Best Floor jack
Best Floor jack
Any recommendations for floor jack for our Z's. I looked at the Arcan XL2T which seems substantial and low profile, but it weight 100 lbs. What do you folks here use and how do you like it?
Cheap Harbor a Freight 2 ton aluminum jack. Fairly low profile(fits under my lowered on stock bolts Z), very light weight and best of all it was cheap!! Works perfect
Ideal for lowered cars w/rockers/pucks
1/2" rocker clearance - lift pad on front puck
2.7" > 24" Lift Range
Precision control dial release - DUAL cylinder Rapid Pump®
T-handle rubber grips - Foam handle protector - Rubber lift pad - Foot pedal
Heavy Duty steel construction - Extra wide casters - Extended reach lift arm/chassis
Habor frieght 3 ton low profile jack duel pump
Padded bottom bar... On sale now $85 bucks! A steal flat fed ex shipping fee. 7 bucks!
Received 1,069 Likes
2015 C7 of the Year Finalist
[QUOTE=C7Jake;1588996868]Ideal for lowered cars w/rockers/pucks
That is a nice jack
What brand is it and where can I buy it?
thanks
That is a nice jack
thanks
Alcoholics Unanimous
Received 1,642 Likes
St. Jude Donor '15-'16
I have the exact same one, and if you're at stock height or don't have the CF side skirts it's a great lightweight low profile jack. But my front is lowered 3/4" and by the time the pad gets to the puck the arm slightly touches the carbon fibre side skirts.
I'm looking for a very low profile jack that doesn't angle that severely towards the handle. There are a couple of good options in this thread for lowered C7Zs.
I think I found the best, albeit somewhat expensive solution: http://www.quickjack.com
That's a pretty cool solution! I'm using the AC jack and race ramps with esco jack stands. I may end up getting a drive on lift if I have to buy my wife a toy, that way I can get 2 vehicles in the same side of the garage. You can get a drive on lift for about 2 1/2 times the cost of the quickjack but you can't put it in the back of a truck and take it to the track.
