View Poll Results: If you've Overheated What is Your Stage Aero 1, 2 or 3
Stage 1 Aero
24.43%
Stage 2 Aero
18.70%
Stage 3 Aero
56.87%
Voters: 262. You may not vote on this poll
ZO6 overheating issues ***MEGA Merge***
Old 04-30-2015, 02:17 AM
  #2021
dmaxx3500
CF Senior Member
dmaxx3500's Avatar
Liked 476 Times in 371 Posts
guys,there was a trick -back in the day,
on overheating panteras,leave the hood on the safety latch[raising it up 1-2'']we would jam a pop can wrapped in a rag under it,doing this forced air out the back side of the engine compartment,,this would be a free try to see if any more airflow would help or hurt
gm spend millions on airflow thou
an other trick might be ,just remove the hood
dmaxx3500 is online now
Old 04-30-2015, 05:42 AM
  #2022
NemesisC5
CF Senior Member
Support Corvetteforum!
NemesisC5's Avatar
Liked 239 Times in 175 Posts
Originally Posted by rwheelz View Post
For $40 you can buy a pressure sensor and test anywhere you would like in the engine compartment. It would be incredibly easy to determine whether there is adequate airflow or whether more/larger vents are needed.
Can you provide a link where I can purchase?
NemesisC5 is offline
Old 04-30-2015, 08:24 AM
  #2023
FiremanC7
CF Senior Member
FiremanC7's Avatar
Liked 5 Times in 3 Posts
Originally Posted by soulsea View Post
Stage 4 aero with cooling pack:
Great post! Lol!
FiremanC7 is offline
Old 04-30-2015, 08:28 AM
  #2024
thebishman
CF Senior Member
Liked 316 Times in 233 Posts
Might have an issue passing the Euro pedestrian safety regs? lol
thebishman is offline
Old 04-30-2015, 08:41 AM
  #2025
Poor-sha
Track Rat
Poor-sha's Avatar
Liked 2,169 Times in 899 Posts
I applaud Bob for creating this thread with proposed solutions. Those shroud pieces *might* be there to direct water/snow/ice away from engine components that could have a detrimental impact over the life of the car. Frankly I don't know.
While we can speculate as to whether or not it will work it seems like this is fairly easy to test. Folks that are tracking the car and having overheating issues try removing those pieces at the track after you start having issues. Let's see if it helps.
The same goes for Lawdogg's trick of removing the weatherstrip at the base of the windshield.
I'll have my C7Z at VIR at the end of May and end of June. If I start having temp issues I'll try it myself.
Poor-sha is online now
Old 04-30-2015, 08:52 AM
  #2026
Snorman
Scraping the splitter.
Snorman's Avatar
Liked 1,006 Times in 473 Posts
St. Jude Donor '13-'14-'15
The electric power steering motor/assembly is almost directly underneath of the hood vent.
S.
Snorman is offline
Old 04-30-2015, 09:46 AM
  #2027
SteveTheCorvette
CF Member
SteveTheCorvette's Avatar
Liked 0 Times in 0 Posts
Originally Posted by SBC_and_a_stick View Post
Not to sound like a jerk, but the only way I see this working is if there is an inherent tradeoff between downforce and cooling. If removing the duct improves both, GM would have done it. It makes no sense to make additional parts to achieve all around less output. They can sell Corvettes with or without a heat shroud. It's all under the hood anyway. It has no marketing purpose.
If you remove that duct you are essentially removing a clean, unrestricted airway, without it you will almost certainly kill front end downforce. I won't deny that it has a chance of cooling the engine compartment, but I'd rather take it easy on the throttle than mess with the aero on one the most balanced cars around.
But, in the name of science, go for it! Analysis means nothing without experimental data.
SteveTheCorvette is offline
Old 04-30-2015, 12:32 PM
  #2028
descartesfool
CF Senior Member
descartesfool's Avatar
Liked 114 Times in 70 Posts
C&R Racing radiator with the Denso core. I am in contact with them about their prototype C7 radiator with the same core. They are waiting fro results from the major tuning shop they sent one to.
descartesfool is offline
Old 04-30-2015, 12:52 PM
  #2029
SBC_and_a_stick
CF Senior Member
SBC_and_a_stick's Avatar
Liked 496 Times in 281 Posts
Honestly, how about running without a hood on? I'm sure drag is terrible but I'm sure it would fix the powersteering overtemp.
SBC_and_a_stick is offline
Old 05-02-2015, 09:55 PM
  #2030
63Corvette
CF Senior Member
63Corvette's Avatar
Liked 252 Times in 177 Posts
Default Overheating TODAY......at MSR Cresson
Our local club had a track day at MSR Cresson. Ambient temperature was about 82 degrees F. A C7 (Z51) M7 StingRay overheated and spit water out the overflow at the end of a 20 minute session. THEN, at the end of the next session, the driver told me that he was experiencing "significantly over 300 degrees OIL temperature..." (in 20 minutes???).
63Corvette is offline
Old 05-02-2015, 10:10 PM
  #2031
SBC_and_a_stick
CF Senior Member
Have them join the club. It won't be an exclusive club for long.
Old 05-02-2015, 11:10 PM
  #2032
ENCT
CF Senior Member
ENCT's Avatar
Liked 3 Times in 3 Posts
Why post this in the Z06 section?
ENCT is offline
Old 05-03-2015, 05:47 AM
  #2033
descartesfool
CF Senior Member
Because there is no Z51 section perhaps? And Z51 is a track pack and most people who post in the other C7 sections do not seem to post much about the track while lots of track related posts in this section. Maybe we need a section on called C7 on Road Racing Tracks.
Old 05-03-2015, 08:53 AM
  #2034
Phil~
CF Member
Or negative types are drawn to the Z06
Phil~ is offline
Old 05-03-2015, 09:18 AM
  #2035
ENCT
CF Senior Member
ENCT's Avatar
With all the hype about the Z06 overheating all we need is more negative threads especially about a non Z06.
Eric
ENCT is offline
Old 05-03-2015, 10:44 AM
  #2036
pcguy2u
CF Senior Member
pcguy2u's Avatar
Liked 34 Times in 31 Posts
pcguy2u is offline
Old 05-05-2015, 10:56 PM
  #2037
ncrowe
CF Senior Member
Liked 11 Times in 6 Posts
I tried this today
Removed the duct and the hood shroud as well as the weatherstripping on the firewall. Lowered my temps 10 degrees - with ac on - 210 max temp. With AC off the temp was fluctuating between 195 and 205, would stay mostly around the 200 mark (15 - 20 degree drop).
I noticed a few really good things - first: when the fan comes on a massive amount of air comes through the hood that was previously trapped in the engine bay. Second: the air intake was cooler because the air being pushed by the fan was getting out of the engine bay.
I noticed no difference in noise, rattles, or anything like that when driving
It too a total of 5 minutes to remove the parts, and would take about 10 minutes to put back on. For the drop in temps I would say this is a good mod.
I'm going to be playing around with a few things with the car - I believe that there are a few basic and easy things that can be done to this car to keep it really cool. I have the spacers and the tank from Formatto coming and a 170 thermostat as well. E85 will be added, and maybe even some meth - this should keep this beast super cool and consistent.
ncrowe is offline
Old 05-05-2015, 11:04 PM
  #2038
soulsea
CF Senior Member
soulsea's Avatar
Liked 274 Times in 101 Posts
St. Jude Donor '15-'16
How do you remove the weatherstripping?
This is the plastic trim piece the wiper arms go through right?
Thanks.
soulsea is offline
Old 05-05-2015, 11:13 PM
  #2039
Flyboy22
CF Senior Member
Flyboy22's Avatar
Liked 42 Times in 34 Posts
I somewhat agree... Just because you can flow MORE air (potentially) by removing the ducting, the airflow is likely to be much more turbulent. The effects on drag / downforce from all that turbulent air under the hood are unknown, but I'd like to think that GM used all those wind tunnel hours for something semi-productive.
Easy enough to undo, I suppose, so try it and let us know
Flyboy22 is offline
Old 05-05-2015, 11:26 PM
  #2040
C7/Z06 Man
CF Senior Member
C7/Z06 Man's Avatar
Liked 312 Times in 248 Posts
Thanks.
No, the weatherstripping is in front or on the front of the plastic trim piece the wiper arms go through. It's a soft hollow strip of black rubber that goes from one side to the other side on the top of the fire wall. The end of the weatherstripping has a hollow black rubber block covering it if I remember correctly that you can just pick up some with your fingers.
TRACK DAY STUFF:
I like the suggestion above (dmaxx3500) of wedging the rear of the hood open some for additional underhood air/heat removal. No removal of parts and very quick to return to stock; also the removing of the firewall weather stripping will do the same but no where as large of a rear opening as wedging the rear of the hood open.
C7/Z06 Man is offline
Quick Reply: ZO6 overheating issues ***MEGA Merge***
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
