View Poll Results: If you've Overheated What is Your Stage Aero 1, 2 or 3
Voters: 348. You may not vote on this poll
ZO6 overheating issues ***MEGA Merge***
#4061
I find it heard to believe that when GM's engineers did the testing etc. that they didn't see these problems...surly they must of did at least 3 consecutive laps while testing....I read that Chrysler's engineers did a 24 hour testing on the hellcat and saw that the temp. on their supercharger etc. was well within limits but I wonder if because the hemi they use is an iron block helps some and I wonder how they cool their supercharger etc...
#4062
The oil temp shut down my A8 Z06 2 1/2 laps around a 1.7 mile track. Ambient temperature was 84F with 18%Rh. I was paddle shifting at recommended shift points, 1 or 2 green/yellow shift lights, downshifting going into corners. Tranny and coolant temps were acceptable. Drove up to a local ski area and watched oil temp approach 280F while staying in D. No problem coming down from ski area. Oil temp normally runs 220-240F. Doing an HPDE this weekend and local temps at the track are forecasted at 94-95F, Rh is unknown but I would guess 20-30%. New card for PDR to record all this.
#4063
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
Perhaps your experience is different from some others. A quick search of overheating for those three makes also returned owner complaints. Of course, Porsche has been working on their design for decades, and considering the cost, may not have as many incidents of overheating. One can still add additional coolers to the vette, as many of us have, and still have quite a sum less invested. Personally, I would not expect a 600+HP car to run all day at the track without some overheating problems unless there were some extensive upgrades.
#4064
#4065
Scraping the splitter.
https://www.corvetteforum.com/forums...post1590052413
Note the FMIC as well.
So you are 100% correct. Stock GT-R's (CBA or DBA) will not survive 20-30 minute sessions stock, especially with a driver that can routinely push cars to 10/10ths lap after lap. Claiming or at least insinuating otherwise is at least disingenuous. I would also doubt a stock GT-R will maintain engine oil temps in a safe range while stock.
S.
#4067
GT-R's are at least as notorious for overheating the GR6 as Z06's are for high ECT temps. That's why there are $2500-3000 trans cooler options out there from vendors like HKS and Greddy.
S.
S.
#4069
Because AFAIK, only MT has reported elevated oil temps at Road Atlanta with Pobst driving. Were there others that I missed?
My points about the GT-R stand. And IMO, if data from a source is unreliable at one facet, it is probably unreliable at all.
S.
#4070
I will never overheat the car or at least I don't think so but I do hope that the frequency will be less. I agree for those running 25-30mins track periods it can/could happen but certainly running a few laps or spirited runs shouldn't induce a car to overheat.
#4071
btw I talked to guy today from a Dodge dealer that said they are seeing some heat issues from the Hellcats, I haven't run mine hard enough yet, but that engine also produces a lot of heat. The fans in my car were kicking in today driving around town...it was 30C
#4072
My GT-R is the oldest one made (2009) of the current generation. I have stated before that I had to add a secondary HKS transmission cooler and posted pictures of the HKS kit with all its laser cut stainless mounting brackets to show what a high end aftermarket parts supplier could provide, and cost was $1900 (depends on the yen value). I then added a secondary oil cooler to keep oil temps lower, although I never actually had an engine oil overheat condition, but I wanted lower temps. I can drive it at 10/10 ths all day and it never overeheats. The production a few years later increased the front radiator opening in the bumper and increased the size of coolant lines back to the transmission cooler, and it seems most people can run it hard all day on track without overheating and only some might need to add a transmission cooler but nothing else, often if they have boosted the power of the engine with aftermarket parts like I did (exhaust, intake and ECU tuning). So an old GT-R needs help to run all day, but it only costs $2000-$3000 and it makes the car completely bullet proof. My GT-R is 7 years old and has never had a repair of any kind, and I have done about a dozen track days a year with it for those seven years. When GM or other aftermarket guys come up with proper solutions to cool the C7 on track, that will be great. I am fed up with my transmission at 300 F every time I take my Vette to the track, and fed up with it's coolant temp overheat warnings, and fed up with its constant AFM actuator failures requiring a visit to the dealer every time I take it to the track, which I avoid now. GT-R is a much better track car than my Vette. Hopefully aftermarket parts will make the Vette an equally good track car, but I am tired of waiting and dealing with GM customer care and the GM brand quality manager. GM has no solution for my overheating Vette. Talked to my service manager yesterday and he is now suggesting moving to a GM buyback. I've never been in that situation before.
And as for mods on the Vette, the last 3 times my AFM actuators have failed the GM brand quality manager has made my service manager confirm with me that my Vette was not modified ( he says each time he is sorry but he has to ask), which I interpret to mean they are looking for a way to deny warranty coverage, as if anything I could be doing would cause those AFM actuators to fail. So not happy with my first ever purchase of an American car. Now considering cars that don't overheat on track, like the Viper and the GT3. Wish GM had properly engineered the car to live up to its marketing as the most track capable Corvette ever.
#4074
Yes the GTR track pack has overheated by magazines.
#4075
The chevy information explains the higher RPM's when the A8 selects the gear thus leading to higher temps. That is easy to understand. Question is, has anyone had a temperature problem when manually selecting gears as suggested in the bulletin? As far as steering problems, many folks have a habit of 'sawing' back and forth unnecessarily on the steering at the track. Not saying this is the particular reason for over heating steering on the C7 but it sure causes hot fluid in the C5 and C6 when abused at the track. A smooth driver in those cars will not see a premature failure of the steering. Those that 'saw' the wheel will. Not taking issue here but I believe we would all like good, valid, anecdotal evidence of the problems.
Please see the listings for peterjank in post #2 (The Tracks) under the Autobahn Country Club heading in the thread above.
Also, regarding the power steering overheating issue there may be a correlation with the use of A/C while on track, i.e. having A/C on may contribute to an overheat of power steering in some instances. However, the power steering has also overheated in some cases when A/C was not in use. I have only experienced my power steering overheating once and it happened to be the one time I accidently left the A/C on.
#4076
Is there any vehicle one can purchase off of the showroom floor and take it out to track to pound on it through a tank of gas without seeing elevated temperatures in most of the fluids? Even the C5 and C6 have an extensive aftermarket for those of us that need to cool the tranny, cool the oil, cool the differential, cool the power steering fluid. Well, as far as the power steering, there is a company that builds a nice pump and rack for them that seems to last longer. I know that my C5Z would overheat oil and tranny (with warnings) on an 85 degree day after running hard for 25-30 minutes before I added components. I guess what I would like to see is someone demonstrate the problems for me while I observe how they drive. Maybe the individual driver is exacerbating the problems, maybe not. Just way too many variables involved. I have been running with other owners of corvettes at the track for several years and I have seen exact cars with different drivers differ immensely in reliability. After all, the C7Z is a highly tuned vehicle. As with most things high performance, it is difficult to get the same result with the population as a whole.
#4077
Yes, I overheated the engine on my A8 Z06 while manually shifting. The data and video is available in this thread:https://www.corvetteforum.com/forums...imes-here.html
#4078
There is clearly an issue, its undeniable. Most production cars during the WAJ media days go 3 laps at MRLS, switch drivers, then go another 3 for 2 hours in the morning, 3 hours in the afternoon and the only thing that gets hot or worn are the brakes. Hellcats, Viper GTS, GT-R, R8s, etc. etc.
#4079
Motor Trend had 5 instances of overheating the Z06 - 3 different times by Randy Probst on a track, once around the figure 8 and once sitting in traffic. They also complained of massive heat from their other testing. This is all within 9 months. I've never seen that many issues with a new sports ever. Especially one in this price bracket.
I just don't see the point of arguing against the fact that there are real issues with the new Z06.
#4080
The transmissions in the C7 Z06 are not overheating, unlike the first couple of years of the GT-Rs. GM even held back production of the A8 models to add the secondary transmission oil cooler which has cured any c/o tranny overheat situations that I'm aware of.
Nissan absolutely did not do this before they released the 2009 GT-R here in the USA, and guys like you and I became beta testers for multiple cooling solutions so that we could run the GT-R reliably for 25-30 minutes at a decent rate around a road course. I had to back off a little even with the HKS tranny cooler to keep the engine oil below the 'red zone' which IIRC is around 300dF in the GT-R. You even had to add the secondary EOC to your car to maintain decent engine oil temps.
THAT is where we are with GM at this point in time: will GM step up and take care of those of us believing them when they called the C7 Z06 the most "track capable" Z ever and produce an add-on secondary EOC, or are we going to have to turn to the after-market. Just like owners of track driven GT-Rs had to do when those cars were first released to the public.
I know you're incredibly frustrated with the issues you've had with your Z51, but as someone who has owned both a 2009 GT-R and now a 2015 Z06, I certainly feel that the Z is so much closer to being 'track ready' this early in its lifespan than the GT-R ever was.
Bish
