12 volt/15 amp underhood source
Looking for an easy hookup under the hood; 12 volt "on" with the ignition or constant voltage.
I would probably pull it off the alternator power stud. Just add an inline fuse. It is easy to get to and all the power you want.
Fyi
On the back of the fuse box facing the firewall is the threaded "power lug" located under a plastic flip-up cover.
