Official C7 Road Course Lap Times...Submit Your Times Here!
#421
-Track - Thunderhill
-Layout - 5 mile
-Transmission Type - M7
-Driving Mode/Settings - Sport
-Aero Package/Option Package/Setup - Stage 1 Aero
-Tires - Super Sports
-Conditions/Temp - Approx 110 on the track.
-Overheat warning/failure if any - car overheated a couple times
-Best Time of the day/Session achieved - 3.24.71
-Modifications, if any - AFE Stage 2 CAI
-Notes - It was hot, really hot. Was trying not to go 100% as the car wasn’t taking it well in the heat.
Youtube Vid link if available -
-Layout - 5 mile
#422
-Layout - 5 mile
-Layout - 5 mile
Cheers.
#423
Good to chat with you and Mike while we were up there. I've been tracking the car for a year and a half and got the handle on some issues. Let me know if you have any Q's. I recommend the GM secondary radiator and the PS cooling scoop. I think you'll run fine with those two. Mike just got them and we both ran very well at Thunderhill last weekend.
Cheers.
Cheers.
#424
https://www.corvetteforum.com/forums...ails-here.html
Haven't tried water wetter. I read Redline's white paper on it and I wasn't impressed, ~ 1* cooling improvement if that. I run 80% water and 20% stock coolant. Just poured some out and filled back up with distilled water. I would run water wetter on a car that runs 100% water but I wouldn't mix it with the coolant. Some people reported sludge over time from mixing with the coolant and I didn't find that worthwhile for nearly 0 documented improvement in coolant temps.
#425
-Track Thunderhill West (2 mile)
-Layout (if more than 1)
-Transmission Type M7
-Driving Mode/Settings Track, no TC, no AH
-Aero Package/Option Package/Setup Z07 set to high
-Tires Cup 2
-Conditions/Temp 95* ambient
-Overheat warning/failure if any None
-Best Time of the day/Session achieved 1:23.97
GM second radiator
GM powersteering cooling duct
C&R racing radiator
80/20 water/coolant mix
Girodisc iron rotor brakes replacing CCBs
-Notes (issues experienced, failures, passenger, anything pertinent that you feel affected your time, etc)
200 lbs extra weight due to passenger, stereo, iron rotors, (+50lbs rotational mass)
Cup 2 tires delaminating heavily and building 16 psi
-Tires Cup 2
GM second radiator
C&R racing radiator
#426
-Track Thunderhill Raceway 5 mile with 2 bypasses
-Layout (if more than 1) 5 mile with 2 bypasses
-Tires Cup 2
-Conditions/Temp 92* ambient
-Overheat warning/failure if any Overheated engine in about 10 minutes
-Best Time of the day/Session achieved 3:16.63
GM second radiator
C&R racing radiator
The car ran really hot and overheated, lost 8 mph on the straight, down from 140 mph to 132 mph.
In the lap where the car overheated you can see the coolant reaching 262*:
-Tires Cup 2
GM second radiator
C&R racing radiator
#429
Premium Supporting Vendor
Driver: Jason Harding
-Champion Motor Speedway @ M1 Concourse
-Full track
-M7
-Track mode/PDR Sport 1
-Stage 3 Aero Z07
-MPSC
-Sunny/80-83F/humid
-no overheat warning
-Best session 1pm
-Katech Stage 3 engine package, DSC Sport suspension controller
-Issue - forgot to set up overlay on the PDR after reprogramming attempt
Fastest lap at 2:45
-Full track
-M7
-Stage 3 Aero Z07
-MPSC
-Sunny/80-83F/humid
-Best session 1pm
Fastest lap at 2:45
#433
#435
SBC_and_a_stick (07-25-2016)
#437
I have a great idea guys. I just need to figure out specifically how to implement it so that it is as user friendly as possible. I will work on it for the next few days just give me a little bit of time to write up a draft of how I can make it work. I am going to change it up a bit. Time to dust off my computer science degree.
Before I do any of the work I will bounce it off of you guys to get your opinions. But, I think you will like the idea.
#438
#439
Sounds good. I wouldn't have the time to keep up with it.
#440
EVERYONE SINCE THE BAN HAS BEEN UPDATED TO NEW THREAD POSTED BELOW, POST AT THAT THREAD FROM NOW ON.
I have been in contact with the OP on another forum extensively. I will take over management of the second thread. RC000E maintained all the code structure so, the new thread will link here for whatever was posted, and all updates should be posted in the new thread from this date forward.
Everything posted in THIS thread, has been updated and added to the NEW thread ONLY, so begin to post there, and carry forward from that thread. All hyperlinks are correct and if selected, will open a window into this thread so vid/details/data can be viewed
Problem solved.
Official C7 Road Course thread Vers. 2
Problem solved.
