Tow hooks soon for the ZO6
#101
Supporting Vendor
Premium set installed ...
Sorry about the crappy garage pics ... a biblical flood is upon us today.
You're gonna need a wrench to get them off because the loop detaches from the shaft, so if they're in there tight the loop will just come off first and then just use the wrench to take the shaft off ... it's easy because the metal has flat edges at the end for the wrench to grab. The D ring or Loop, should be tightend after you install so as to be level with car, after that it can be removed with out a wrench if you tighten the D ring jamb nut.
Very happy with these.
#102
Supporting Vendor
Supporting Vendor
We only made 34 sets of the SS premium ran out of stock, also found that the chrome molly we can turn down a bit more being 30% stonger. We now have the chrome molly in stock that replaces the SS shafts, they are $20 less in cost. $169.99 for a set.
#104
Supporting Vendor
Supporting Vendor
NO, the plate will not twist off easy. The shaft has a lock pin to keep tight and the cap bolt has a lock washer. I drive with mine all the time and no movement. If someone wants your plate they have to remove the plate to remove the holder. The plate comes off then you remove holder.
#108
Supporting Vendor
Supporting Vendor
2019 Corvette of the Year Winner
St. Jude Donor '15
Struggled with your web site on my iPhone 6+
Just went in circles trying to pay with credit card. Will have to call in and order.
Checked my credit card and I ordered three sets...ugh! Only need one set. Sent you PM as well. My impatience got the better of me....thanks
#117
Supporting Vendor
We now have tow hooks for the 2016 also, We checked and the grill is the same. One car had the receiver farther in as we can see so far. We are checking now for fit.
#120
Supporting Vendor
We checked and the grills are the same for 14 to 16 ZO6 We now think one frame on a car had the receiver welded in too far and that may be what we thought was a change. Anyone out there with our tow hooks with the black front shaft have a issue with it screwing to far in on a 2016? Let me know 858 527 8727 John www.zl1addons.com
