C7 Z06 picture thread...
#41
Do any of the variants look that much different?, Chevy isn't going to change that formula , the C7 is already a wide body the Z will have subtle changes here and there on the outside, but will perform like a beast with the lt4.
#47
I believe this sketch came from the initial patent designs when the C7 was first speculated. I believe this to be the new Z06....subtle in pic, but a whole different animal up close and personal.
#48
I am of the opinion that the wide body C6s look much more aggressive than the base C6. I also believe that while the C7 looks excellent even in base form, the ZO6 variant could and should look more aggressive. I want a little more than just a LT4 engine for my $30k+ price premium...otherwise, me and many others could simply buy a base car and add a blower for significantly less $$. Just my 2 cents...
#49
You can clearly see the different grill used here, as well as a high rise hood and different hood vents. The wheels are the hi performance design to what looks to be bigger disc brakes behind them. You can also see the large rear air vents at the diffuser behind the tire that was shown with keek's CAD pic. Notice the sideskirt and front splitter as well.
#50
#51
Received 2,054 Likes
Glad to see Sport Cups on it, should be a beast on track!
#52
Received 5,299 Likes
#53
And look at the grille compared to the sketch. I know the sketch is a profile shot, but look at the unique openings at the side of the grille... they match.
This is the Z06 and that is it's grille. The front fender vent and wheels already match up perfectly.
#54
Clearly it is the ZO6.
I was hoping that they would change the side fender vent, but it appears that only the black plastic fender insert got larger (not the vent itself). We can't judge the car based on this picture but I am not seeing much of a difference at all really.
#55
#57
#59
I'm guessing it will look better in the flesh tho.
