those requiring the ISOi version (older imports) require switched 12v power. The rear connector of the gauge has a provision for this so installation is still a snap!
Dual Interceptor Option: Two Interceptors can be purchased with a special splitter cable that allows both gauges to operate simultaneously. The second gauge of a dual set in most cases is simply another single gauge programmed to working in tandem. The exception is the SR dual set in which case the second gauge will show a smaller subset of parameters that the main gauge. This is due to limitations of the Chrysler PCM. Check the list of parameters and features for more details. This second gauge also will not have a performance timer.
Warranty
Aeroforce Technology warrants this product and its accessories against defects in material and workmanship for a period of 1 year from the date of purchase.
The Interceptor scan gauge is capable of displaying over 100 parameters, two at a time (8 using cyclic scan), at an adjustable rate of up to approximately 20 times per second. Not all are supported by every vehicle, so there is no guarantee that the Interceptor will display all of these on your particular car or truck. If the vehicle is broadcasting the parameter, the Interceptor will recognize this and make it available for display. A sample list is below...
RPM
MPH
Intake Air Temperature (post Intercooler)
Ambient Air Temperature (pre Intercooler)
Engine Coolant Temperature
Exhaust Gas Temperature (PCM Calculated)
Transmission Temp. (auto trans)
Manifold Pressure (vacuum/boost) displayed in PSI
Fuel Temperature
Battery Voltage
Battery Temp
Injector Pulse Width in msec.
Injector Duty Cycle (%)
Air Flow Rate into engine
Long Term Fuel Trim
Short Term Fuel Trim
O2 Sensor Voltage
Barometric Pressure
Ignition Advance
Base Spark
PCM Spark Adjust
Fuel Status (open/closed loop)
Wastegate Solenoid Duty Cycle (%)
Knock Retard
Knock Sensor Raw Voltage
Throttle Position Percentage
Throttle Position Sensor Raw Volts
Calculated Net Horsepower
Engine Load
Transmission Slip
Current Transmission Gear
Torque Delivered to Transmission
Torque Converter lockup status
Brake pressure
Brake Booster Travel
Steering Angle
Non-driven Wheel Speed
Lateral G's
Yaw
Fuel economy (instantaneous and average)
P-ratio - pressure ratio MAP/Barometer
2 user configurable analog inputs**
** 0-5v inputs can be configured to read the outputs from MAP sensors, Air/Fuel ratio kits, pressure or temperature sensors, etc. Raw voltage can be displayed or a conversion can be entered to read proper units.
Users will find that ability to log RPM vs other parameters at high speed such as ignition advance, boost, or knock retard invaluable with regards to tuning.
Use Promo Code of md5d
Single
https://rdpstore.com/p-499-aeroforce...ge-single.aspx
Duel Combo
https://rdpstore.com/p-10473-aerofor...el-gauges.aspx
For Super Specials Pm us here or give us a call on 440 358 5500 or 440 251 8571
Old 03-01-2019, 08:35 PM
RDP Store
Supporting Vendor
RDP Store's Avatar
RDP Store has teamed up with Paypal to Offer 6 Months Interest Free Finance on all items over $99, its a simply process and only takes a couple of minutes to complete on the Site Also Save Everyday with RDP Store Member Pricing
http://www.rdpstore.com
Old 03-02-2019, 01:40 PM
RDP Store
Supporting Vendor
RDP Store's Avatar
PM for deals and Benefits
Old 03-03-2019, 05:59 PM
RDP Store
Supporting Vendor
RDP Store's Avatar
We wont be beaten by any competitor and we also offer discounted installation rates as well, and all products we sell come with Full Manufacturer Warranties Unlike items Sold on Amazon and Ebay.
Old 03-04-2019, 08:21 PM
RDP Store
Supporting Vendor
RDP Store's Avatar
Warranty
RPM
MPH
Fuel Temperature
Battery Voltage
Battery Temp
Long Term Fuel Trim
O2 Sensor Voltage
Barometric Pressure
Ignition Advance
Base Spark
PCM Spark Adjust
Knock Retard
Engine Load
Transmission Slip
Brake pressure
Steering Angle
Lateral G's
Yaw
Single
Duel Combo
Old 03-05-2019, 06:47 PM
RDP Store
Supporting Vendor
RDP Store's Avatar
With Tax Season upon us and some extra cash to spend on your toys, pm us for a Special Deal on any item that your looking at and we can get you hooked up, we will match and Beat any Genuine Quote and we have 6 Months Interest Free Options and Layaway programs. Give us a call on 440-358-5500 or email us at [email protected]
Old 03-06-2019, 06:34 PM
RDP Store
Supporting Vendor
RDP Store's Avatar
Put those Tax Return Dollars to good use and buy your car something to make you both Happy!!!!
Old 03-07-2019, 07:53 PM
RDP Store
Supporting Vendor
RDP Store's Avatar
Old 03-08-2019, 10:35 PM
RDP Store
Supporting Vendor
RDP Store's Avatar
Bump for a Deal
Old 03-10-2019, 02:06 PM
RDP Store
Supporting Vendor
RDP Store's Avatar
Save Now with our Promo Code of md5d
Old 03-11-2019, 08:24 PM
  #33
RDP Store
Supporting Vendor
RDP Store's Avatar
Promo Code just Updated
Old 03-12-2019, 07:56 PM
  #34
RDP Store
Supporting Vendor
RDP Store's Avatar
Old 03-13-2019, 06:54 PM
  #35
RDP Store
Supporting Vendor
RDP Store's Avatar
Great Time of the Year to get the Mods started
Old 03-15-2019, 09:43 AM
  #36
RDP Store
Supporting Vendor
RDP Store's Avatar
Best Pricing and Best Service to the Forum Members here, hit us up with questions and for a Promo Code.
Old 03-16-2019, 07:18 PM
  #37
RDP Store
Supporting Vendor
RDP Store's Avatar
Old 03-17-2019, 02:32 PM
  #38
RDP Store
Supporting Vendor
RDP Store's Avatar
Old Yesterday, 07:48 PM
  #39
RDP Store
Supporting Vendor
RDP Store's Avatar
Bump for a Deal
Quick Reply: AeroForce OBD2 Gauge Specials
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
