Official C7 Road Course Lap Times...Submit Your Times Here!
#101
How do you want to handle updates to previous posts? I originally documented a 2:06.0 here and then had a 2:04.8 documented here:
https://www.corvetteforum.com/forums...-part-2-a.html
Some other folks have reported 2:04's and a 2:02 as well but I didn't see PDR data posted.
#102
MSR Cresson fast laps.
-Track: Motorsport Ranch Cresson
-Layout (if more than 1) - 1.7 mi track in CCW direction
-Transmission Type - M7
-Driving Mode/Settings - Track Mode - Race Setting
-Aero Package/Option Package/Setup - Stage 3 Aero, non Z07
-Tires - MPSS
-Conditions/Temp - Cloudy, little wind, Temp Mid 80s
-Overheat warning/failure if any - No engine overheats, but power steering issues right before cool down lap
-Best Time of the day/Session achieved - 1:22.6
-Modifications, if any -- Stainless steel brake lines, Forgeline wheels, Harness bar and 6 point restraint.
-Notes (issues experienced, failures, passenger, anything pertinent that you feel affected your time, etc) - No other issues
Note: my previous submission was for the 1.3 mi track in CCW direction and here is that link:
-Tires - MPSS
#103
If you ran an updated time, post all you have to support it, etc.
Does that answer your question, if I understood it correctly?
As stated in the beginning, disputes can be made if there is no data support or vid evidence, and I can ask the driver to validate or change the color. To this point, we are still trying to get enough interest in this thread to have a valid gathering for now...lol.
Look forward to any other track days or contributions you have!
#104
-Track: New Jersey Motorsport Park - Lightning
-Driving Mode/Settings - Track Mode - No PTM
-Aero Package/Option Package/Setup - Stage 2 Aero
-Tires - MPSS
-Conditions/Temp - Cloudy, light rain, wind, Temp Mid 70-80s
-Overheat warning/failure if any - No issues
-Best Time of the day/Session achieved - 1:18.X (calculated by video timer
-Modifications, if any -- None
-Notes (issues experienced, failures, passenger, anything pertinent that you feel affected your time, etc) - Passenger, 3 point belts. White Run group, slower traffic.
-Tires - MPSS
#106
Track: National Corvette Museum Motorsports Park
-Layout (if more than 1) - 3.15 Road Course (Maximum)
-Driving Mode/Settings - Track Mode - Sport 2
-Aero Package/Option Package/Setup - Stage 3 Aero, Z07
-Tires - MPSS
-Conditions/Temp - Sun/ Cloud, Temp max 74
-Overheat warning/failure if any - None
-Best Time of the day/Session achieved - 2:32
-Notes (issues experienced, failures, passenger, anything pertinent that you feel affected your time, etc) - Traffic on every lap
-Tires - MPSS
#108
Let's get some non-Z06 in here.
2015 C7 Z51 + MSRC
-Layout - 1.7 mi track in CCW direction
-Tires - MPSS
-Conditions/Temp - HOT Sunny, no wind, Temp 95-100
-Overheat warning/failure if any - No engine overheats, transmission was high but I did not have to stop. Others did.
-Best Time of the day/Session achieved - 1:28.0
-Modifications - none, did not prep the car in any way for this event, just a full tank of gas.
-Notes (issues experienced, failures, passenger, anything pertinent that you feel affected your time, etc) - I think I could have ran a 1:25, this was my first time ever at a track and racing this car. (i've autocrossed my previous cars). I wasn't pushing it to the limit and was also blocked by someone slower in most laps.
Here is one of the event's videos, the speedo was inaccurate. I did not tape my fastest lap.
2015 C7 Z51 + MSRC
-Tires - MPSS
#109
That's not bad at all for a first time. Love seeing some Z51's in here. N/A on the track certainly has a place...I wanna see some guys do work in the Z51.
#110
-Track: Autobahn Country Club (Joliet, IL)
-Layout (if more than 1): South Track
-Transmission Type: A8
-Driving Mode/Settings: Track->PTM->Race
-Aero Package/Option Package/Setup: Stage 2
-Tires: Michelin PSS, started with cold pressures of 27lbs all around
-Conditions/Temp: 80 degrees, hazy sunshine
-Overheat warning/failure if any: "Overheating - idle engine" message after 14 minutes of running on track
-Best Time of the day/Session achieved: 1:35.11
-Modifications, if any: radiator flushed by dealer and refilled with 80% water/20% coolant, 93 octane gas, 15w50 oil
-Notes (issues experienced, failures, passenger, anything pertinent that you feel affected your time, etc): running in manual mode and shifting around 6000 rpm, second session of this particular day, previous session ended with overheating power steering unit after 18 minutes of running on track, have a Ron Davis radiator on order
https://vimeo.com/132656968
#111
-Track: Summit Point
-Layout (if more than 1): Main Track
-Transmission Type: M7
-Driving Mode/Settings: Track->PTM->Sport 1
-Tires: Michelin Pilot Sport Cup 2, started with cold pressures of 26F/27R
-Conditions/Temp: 70's to low 80's
-Best Time of the day/Session achieved: 1:17.4
-Modifications, if any: Standard track prep (15W50, Castrol SRF, alignment). Ferodo DS 1.11 brake pads
-Notes (issues experienced, failures, passenger, anything pertinent that you feel affected your time, etc): Car ran great. Burned through 10 gallons of fuel each 30 minute session. I had to cut the day an hour short due to wearing out the pads after 5 days but they worked well right down to the end.
#113
1:17.4 on Summit Point Main in a 2015 Corvette Z06 - YouTube
#115
I just realized that I never posted my updated best at VIR in this thread.
-Track - VIR
-Layout (if more than 1) - Full
-Transmission Type - M7-Driving Mode/Settings - Track Mode Sport 1
-Aero Package/Option Package/Setup - Stage 2 aero, Z06 (steel rotors)
-Tires - Michelin Pilot Sport Cup 2
-Conditions/Temp - mid-80's to lower 90's.
-Overheat warning/failure if any - none
-Best Time of the day/Session achieved - 2:04.8
-Modifications, if any - Ferodo DS 1.11 brake pads
-Notes (issues experienced, failures, passenger, anything pertinent that you feel affected your time, etc) - none
Mac fluid temps
Coolant: 228F
Oil: 271F
Trans: 225F
Video: https://vimeo.com/130215007
-Track - VIR
Mac fluid temps
Coolant: 228F
Oil: 271F
Trans: 225F
#117
MSR Cresson CCW
-Track - MSR Cresson,TX
-Layout (if more than 1) - 1.7 CCW
-Transmission Type - A*-Driving Mode/Settings - Track Race
-Tires - Hoosiers R7 335/19, 295/19
-Best Time of the day/Session achieved - 1:20:79
-Modifications, if any - Carbotech xp10 80/20 water /dexcool
-Notes_ Was slowed a bit by traffic
#118
Scraping the splitter.
#120
