Leg room in Z06
#41
Thanks man! Will just have to do the adjustment trick...Should be fine!
#43
I just did this. Why the heck did I wait so long? I'm not sure exactly how much extra room I gained but it is noticeable and makes a huge difference for me given I'm 6'4" tall. Have to check and see if the passenger seat has the same thing as that's even worse (not that I ride as a passenger too much).
#44
I bought my C7 Z06 "new used" with a few hundred miles. The owner traded it on a C6 Z06 because he was a big guy and fit in the C6 better. Little strange but...
#45
#46
Don't rain on my parade. It seems a lot better so I'm sticking with it.
#47
In that case the mod might have made the seat go lower, but either way, there is a difference in leg room for sure and my arm is also further away from the wheel which was the first thing I noticed after the mod. I have a way that I rest my arm against the door panel and my elbow isn't as bent now...
#48
#51
Just an update. I did this mod to my new '15 Z06 (the pic I posted earlier was from my '14 Stingray), and it also made a noticeable difference. I have the competition seats...
A huge thanks to Carnut52 in this thread for the tip. Those extra couple of inches really made the leg room and longer arm reach perfect for me.
#52
Also, for those who are doing this mod, remember to undo it when taking the car in or you could have a shop monkey blow your seat motor.
#54
which seat
Unplug the seat limiter. Pull up the carpet behind the drivers seat. There is a plastic stripe that has two white wires at the top. Follow those toward the passenger side and there is a small black harness. Unplug that and you will have 2" of leg room. Did mine yesterday
So is the plug behind the drivers seat or the passenger seat, I have a 2015
#55
Get the transparent roof and you gain a couple of inches of headroom.
#56
I had Issues
I'm 6'4" 235lbs and I could not fit into the Z06. I suspect that it may have been due to the sportier seats. I ended getting the Stingray because I could actually fit into it better. I recorded a video of how I gain a bit more legroom. Now that I figured this out, I'm wishing I had gotten the Z06.
#57
need more leg room
#58
seats
https://www.youtube.com/watch?v=8DDwwtWdnsY
I had the same experience with the Z07 package in my 2015, it was just too rough. The Z07 really makes it more for the track than daily driving.
JMHO
BTW I track my car some and getting out with my helmet on takes a little for thought. It's a bit tight, but doable. We have to pass a 12 sec fire exit drill for the Optima Series. In full fire gear.
#59
Those seats are the GT seats and they are available in the Z06. When I bought a 2015 M7 Z06 it had the Comp Seats and I didn't care for them. Sold the car and ordered a 2016 A8 with the GT seats, all is well. I'm 6'2" and approx. 275. One addition is I CAN'T fit in the pass side. I have to drive or I can't ride in it. There is an appreciable difference in the leg room of both sides.
JMHO
JMHO
#60
Check out my video below. It may prevent you from having to disconnect the seat limiter. I was also thinking of doing that, but I heard that you don't really gain much. My video shows how to potentially get more room for your left leg. Not much I can tell you about the right leg.
