2015 Corvette Z06 Performance Numbers
The ZR1 does not run into any heat issues until you start running in 95 plus degree weather on the road course.
As for the original question, if it is available with an A8 then it'll be quicker in the 1/4 than the ZR1 if not then it won't be. On the road course it will be marginally faster but still pretty close unless they offer a true track only stripper type option.
That is a photoshopped C6, has no resemblance to a C7, at all so I hope you aren't betting on that design to much....., oh god please make time go by fast so the unveil will put some of these posts to rest! but then again! it will create more! people will find something to complain about the z06 is going to be awesome but it's not like GM is going to reinvent the wheel , it will have the same improvement the prior models had except it will be the current best performing vette that has been made to date, passing all the previous C6 performance variant corvettes.... That is until the C8 performance variant is introduced, and the cycle will start all over again.
The only FI machine I have that I haven't heat soaked is my RCC ultra plenum intercooler on my turbo busa, but that isn't fair because it get so much open air. GM skimped on the intercooler for the previous FI vette , have you taken your intercooler apart to see crumbled pieces of metal where the heat hits the fins?, if I was planning on buying another C6ZR to keep the 1st thing I would do was upgrade the bars, I believe this is why the C7 Z is switching to a centri, there is more to work with when it comes to cooling, which will allow them to run more timing and boost.
Not true, I had heat soak problems after 3-4 runs in 80 degree heat, heat soak is just a problem with all FI cars more so with PD superchargers, I have another FI car that has two air to water intercoolers run in series along with meth and although it takes much longer to heat soak at some point it does about 8 runs, point is the all have heat soak.
Thanks for adding some sanity to this thread. Your observations match mine. Basically, if you're using an air to air intercooler, and it is of sufficient size to be properly matched to the power demands of the application, you may avoid heat soak issues. If you're running any sort of water-air intercooler, it's going to heat soak - simply a matter of time. Furthermore, if you do end up heat soaking an air-air intercooler, it tends to recover much more quickly as compared to air-water.
As to the individual talking about lap times on the ring : yes, the ZR1 is very fast around the ring - it is amazing! But that doesn't mean it doesn't suffer from power losses due to heat soak! It's just really fast DESPITE these losses. Why is it that the feeble minds on this forum insist that someone is "hating" when a fact is put forward that runs contrary to their opinion? Go drive a ZR1 and it will be obvious.
Received 3,787 Likes
"Ask Tadge" Producer
I do. Quite consistently on the race course. Have done so for over 3 years.
ALL engines suffer from heat soak. It doesn't matter how they're aspirated. What does matter is when it hits and how brutally. The ZR1 in its current form will suffer from timing retardation to protect itself when run hard in hot (95º+) temps for prolonged periods. A simple 20-minute session isn't going to be enough to do it.
Anyone that says they've seen "heat soak" at 80º is full of crap. Even after a few sessions. That is unless they were driving on the track with the A/C on; I've done that as a test and sure enough it does get the engine hot.
Like I said these are just educated guesses and I could be totally wrong.
I'm no corvette expert by any means, but I've rr both a turbo setup, SC setup and NA and certainly found heat issues with all 3. The NA seemed to be the least affected and easiest to address, but running in AZ at 90 degree temps ALL of them had issues.
However, just for track days I'd take a stripped down NA 7.0 version of the Z with 100lb weight reduction and a 100hp jump in power along with some R comps and there wouldn't be many cars you'd be seeing tailights of.
And being new to this thing called corvette passion, it's amazing how quickly some guys get their motors revved. Yowsa.
No doubt it will be the fastest Corvette ever! 620HP and 650# torque. That is insane!
Op was close. Well, sort of.
This is a screen shot from Google that I just took this morning. Apparently, google captured the metadata from the Chevrolet page. I don't know how long it will be before GM pulls that down but if you google "2015 Chevrolet Z06 Supercar", it's right there for all to see.
#33
#34
And as I wrote in another post: it's incorrect information. Those aren't the numbers we're going to hear from GM next week. And the numbers we do hear will be of the, "At least..." variety.
Rest assured: no final testing, tuning, validation, verification, etc has been done with the car yet. They've still got quite a bit of work ahead of them. What we'll see at NAIAS next week is just like what we saw last January: "Here's what the car will look like and here are some of the things on it..." No precise numbers will be disclosed because GM doesn't have them yet.
#35
#36
Either way, it's pretty safe to say that those number will be very close to actual numbers if in fact they are not spot on.
#39
#40
Banned Scam/Spammer
This stuff is simply amazing. State of the art sports cars right off the showroom floor with this kind of power! Really cool stuff. Hope it sells. Damn, I can remember back in the late 80s when I thought my '87, 4+3 was a screamer. We would have never dreamed any of this would be possible.
