Official C7 Road Course Lap Times...Submit Your Times Here!
#121
-Track - Memphis International Raceway (MIR)
-Layout (if more than 1) - 1.8miles
-Transmission Type - M7 in Track SP1
-Aero Package/Option Package/Setup - Z07 (wicker lowered)
-Tires - OEM size PSS (removed the cup 2's)
-Conditions/Temp - 92-99 Degrees
-Overheat warning/failure if any - none
-Best Time of the day/Session achieved - 1:14.93
-Modifications, if any - Stock
-Notes:
Did not overheat. Was surprised that I did not get higher although I took every 3rd lap a bit easy on the straightway. My hotest temp was in the morning at 92 degrees. The temp was 268.
After the first session I removed the rubber liner by the top of the hood.
Will have to post video later, still at the hotel.
-Notes:
#123
-Track: Blackhawk Farms Raceway, South Beloit, IL
-Layout (if more than 1): Full (std)
-Transmission Type: Manual, 7 Speed (Z51)
-Driving Mode/Settings: Track, Sport 1
-Aero Package/Option Package/Setup: N/A (Z51_
-Tires: Stock Michelin Pilot SS
-Conditions/Temp: Mid 70's, sunny
-Overheat warning/failure if any: None.
-Best Time of the day/Session achieved: 1:19.85
-Modifications, if any: DBA front rotors, Carbotech XP10/8, DOT4 brake fluid, track set up per GM spec
-Notes (issues experienced, failures, passenger, anything pertinent that you feel affected your time, etc): Very worn tires (replaced two days later) = lots of tire squealing! Still, almost 1/2 sec faster than last year on fresh tires. Visited Spring Mountain in between.
OP: all my runs are on the stock MP SS tires (Z51), so you can update my other times, please. Thanks.
#125
Track - VIR Full
Trans - Auto
Mode - Track, Active 1
Z06/Z07 - stage 3 aero [first time on track with car]
Tires - Pilot Cup 2
Alignment - Street [dealer could not do track!]
Ambient temp - high 80's-low 90's, very humid
Issues - Ran full auto [no paddle shift] day 1 and never could run more than 20 minutes due to oil overheating warning; Day 2 paddle shifted [poorly as can be seen coming out of 1 and oak tree in 5th gear] but temps stayed below 290
Ran 2:06.62
Video: https://vimeo.com/133657345
Trans - Auto
Tires - Pilot Cup 2
Ran 2:06.62
#126
PittRace South Track
Track - PittRace South Track
Trans - M7
Mode - Sport - all nannies active
Car - 15 ZO6 Coupe Level 1 Aero
Tires - Mich Pilot Sport Cup 2
Alignment - Track
Conditions - New track (5th day of use), Mid 80's, high humidity, no curbing, lots of dirt and runoff from recent rains
Overheat / Issues - Pretty sure I ran some old gas - had some issues on track that cleared up once I put in some 100 octane gas
Best Time - 1:02.2
Modifications - Haltech CAI, Carbotech pads front & rear, Mobil 1 5 /30 Oil, Torque Brake Fluid
My excuses: I was gun shy from a recent off, so I left settings on Sport and went only about 80%. Ran low on gas and put about 3 gallons of 93 octane fuel that was around 4 weeks old. Track was still damp (at least in my mind) from very light rain during previous session
Session #2 Laps
Tires Session #2
Vehicle Health Session #2
Trans - M7
Alignment - Track
Best Time - 1:02.2
Session #2 Laps
Tires Session #2
#127
^ South track....I love it! Finally! Of course it finally gets built after I move...lol. I'll get my M3 up there next year...FO SHO!
All updated
All updated
#128
-Track: Autobahn Country Club
-Layout (if more than 1): South
-Transmission Type: M7
-Driving Mode/Settings: Track->PTM->Sport 1
-Aero Package/Option Package/Setup: Stage 2
-Tires: Michelin Pilot Sport Cup 2, started with cold pressures of 26F/27R
-Conditions/Temp: mid 80's
-Best Time of the day/Session achieved: 1:33.39
-Modifications, if any: Standard track prep (15W50, Castrol SRF, alignment). Ferodo DS 1.11 brake pads
-Notes (issues experienced, failures, passenger, anything pertinent that you feel affected your time, etc): I had a passenger in the car so I cut the session short.
Max fluid temps:
Water: 237
Oil: 277
Trans: 252
Max fluid temps:
Water: 237
Oil: 277
Trans: 252
#129
-Track: Summit Point
-Layout (if more than 1): Shenandoah Circuit
-Tires: Michelin Pilot Super Sports, started with cold pressures of 27F/27R
-Conditions/Temp: mid to upper 80's
-Best Time of the day/Session achieved: 1:37.74
-Notes (issues experienced, failures, passenger, anything pertinent that you feel affected your time, etc): Car ran great and we were running hour long sessions plus a 90 minute at the end of each day. I missed the last session with corded front tires. This is from earlier that day so very worn Super Sports.
#130
Well, at least Poor-Sha is out there tracking this thing since no one else is.
Jk...I'm sure there are somewhere.
#131
#132
Maybe if we had more Porsche types, then we'd actually see these cars on tracks. Love the Corvette...can't say I love the demographics...
#134
Official C7 Z06/7 Road Course Lap Times...Submit Your Times Here!
#135
i sure a lot of older porsches.. i see a lot of corvettes mostly c6 or c5 but c7 are showing up slowly.. there is like 4 of us regulars around me that i know of
#136
If Corvette keeps focused on the driving experience and not too heavily derailed with CTS-V's and open air experiences, the evolution of Corvette as a true global performance benchmark is possible. Can't say I'm 100% thrilled with C7Z overall but...it got them the numbers they need for pamphlets I suppose.
#137
Road America - Kink OPEN
-Track: Road America
-Layout (if more than 1): Kink open (no bend)
-Driving Mode/Settings: PTM Sport 1
-Aero Package/Option Package/Setup: No aero, track specs per GM prep sheet
-Tires: PSS
-Conditions/Temp: Warm, 85 degrees
-Best Time of the day/Session achieved: 2:37.8
-Modifications, if any: Race Brake front rotors, Carbotech pads (12/8), Motul 5.1
-Notes (issues experienced, failures, passenger, anything pertinent that you feel affected your time, etc): Rotors were cracked by the end of the day
-Tires: PSS
#138
Gingerman Raceway
-Track: Gingerman Raceway, South Haven, MI
-Layout (if more than 1): Using turn 10B (extended track)
-Tires: PSS
-Overheat warning/failure if any: Transmission started getting over 290 degrees by the end of the day, but no warnings.
-Best Time of the day/Session achieved: 1:44.43
-Modifications, if any: DBA front rotors, Carbotech pads (10/8), ATE 200
-Notes (issues experienced, failures, passenger, anything pertinent that you feel affected your time, etc): Took my first four-wheel off adventure on this video!
-Tires: PSS
#139
Miller Time Wisconsin 🍺
Location: The only thing we have to beer is beer itself 🍺
Received 1,440 Likes
2018 C7 of Year Winner
2017 C7 of Year Finalist
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22
I was there the same weekend. I'd say a 2:37.8 is pretty good for a stock C7. I was there with my stock C6 GS and best time was 2:42, with 30 less HP
There was a Shark Gray C7 Z06 in the fast group running slower times than us, but I chalked it up to maybe he didnt want to go ***** out 10/10ths with his new $90,000 sports car.
#140
Do you have any video of your time at RA? I was in the 2nd highest run group there; would love to see some of your driving, too.
