View Poll Results: If you've Overheated What is Your Stage Aero 1, 2 or 3
Voters: 348. You may not vote on this poll
ZO6 overheating issues ***MEGA Merge***
#2081
Yup - I bet there are fewer than 20 Z06 owners who can drive truly fast, as in within say 2 sec a lap of Milner or Pobst. They probably lament the lack of cooling. But I think I read that over 8000 Z's were sold for the 2015 model year. That is more than the entire production of Ferrari. Seems like the right call by GM to just sort of fade all the track-worthiness questions.
#2082
And I had the audicity or delusion that this thread might get one response from the "genius" with the solution. But this topic appears to be red meat for the masses - eat hardily comrades. Best
#2083
V10LEE
My personal opinion is that it is asking too much for a stock, 3500+ lb, 650 hp, air conditioned car to run at race pace for 20+ minutes in 80+ deg ambient and not overheat. I don't know of a single stock car that can do that. Just the airflow restriction from an A/C condenser is a street compromise that significantly reduces cooling capacity.
#2084
At a race pace, you will likely see wide open throttle close to 80% of the time on track. And average speeds are probably in the 80 mph range for most tracks. (e.g. I've run 2:25 at CoTA in a street car, so average 84 mph, despite over 160 mph on the longest straight).
Surely someone can do the thermodynamic calculations to see how much surface area and airflow for heat exchangers is required to dissipate the heat from running 650 hp?
For a purely anecdotal comparison, my Radical SR8 track car has a pair of sidepod mounted radiators that are comparable in size to a normal automotive radiator, that are ducted to enjoy what looks like a lot of air flow and no restrictions like an A/C condenser or even a radiator fan and it makes only about 400 hp. It never overheats, running coolant temps consistently under 100 deg C and oil temps under 125 deg C.
I'd bet that it will take pretty radical surgery to get a Z06 to run cool at race pace, as in lots of mods to improve airflow and much different and more numerous heat exchangers.
The solution is non-trivial.
For example, LG appears to be silent right now. I know Lou and he can drive with real pace and I suspect they are having to do a lot of work to try to make a new Z run cool with him driving it to his potential.
This car was not built for a guy who can run serious pace to track for long periods of time - I felt pretty sure of that when I saw the stats of power, supercharging and weight. It is an awesome GT car, very appealing to the drag racers, and great looking. But a track car it is not.
I wouldn't be so quick to write GM off regarding this topic. While I have no details or specifics yet, I do know they're looking into it. Whether they're able to come up with an explanation or solution or not is another thing entirely. And it may be best to hand this off to the aftermarket (see: DeWitt).
The ISSUE is, yet again Corvette has targeted other markets..it's been stated that was the goal. They've made it clear they want Porsche buyers and they also invested quite obviously in racing and in Nurburgring presence. All this adds up to a track machine, and an increase in buyers who want to track the car...as you see with Porsche owners. I don't care if 90% don't use it there, for the 10% that do, it should show up.
I'm not Tadge...and I've defending the company, the crew, the leaders endlessly, but...these are calculated moves or they are incompetency. The Z06 acts as the HALO car...this simply can't happen. I feel like we are experiencing similar fumbles from the Corvette/GM people that we saw with SRT. The alignment fumbles, the lack of performance, the dealer ball drops, etc...and look at the impact it had on Gen V sales...the Plymouth Prowler was more successful than this Viper, and that problem starts with Gilles.
#2085
Not at all ..My bonestock Gen V viper at 3300+ lb with 640 hp, air conditioned etc never gets close to getting hot on the track . It just keeps going lap after lap. Session after session in hot weather temps. Same goes with my bonestock 2010 Viper ACR. At Laguna Seca I am at 2nd and 3rd gear most of the time too. Also ran Buttonwillow track in the heat , no issues.. With that being said. It's an engineering flaw by GM causing these new Z06 overheating on the road course..
The anecdotal stories about how well any car does on track are worthless without lap times. For example the TWS story had a best lap time less than 1.5 sec faster than Spec Miata TWS track record. Not exactly wringing max performance out of the Z06 in my mind.
I do agree that GM did not engineer these cars to go fast on track for extended sessions. I also think they had to know that well before production began. Most of the target market simply does not care that much, IMO. We track rats are on the lunatic fringe
#2087
#2088
#2089
As have I. It's just very, very hard to run race pace in a high power stock car and not have overheating. I held off on the new Z as soon as I saw 650 hp and 3500+ lbs. First, the power and weight told me consumable costs for brakes and tires would be very high, and second I was immediately worried about cooling, having myself overheated Vipers, Gallardos, C6 Z06, and (marginally) MP4-12C on track.
#2091
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
#2092
My personal opinion is that it is asking too much for a stock, 3500+ lb, 650 hp, air conditioned car to run at race pace for 20+ minutes in 80+ deg ambient and not overheat...
This car was not built for a guy who can run serious pace to track for long periods of time...But a track car it is not.
"The Z06 Manual is designed to keep engine oil, coolant, transmission and differential fluids below the hot warning targets when driven by a professional on a 30C day (86F) on a "typical" racetrack for an indefinite period of time (effectively the time to burn through a full tank of fuel)."
#2093
Respectfully disagree. Check the Ask Tadge forum and you'll find the following which came from TJ in response to a question on track overheating.
#2094
A thread with one question and takes off like a rocket. I may sit down and right a paragraph and be entertained for weeks. Best
I disagree as well. This car offers a Z07 package that features tires that brag that you can drive them from the street to the track, has massive downforce which offers little outside of track conditions, and stiffens the suspension such that the track is where it's most at home. When I "built" the car on the website, it produced high resolution pics of my build on the track. Are you seriously going to try and say that the car was built for the track, but only if you drive it slowly?
#2095
Scraping the splitter.
Originally Posted by Tadge
•The Z06 Manual is designed to keep engine oil, coolant, transmission and differential fluids below the hot warning targets when driven by a professional on a 30C day (86F) on a "typical" racetrack for an indefinite period of time (effectively the time to burn through a full tank of fuel). Our team validates the durability of the Z06 cooling systems with a 24hr accumulated track test to simulate the most aggressive track-day usage by our customers.
•We designate our track: the Milford Road Course, as the "typical" standard, but recognize that there are tracks around the world which are easier on a cooling system and some which are harder on a cooling system. Generally speaking, tighter tracks with lower average speed and higher sustained RPM, will drive higher fluid system temperatures.
•Higher temperature ambient conditions affects all car's abilities to run sustained laps at ten-tenths.
•The Z06 Automatic transmission put in "Drive" selects the lowest possible gear ratio for best acceleration, and because it has 8 closely-spaced ratios typically runs higher average RPM than the manual. This optimizes lap time performance, but also taxes the engine oil and coolant more for any given track. So the automatic has the capability to run faster laps than the manual, but thermal limitations are reached more quickly. Customers who are planning to run extended track-day sessions at 'professional' speeds, are advised to go with the manual transmission, or to paddle shift the automatic and select higher gears when conditions warrant it.
•Any time the maximum recommended temperatures are reached in any condition, the DIC will give warnings at the appropriate time for coolant, oil, or transmission fluid. A cool-down lap or two will bring operating temperatures back to a reasonable level and aggressive track driving can be resumed.
I really like the car. They've done a helluva' job with the C7 and the Z06. But the relatively marginal cooling needs to be addressed. If it's a simple fix GM needs to implement it and provide it to existing owners. I don't think the sky is falling, and I don't think that everybody tracking the car is going to have these issues. But if they want to be mentioned in the same breath as "GT3" or "Porsche" it must be done.
S.
#2096
Since I have a M7 I was wondering if I could lay my intercooler down like this? This would open up airflow to the radiator, Than a DeWitts might work. Thoughts?
#2097
While not the full quote, this is the bulleted list of his response:
Nowhere in that, or in the full response, did I see the statement "by a professional to x% of his or her" or "x% of the car's capability". Taken on its face, this statement can be interpreted differently than insinuated. The statement "to simulate the most aggressive track-day usage by our customers" is non-specific, and may not reflect anywhere near the capabilities of the car or their "professional". Finally, a "professional" what? Driver? Engineer?
S.
S.
Even his explanation, though, was delivered after people started having problems in response to this forum. Never was it marketed as only a fair-weather track car for those with manual transmissions and novice trackers who can't go fast enough to really stress it.
#2098
However, a Dewitt dual core replacement solved my problem without needing any more airflow than the sock GM radiator had
#2100
I agree that Tadge's comments are sufficiently vague as to not exactly say how hard the car can be driven and not overheat. It sure seems like some of the quicker track drivers are having very high fluid temperatures (I for one never allow one of my race cars over 240 water or 280-90-ish oil) that really shock me. 260 water? Yikes. 300+ oil? From what I have read that really means an oil change every few hours of operation.
I am a huge GM and Corvette fan; I've owned several including the C6Z and my DD is a CTS-V Wagon. But I decided to pay more for "less," by buying a GT3. Why? Well partially I just wanted to try a P car as I've never had a street Porsche, but I also liked the lighter weight and lower power, as I figure it's easier to cool 475 hp and Porsche somehow manages to punch way above its weight in terms of lap times for the power level. I would have been much more impressed if the C7 Z06 went down in weight with a modest increase in power (imagine say 3000 lb and 525-50 hp) with a big emphasis on cooling and brakes.
Problem is, I really think the Corvette demographic would rather have the power than serious track ability, and of course lower price. The car is fantastic looking, can lay down a serious hero lap, and drag race in the 10s. But hard, race-pace track driving is very expensive to design and build for and a complete waste if the driver never really uses the car that hard and I honestly don't think most Corvette owners track their cars with great pace (present company excluded). I can't blame Chevy for building to this market, but that's exactly what I think happened.
