***Worlds Highest HP C7 Z06 743rwhp/794rwtq***
Supporting Vendor
Here ya go guys, This will be the LMR stage II package.
This is the:
-First C7 Z06 to make over 700rwhp
-Highest HP C7 Z06 on the planet
Still Retains Factory 1.7L Supercharger with stock Upper Pulley and our Prototype Lower SFI Approved Over Drive Harmonic Balancer Installed.
Check out that Torque!
This is the:
__________________
Worlds Quickest C8 Corvette 8.83@160MPH
FIRST C7 Corvette in the 7's & 9's
2019 ZR1 LT5 8.874 @ 155
Current C7 World Record Holder 7.55 @ 184 MPH
Quickest and Fastest GEN5 LT Powered Vehicle
LMR1200HP Supercharged C7 8.84 @ 160
LMR1200HP Twin Turbo C7 9.35@155mph-2014
2 TIME OUTLAW DRAG RADIAL LSX CHAMPION 2008/2010
9.47 ZR1 Corvette-2009
LATE MODEL RACECRAFT
713-466-9900
LateModelRacecraft.com
Too many PMs, please call or email instead, thanks!
713-466-9900
Let me be the first to say congrats!!!
How hard is the blower spinning now?? Gues the cfm rating if the blower is quite a bit higher than 1075cfm. Still stock cam n heads??
Nicely done guys
Nicely done guys
I got goosebumps!
Holy frickin' smokes!!! Congrat's LMR for being the first to break 700 RWHP and pushing the envelope, this is just fantastic given the short R&D window that you guys have had with this car.....just WOW, truly World Class!
Now, for come constructive feedback....WTF is up with 480p video...if this isn't ghetto I don't know what is Secondly....do I have to install the two water jugs in my trunk with this package? How much HP will I lose if I don't
Again, nicely done guys, you ROCK As mentioned above, please let us know all of what you have done
You said 750 hp in an earlier post. Right on with the estimate.
Any nitrous?
If it is the same car they LMR previously posted on I think it is the stock cam. The boost was quite a bit higher than stock as I recall.
You can tell by the idle that's not a stock cam, what's the driveability like?
Scraping the splitter.
I am guessing this car has a slightly more aggressive cam that also increases fueling and mild bolt-ons (headers, intake, etc.) similar to their second level ZR1 package.
S.
Supporting Vendor
Our Stage 2 Kit consists of the following:
LMR Cold Air Induction
American Racing stainless steel headers with high flow cats
NGK Spark Plugs
MSD 8.5mm Spark Plug Wires
160* Thermostat with Billet Housing
LMR (Overdrive) Harmonic Balancer
Gates Belt
LT4 Cam Package
-Tool Steel Custom Cam
-Double Valve Spring kit(Retainers, locaters, keepers, and seals
-Pushrods
-Cam Phaser Kit
Crank Bolt
Fluids
-Oil Change
-Coolant
Shop Supplies
Badging
Professionally Installed
Custom Dyno Tune
FIRST C7 Corvette in the 9's
LMR1200HP Twin Turbo C7 Package-9.35@155mph
2 TIME OUTLAW DRAG RADIAL LSX SHOOTOUT CHAMPION 2008/2010
9.47 ZR1 Corvette
FIRST 2010 CAMARO in the 9's
HOME OF THE FASTEST LSx'S IN THE WORLD!!
Late Model Racecraft
713-466-9900
WWW.LATEMODELRACECRAFT.COM
NGK Spark Plugs
Gates Belt
LT4 Cam Package
-Pushrods
-Cam Phaser Kit
Crank Bolt
Fluids
-Oil Change
-Coolant
Shop Supplies
Badging
Custom Dyno Tune
9.47 ZR1 Corvette
713-466-9900
Not seeing any fuel upgrades in that list. Thought you said you have to upgrade the fuel system ?
And so those numbers are with meth as well? What octane fuel? e85 ?
What is power rating of the factory clutch in m7 and the factory A8?
So probably still more potential from some upgraded cylinder heads ?
