C7 Vendor for Sale Exclusive forum for vendors to list C7 products, services and promotions.
AeroForce OBD2 Gauge Specials
Old 03-23-2019, 10:27 PM
  #41
RDP Store
Supporting Vendor
RDP Store's Avatar
Best Pricing and Best Service to the Forum Members here, hit us up with questions and for a Promo Code
Old 03-24-2019, 06:27 PM
  #42
RDP Store
Supporting Vendor
RDP Store's Avatar
RDP Store has teamed up with Paypal to Offer 6 Months Interest Free Finance on all items over $99, its a simply process and only takes a couple of minutes to complete on the Site Also Save Everyday with RDP Store Member Pricing
http://www.rdpstore.com
Old 03-25-2019, 08:29 PM
  #43
RDP Store
Supporting Vendor
RDP Store's Avatar
PM for a Deal to Beat ALL Others
Old 03-27-2019, 06:00 PM
  #44
RDP Store
Supporting Vendor
RDP Store's Avatar
Make Any Purchase During the Months of March & April at RDP Store for the Chance to Win a Pit Barrel Cooker www.rdpstore.com
The Pit Barrel® features top-quality construction with durable 18 gauge steel and a porcelain enamel coating. The PBC package includes all of the accessories to cook an enormous variety (and quantity!) of food.
The PBC package includes:
1 30 Gallon Steel Drum/Lid
8 Stainless Steel Hooks
2 Steel Hanging Rods
1 Charcoal Basket
1 Standard Grill Grate
1 Wooden Hook Remover
1 Three-point Barrel Stand
1 All-Purpose Pit Rub
1 Beef & Game Pit Rub
Old 03-28-2019, 07:34 PM
  #45
RDP Store
Supporting Vendor
RDP Store's Avatar
Great Time of the Year to Save and Get your Parts Fitted Before Spring Driving Weather.
Old 03-31-2019, 12:01 PM
  #46
RDP Store
Supporting Vendor
RDP Store's Avatar
Old 04-01-2019, 10:24 PM
  #47
RDP Store
Supporting Vendor
RDP Store's Avatar
Its the Spring Make us a Deal Program, Simply Look up the Part you want and Need and let us know and we will Put together a Spring Saving Deal for you, Also Doesnt matter if you dont see it on our website as we still probably have it and havent added it to the site yet, Either pm us here or give us a call on 440 358 5500 www.rdpstore.com
Old 04-02-2019, 07:49 PM
  #48
RDP Store
Supporting Vendor
RDP Store's Avatar
Old 04-03-2019, 11:11 PM
  #49
RDP Store
Supporting Vendor
RDP Store's Avatar
RDP Store is Proud to Offer Great Savings on Aeroforce Gauges for your Corvette.
The Interceptor gauge is 52mm (2 1/16") in diameter and will fit in all standard gauge pods of this size. A 5' cable is included with appropriate OBD2 connector. A splitter cable is included with the dual Interceptor units. Gauges come with a black bezel with polished silver center ring with a black face as shown on right. An extra white face is also included and can easily be swapped since the bezel screws on/off. Optional black, polished silver, and brushed silver bezel along with various other face options can be purchased separately from the accessories page.
A function menu is available by pushing both buttons simultaneously. One menu option allows you to enter a record mode. Once selected, the Interceptor will return to normal scan mode, but will start recording the displayed data automatically when the throttle exceeds 60%. Approximately 60 seconds of data will be stored. Returning to the menu screen, you can choose to replay the stored data on the Interceptor display.
The gauge displays 2 parameters at a time, but can be programmed to cycle through up to 8 parameters during a user determined period of time. This way you can monitor several items without taking any other actions.
Has high intensity warning lights that can be set using a 1 or 2 parameter algorithm. P1, P1 or P2, P1 and P2. For example, trigger the lights when rpm exceeds 6000 rpm, or when trans temp exceeds 230 F and coolant exceeds 210 F, or when air fuel ratio is above 12.5 and throttle is above 75%. Due to the gauges extremely fast update rate, this light is very accurate and easy to set. Once you try it you'll find you can't live without it!
Another menu option offers the ability to swap the foreground and backround colors of the display (as pictured below). Using this feature, for example, the gauge with a black backround and blue characters (negative image) becomes a blue backround with black characters (positive image). Not only can this be visually appealing but beneficial in changing lighting conditions. Positive images are easier to read in bright sunlight, negative at night.
The Interceptor's scan rate can also be adjusted through a menu function.
DTC's (Diagnostic Trouble Codes) can be accessed and cleared via menu options.This essential feature will help the gauge to pay for itself the first time the check engine light comes on. Those that have modified their vehicle will find this very handy when a sensor, vacuum line, etc. has been inadvertently left disconnected, or something was just not put back together properly.
The two analog inputs can be configured through menu choices. A linear conversion can be entered so that an analog signal connected to the gauge can be read in appropriate units. These inputs are handy for pressure signals such as those from MAP and oil pressure sensors, analog outputs from Air/Fuel ratio kits, etc. These signal can then be read and recorded along side the other parameters obtained on the vehicle's bus.
The gauge has bi-directional controls allowing for manual control of the low and high speed fans, CASE relearn and ECU reset on GM vehicles, and on most Chrysler vehicles the transmission controller can be reset and Electronic Stability Program can also be completely turned off to improve track performance.
New optional relay output module allows you to control a 12v relay based on values of OBD2 or analog input data.
Last but not least, the Interceptor will measure 0-60 times, as well as 1/8 and 1/4 mile time and speeds. This is accomplished through a simple menu selection. This function is not available on the ISO based (older imports) due to slower bus speeds.
Installation in most cases is accomplished by simply plugging the supplied connector into the OBD2 port below the steering wheel. Literally plug-and-play! Some vehicles such as those requiring the ISOi version (older imports) require switched 12v power. The rear connector of the gauge has a provision for this so installation is still a snap!
Dual Interceptor Option: Two Interceptors can be purchased with a special splitter cable that allows both gauges to operate simultaneously. The second gauge of a dual set in most cases is simply another single gauge programmed to working in tandem. The exception is the SR dual set in which case the second gauge will show a smaller subset of parameters that the main gauge. This is due to limitations of the Chrysler PCM. Check the list of parameters and features for more details. This second gauge also will not have a performance timer.
Warranty
Aeroforce Technology warrants this product and its accessories against defects in material and workmanship for a period of 1 year from the date of purchase.
The Interceptor scan gauge is capable of displaying over 100 parameters, two at a time (8 using cyclic scan), at an adjustable rate of up to approximately 20 times per second. Not all are supported by every vehicle, so there is no guarantee that the Interceptor will display all of these on your particular car or truck. If the vehicle is broadcasting the parameter, the Interceptor will recognize this and make it available for display. A sample list is below...
RPM
MPH
Intake Air Temperature (post Intercooler)
Ambient Air Temperature (pre Intercooler)
Engine Coolant Temperature
Exhaust Gas Temperature (PCM Calculated)
Transmission Temp. (auto trans)
Manifold Pressure (vacuum/boost) displayed in PSI
Fuel Temperature
Battery Voltage
Battery Temp
Injector Pulse Width in msec.
Injector Duty Cycle (%)
Air Flow Rate into engine
Long Term Fuel Trim
Short Term Fuel Trim
O2 Sensor Voltage
Barometric Pressure
Ignition Advance
Base Spark
PCM Spark Adjust
Fuel Status (open/closed loop)
Wastegate Solenoid Duty Cycle (%)
Knock Retard
Knock Sensor Raw Voltage
Throttle Position Percentage
Throttle Position Sensor Raw Volts
Calculated Net Horsepower
Engine Load
Transmission Slip
Current Transmission Gear
Torque Delivered to Transmission
Torque Converter lockup status
Brake pressure
Brake Booster Travel
Steering Angle
Non-driven Wheel Speed
Lateral G's
Yaw
Fuel economy (instantaneous and average)
P-ratio - pressure ratio MAP/Barometer
2 user configurable analog inputs**
** 0-5v inputs can be configured to read the outputs from MAP sensors, Air/Fuel ratio kits, pressure or temperature sensors, etc. Raw voltage can be displayed or a conversion can be entered to read proper units.
Users will find that ability to log RPM vs other parameters at high speed such as ignition advance, boost, or knock retard invaluable with regards to tuning.
Use Promo Code of md5d
Single
https://rdpstore.com/p-499-aeroforce...ge-single.aspx
Duel Combo
https://rdpstore.com/p-10473-aerofor...el-gauges.aspx
For Super Specials Pm us here or give us a call on 440 358 5500 or 440 251 8571__________________
Old 04-04-2019, 01:54 PM
  #50
RDP Store
Supporting Vendor
RDP Store's Avatar
PM for Special Forum Member Deals
Old 04-05-2019, 02:09 PM
  #51
RDP Store
Supporting Vendor
RDP Store's Avatar
Weekend Super Specials Start Today at www.rdpstore.com
Old 04-07-2019, 11:59 AM
  #52
RDP Store
Supporting Vendor
RDP Store's Avatar
At RDP Store we Strive to do what the others Fail to do, We communicate with you our Customers Before During and After order, we stock a huge range of parts and if we dont have something in stock and have to drop ship or back order we will let you know immediately and see what you wish to do and keep you up to date, and we will not allow you our loyal customers to wait weeks and even months on your items as many of you have experienced with other vendors. Also as most of our Customer know we not only run the Business Phone lines from 7am to 6pm but we also offer Dynosteves Cell Number 440 251 8571 for Customers needing help or information after hours.
RDP Store Policy
Best Pricing
Best Service
Best Communication
Fast Replies to PM's and Phone Calls 7 Days a Week and and Past Business Hours
Free Shipping to the Lower 48 States
Cost Price Shipping anywhere else in the World
Price Matching
Technical and Tuning Support on the Products that we sell. (we not only sell performance parts but we install them and dyno tune them in house)
Fully Up to Date Online Store with Tracking Information
We Help with Tech Support for Customers even on items we didnt sell.
Thankyou for your Business and Continued Support of RDP Store and we look forward to helping and working with you all in the Future.Attached Images
Old 04-09-2019, 08:59 PM
  #53
RDP Store
Supporting Vendor
RDP Store's Avatar
Old 04-10-2019, 04:44 PM
  #54
RDP Store
Supporting Vendor
RDP Store's Avatar
Old 04-11-2019, 08:50 PM
  #55
RDP Store
Supporting Vendor
RDP Store's Avatar
Please give us a call with any questions on 440 358 5500
Old 04-13-2019, 09:36 PM
  #56
RDP Store
Supporting Vendor
RDP Store's Avatar
use promo code of md5d save now
Old 04-14-2019, 04:10 PM
  #57
RDP Store
Supporting Vendor
RDP Store's Avatar
Save this month with our blow out specials for forum members and remember we always ship for free to the lower 48 states and ship for cost any where else in the world
To AeroForce OBD2 Gauge Specials
Old 04-16-2019, 07:40 AM
  #58
RDP Store
Supporting Vendor
RDP Store's Avatar
We wont be beaten by any competitor and we also offer discounted installation rates as well
Old 04-17-2019, 07:52 PM
  #59
RDP Store
Supporting Vendor
RDP Store's Avatar
Thank you very much for all your enquirers.
Old 04-19-2019, 09:27 AM
  #60
RDP Store
Supporting Vendor
RDP Store's Avatar
Easter Specials Running from Today until Midnight Monday the 22nd, PM us for a Deal and if you have a Better Price on a Item we Stock we will Beat it and Ship for Free to the Lower 48 States and cost Price anywhere else in the World.
Quick Reply: AeroForce OBD2 Gauge Specials
