Xpel or Suntech
Personally, I'd closely check out the installers and accept the film the best installer prefers to use.
Yes, the expertise of the installer is critical to proper installation. Either film is great.
You may want to see the film on some cars the installer has worked on to see if you can discern a difference in appearance.
Suntek is 6 mil in thickness, hence might not protect as completely as Xpel Ultimate if a large stone hits the car; it is supposedly optically clearer, and is easier to work with, (meaning wrap around edges, etc), than the Xpel.
Xpel has a longer warranty; is 'self healing' and is 8 mil thick, hence might protect slightly more.
As above, the installer is the main thing to chose before the film used.
I went with Xpel.
XpeL on today!
Picked up today after full wrap except roof. Double layers on high impact areas. Cant even really tell its installed. If you look for it in very good lighting it can be seen. Have used this installer before. Might be best to go with an staller who also wraps race cars, decals etc. As always, the installer is the weakest link. P.S. i wouldnt consider Suntek if you plan on tracking the car.
So you would figure that with the same coverage, using the exact same product, that the prices would be within the same ballpark.
I check 8 different local installers and received a high bid of 8k......funny right? When I heard that number I literally did an about face, as the owner asked, ummmmm you don't want to talk about it? Actually no!
Ended up paying 2k OTD,......Don't let em shiester ya.
Yep
I thought it was a great price as well. Additionally the installer sat me down and listened to what i had in mind with regard to functionality. I did receive quotes as high as 6 to 7.5K
He also showed me a CAD program which he used to custom make the front fang pieces, and displayed each product lined up against one another.
A quick suggestion on arrival after the car is wrapped; a nice bubbly 2 bucket wash, ( I had 2 since it rained in Cali today for the first time in months) then inspect the wrap job.
Even with the best installers, it would be best to hit certain rolled areas with a heat gun very lightly, and work the area a bit.
For example, the very bottom of the door panel as the wrap makes its way into the inside of the car.....
It also helps if she a virgin when you drop her off( see Pic)
Trac wrapped my Z06 for delivery home. Buddy with a new car went to the same installer, upon closer inspection of his paint after 1000 miles, he is bummed.
Had P.M.'s with Q's about this....so here is the scoop.
Sending you a pm
I went with a product called "PPF". According to my detailer he says its the best. Personally I think they are all pretty similar and I do believe like the other posters that the installer and his expertise is whats really important. Not sure if I think the thickness is all that crucial because if your traveling 75mph and a rock hits you from the truck in front of you Iam not convinced that a millimeter of thickness "difference" is going to matter.
Bish
My installer (who I think did an amazing job) suggested Suntec on the nose because it looks better on lighter cars and but XPEL on the high impact areas (rockers, behind the front and rear wheels) and used Suntec for the window Tint as well.
He first washed waxed (And I think buffed) the car, then applied the wrap - you cannot see it anywhere.
Full Coverage Package $1300 installed including sales tax
- Full Wrapped Hood
- Full Wrapped Fenders
- Mirrors and Door Cups
- Front Bumper kit
- Headlight kit
- A-Pillar kit
+ Rocker Panel kit $400
+ $300 for full tint
So essentially $2000 out the door for the front clip and rockers.
- Full Wrapped Hood
- Front Bumper kit
- Headlight kit
- A-Pillar kit
^^^^^^^Soooo nice^^^^^^
Wow. Every time i see that color.....Hmmmm.
Well obviously your installer did a good job. Looks great. Your color selection was my second choice. It was a toss -up. Awesome picture. These cars really POP in the right light.
Also really digging how the SGM changes color when its cloudy outside.
Of course that's only going to happen in California about twice a year.
So it seems two thousand dollars is about what it costs. Have to wonder why some installers turn away business by initially quoting such a high price~ 7.5K?
I had mine done in Xpel a few days ago. I had the entire front (from the start of the doors forward), the full rockers, mirrors, door handle pockets, pillars and roof done for 2k. Mine only had 125 miles on it and I could already see small pits in the vents in front of the rear tires.
But my main reason was due to my using the same installer for my 2015, 2011, and 2006. He is surgical in his level of perfection. The installation expertise is by far the most important consideration as long as you get one of the more popular brands.
FYI, my installer used 3M on the prior 2 and Xpel on my 2015. He stated he switched after seeing how scratches fade in sunlight on the Xpel product.
