X-pipe options?
Old Jan 15, 2015 | 12:07 PM
jdmdohcpower's Avatar
jdmdohcpower
Default X-pipe options?
The car sounds great stock, just want to give it a bit more and I think an x-pipe would do that. Its a cheap solution without have to tune and void warranty I believe. Any options?
Old Jan 15, 2015 | 11:36 PM
JMB's Avatar
JMB
Active Streak: 90 Days
Do you own a Z06? It already has an x-pipe from the factory!
Old Jan 16, 2015 | 09:39 AM
Kracka's Avatar
Kracka
I think he's wanting to upgrade his stock X-pipe to an aftermarket to add a little more bark to his exhaust.
Old Jan 16, 2015 | 07:19 PM
JMB's Avatar
JMB
This doesn't make much sense either because the current design of the GM x-pipe is about as good as it gets and changing it from one mfgr to another isn't going to make a dramatic sound difference by changing x-pipes (if any sound difference at all!)!
Old Jan 16, 2015 | 07:38 PM
jdmdohcpower
Of course it will and I do own one. There are cats in the x-pipe. When you remove the aft cats and replace with an "off-road" or catless x-pipe, sound will be significantly increased. With the stock NPP already sounding so good. A catless X will as the above poster said, give a more bark. It's a really inexpensive way to increase the sound
Old Jan 16, 2015 | 08:13 PM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
Are you going to be able to remove the cats without programming out the rear O2 sensors?
Old Jan 16, 2015 | 09:02 PM
jdmdohcpower
Not sure, most cars you can remove the rear cats as they are past the sensors, some you can't. My friend was able to do it on his cts-v without programing I'm assuming the pipe manufactures will have the answer. I haven't jacked it up yet to see if secondary O2 sensors were before the rear cats
Old Jan 16, 2015 | 09:55 PM
JMB's Avatar
JMB
Your post didn't ask about removing and replacing the CAT's....it only asked about replacing the x-pipe! I'm only responding to what you asked
And I agree...I am looking at this option too and since I didn't notice any rear 02 sensors when I had my car up on the hoist there shouldn't be any issue removing them.
It seems like the Corsa double x may be the ticket due to no drone https://www.corvetteforum.com/forums...-vs-corsa.html
Old Jan 16, 2015 | 09:59 PM
jdmdohcpower
Why else would you replace the x-pipe?
Also I don't believe the c7 is interchangeable with the Z06. I was asking if anyone was aware of a z06 specific part
Old Jan 16, 2015 | 10:07 PM
2006Z06's Avatar
2006Z06
Removing cats will probably trigger a CEL which can be cancelled out with a tune, but of course that will potentially void any warranty. Also, removing cats will make the exhaust smell really bad. It will make the exhaust louder, but usually not better, especially if the original exhaust was already tuned for sound.
Old Jan 16, 2015 | 10:14 PM
JMB's Avatar
JMB
Call Corsa on this...I'd be willing to believe that these parts of the exhaust system are identical between the LT1 & LT4!
Not true, read the link I inserted...no one has thrown codes....there are no sensors to monitor this!
Not true.....my LS7 Monte SS has no CAT's and there is zero odor! In the case of the C7....even if this was true (and it's not) you still have two CAT's on the car!
Old Jan 16, 2015 | 10:54 PM
jdmdohcpower
The rear cats are only used to burn what the main cats didn't get and since you will still have the main cats you won't notice the smell and it will in my thoughts make the car sound great. My buddy's cts sounds awesome and and the xpipe is all he has as far as exhaust. Also I've had a few cars that i did this too. Never regretted it. Also spoke to corsa and they said they are developing one so I'm not sure if that means the current one won't fit but on Monday I'll call and ask. I'm pretty sure the O2 is in front of the xpipe so it won't throw a code. Can anyone chime in about the xpipe from C7 swapping over? I would really doubt it's identical between both platforms
Old Jan 19, 2015 | 09:43 PM
JMB's Avatar
JMB
Oh people just hate it when I'm right....just like saying that the Seahawks would spank the Packers
Here's your answer from the "best expert":
Old Jan 19, 2015 | 09:56 PM
jdmdohcpower
That's great news. I believe corsa makes one I'm going to call them and confirm
Old Feb 17, 2015 | 12:25 PM
jdmdohcpower
anyone know the size of the stock pipe. Borla makes a 2.75 and corsa is 3. I think it makes more sense to stay as close to the stock size as possible to prevent the gas from expanding.
Old Feb 17, 2015 | 02:16 PM
Kracka's Avatar
Kracka
Stock = 2.75"
Here is a write-up I did comparing stock vs. Borla vs. Corsa:
Old Feb 17, 2015 | 03:42 PM
Bmbarney's Avatar
Bmbarney
Corsa Xpipe is around $550. From everyone I have talked to ... vendors and from other forum members - there have been no codes received. Im about ready to order but along with the Corsa Sport mufflers.
Im thinking its 14768 for the sport mufflers
And not sure .... if its the same X Pipe (no cats) it may be 14761
To X-pipe options?
Old Feb 17, 2015 | 03:53 PM
Kracka's Avatar
Kracka
No codes and compatible with the stock tune on the LT1, I'd assume the same for LT4.
Old Feb 17, 2015 | 06:20 PM
jdmdohcpower
No x pipe will throw a code because there are no sensors there. The x is past all the sensors so no worries. Corsa' is a 3 inch double x. My concern is that the gas coming in can expand and then will have to contract again at the 2.75 muffler inlets creating back pressure? I've also read that it gives a more exotic sound rather than muscle. If the stock size is 2.75 it may be best to go with borla's since it's also 2.75. With a 3 in aftermarket exhaust you would want corsa but I would rather keep the same size all the way and prefer the muscle sound
Is my thought process a good one or am I understanding this wrong?
Old Feb 17, 2015 | 07:25 PM
JMB's Avatar
JMB
Since you asked....WRONG
The Corsa X may need a reducer to fit, not sure but that shouldn't create an issue.
What you have to remember (and most people don't so don't feel bad) is that exhaust gas cools as it flows through your exhaust system....this also causes the exhaust gas to lose velocity. It is very common to have a size smaller tailpipe for this very reason. For example, on my 700+ RWHP NA LS7 I use 4" exhaust and 3-1/2" tailpipes with no loss of power over open headers!
As for the "muscle" sound...the double X will idle very nicely and under throttle, the X creates an intoxicating roar that is 2nd to none under WOT, just try a pre-2012 ZR1 or 2011 Z06!
