Katech LT1 427 - The highest horsepower NA Gen 5 LT1 in the world. 703hp/625lb-ft
#101
IMHO, when LG releases their "cooling solution", through the means of additional radiators and their reconfiguration of airflow, it will probably put a finality on whether its the engine itself or the configuration of airflow and radiators that cause the overheat ... Im not a mechanic , however, when I bought my c6 LS3 the day it came out back in 07 (I still have it ) , I would drive from studio city to malibu ca(where i live now) to get access to some great canyons and quiet backroads. By the time I would get there, the car would feel less spunky maybe even sluggish. I was one sad puppy, car was amazing locally what gives?, I looked at some schematics and saw that the z06 had an oil cooler up front. I ended up going to AA corvette and had them add a Z06 Oil Cooler to the front of the car for a grand total of a $100 and Poof , problem was gone.
With that in mind, I believe that putting a couple oil coolers in high and direct airflow areas will fix the issue, I remember seeing temps of 250+ after some spirited canyon driving and only 210-220 post oil cooler. Additionally and just as important the oil temps would cool down ALOT faster with the oil cooler once I resumed normal driving.
Of course rearranging the radiators and separating them across an enlarged area by modifiying our front bumper would probably help too, to what extent would be really cool to find out...
One more thing... when is Katech going to be releasing this, Ive been keeping an eye on this for awhile, if the price is right and I can test drive their engine at their facility I would be highly interested ...
#102
Premium Supporting Vendor
#103
#107
Subscribed
#108
Man oh man!!!! That engine sounds superb. Addictive. heehee. Okay so it's curtains in Ca for putting this in a C7 (or a C6)...how about Tennessee?
Must. Have. This. Engine.
#110
We have not changed anything significantly in regards to weight so it should weigh about the same as a stock LT1.
#112
1BlinkGone (03-08-2016)
#113
Received 4,376 Likes
This is technically correct, but you're forgetting one very important factor. Supercharged LT4 making for argument's sake 700hp at the crank and a 427 LT1 making 700hp at the crank are not making the same horsepower in the cylinder. If it takes for arguments's sake 100hp to spin the supercharger at peak power level, the LT4 is producing the heat of an 800hp engine, but 100hp is lost through parasitics. Hence the higher BSFC of supercharged engines compared to NA.
You are absolutely correct, people ignore the power produced and used to drive the supercharger to get the same het crank HP. That produces heat. It takes fuel. Fuel consumption per HP produced increases. It is all physics.
#114
(I put this in the Z06 section also in case Z06 road racers may be interested in a naturally aspirated engine)
I'm pretty sure I can make that claim. If there is a higher one somebody else has done on the engine dyno please let me know.
Full specs to be released later, but here are some:
703hp/625lb-ft on 93 octane
4.070x4.100"
Callies forged crank/rods
Katech forged pistons by Mahle
Katech LT1 piston squirters
12.5:1CR for use with premium pump gas
DI
Katech AFM delete valley cover
Katech CNC ported heads
Very streetable camshaft. Same or better drivability than K501.
Two all new, not yet announced products:
Katech throttle body
Katech 4 stage dry sump system
-Manufactured exclusively for Katech by ARE.
-Features OEM internal pressure and scavenge pump plus
-2 stage external roots pump
-New pan casting with better windage control
-Screened pickup fittings
-In car mounting will vary from what is seen in the photo
4.070x4.100"
DI
Now that's a bad assed engine...........
#115
This in a Grandsport would make a damn DREAM C7....holy shitballs!!! I wouldn't even want that much honestly. 605 at the crank N/A in a GrandSport is juicy enough imo. I'm getting there. My brain has been all over the place...go C6Z, go C7GS, go Porsche...wtf...
#116
You are too kind, they are not even remotely technically correct.
#119
