C7 Corvette Z06 APR Carbon Fiber Front Fender Vents from RPI Designs!!!
Platinum Supporting Vendor
C7 Corvette Z06 APR Carbon Fiber Front Fender Vents - $582.25
Website Link: https://www.rpidesigns.com/shop/item.aspx?itemid=5449
Give your C7 Corvette Z06 the very best treatment with these replacement carbon fiber front fender vents. APR Fender Vents help reduce high-pressure air that builds up in the wheel wells. Built using pre-preg. carbon fiber reinforced polymer (CFRP) composite materials for superior strength-to-weight ratio, APR Fender Vents add both function and "lightness" where it counts. These front fender vents are designed to simply replace your existing OEM GM plastic vents. Once you get these new Z06 Carbon Fiber vents installed, just transfer your Z06 badges from your old plastic pieces to these new carbon fiber pieces. These C7 Z06 front vendor vents are sold as a pair. Free ground shipping on these vents.
Fitment: 2015, 2016, 2017, 2018, 2019 C7 Z06 Corvette
__________________
APR has some of the hottest Carbon Fiber C7 products available! Here is a link to other C7 APR products we have available:
https://www.rpidesigns.com/shop/sear...&search=c7+apr
Check it out, you will not be disappointed!
