C7 Z06 or a Z51 for the Track?
Assuming the Z06 LT4 is going to be S/C was wondering what you guys would rather have for the track (road course). Would you rather have a Z51 (possibly modded) and keep N/A or go with Z06 and keep it stock?
I realize price may or course be a factor but lets assume for argument sake there is a similar price spread as C6 C6Z.
My experience with a modded Twin Turbo BMW at that track has been a PITA due to heat soak.
FI here in Phoenix would blow on the track after a couple of laps I would imagine.
V10LEE
No question the C6 ZR1 suffered from heat soak. Lets hope for the C7 Z06, if supercharged, GM has worked hard to prevent that. Its my opinion that is the main reason the C6 Z07 package turned lap times so close, or in somecases better, than the ZR1.
Received 3,791 Likes
"Ask Tadge" Producer
Folks have to get over this, "waaaaah ... heat soooooak!!!!" crying because it's actually not as significant a problem as people say it is. Can you cause a ZR1's engine to retard timing due to temps? Sure. If you track drive it heavily with the AC running on a 100º day. As it turns out: NA engines can and do suffer from heat soak as well.
Any close examination of the C7's aero and more specifically its engine cooling will make very clear that GM was planning on forced induction with this car, from the get-go. Unlike the C6, where it was shoe-horned in, the C7 has the right allowances for it as far as space and air flow are concerned.
I predict that any perceived "heat problems" with an FI engine will be put to rest.
I think GM will contiue to improve on the heat management with the C7 FI varient.
Last edited by racerns; 12-06-2013 at 10:16 AM. Reason: Well JVP beat me to it. That is what happens when you start a post and then let work get in the way of completing it. ;)
Heat soak had nothing to do with it; your opinion is invalid in this case. On tight tracks where the ZR1 wouldn't get its legs under it, the Z06 would barely beat it. On a track with any decent straights to it, the ZR1 would beat it down.
Sorry to ruffle the ZR1 feathers... bottom line is look at the best ring times on both cars. The Z07 is only 3.28 seconds behind the ZR1 on a very long high speed track. The ZR1 with 130+ hp and tq advantage, not to mention tighter gearing to boot, on that long of a track should have had a much larger advantage. What could have held the ZR1 back? Heat soak maybe?
I have drag raced both my previous C6Z06 and my buddies ZR1. The two cars where about 0.3-0.4 and 5 mph apart. Hot lap them and the mph on the ZR1 would drop much more dramaticly then the Z06. For the sack of the original posters question I would say that heat soak can be an issue.
I will speculate that the C6Z06 given the early ZR1 gearbox and 3.90 diff gearing would have matched or beaten the ZR1 Ring lap time.
The LS7, early ZR1 gearing (1 - 6 in the TR6070) and 3.90 diff would make the C7 Z06 the perfect storm for the road course.
You're not actually ruffling feathers, more posting without any first-hand knowledge of the tech at play.
Certainly not in a sub-8 minute lap it didn't. Heat soak had nothing to do with it. Mero's already said that he felt more "nimble" in the lighter Z06 and therefore more comfortable in it. And he also ran the Z06's test after the ZR1's, which gave him a "warm up" of sorts for the new aero and grip that both cars had available to them (ie: tires, carbon fiber trim, etc).
Drag racing aside (which has almost 0% to do with road course work), heat soak can be an issue. It can be an issue with non-FI'd cars too. Abuse either one of them without decent cooling, and you'll see both types of engines dial back timing.
A romp around a road course isn't going to cause that. You can argue with me all you want, but I have more than 3 years of DIRECT experience with the car on a road course. And summers in WV aren't necessarily... pleasant.
Jvp, I am not arguing with you. You seem convinced that your knowledge is unsurpassed in this area. That might be. I am merely presenting a different perspective based not just on heresy, but real word knowledge. Dragracing is not roadracing. But heat soak is heat soak.
We are both 14 year members of this forum. I am sure we both have a lot more Corvette knowledge then the avg member. I know I have spent a lot of time on here over the years.
