View Poll Results: If you've Overheated What is Your Stage Aero 1, 2 or 3
Voters: 348. You may not vote on this poll
ZO6 overheating issues ***MEGA Merge***
#4241
So it is engine oil temps, transmission oil temps, and coolant temps and any combination of the 3 for both A8 and M7 cars, but obviously not for everyone.
Need a spreadsheet to track the variations.
I look forward to hearing about a group of 3-5 and swapping cars.
#4242
Coolant and powersteering overheat in both A8 and M7 cars. I've seen people with less than 10 track days do it so you don't really have to be a good driver.
#4243
I agree
How about adding a C6 Z06 to that list of cars that can be tracked stock as well.
There is no track prep in the manual that improves engine cooling except for the removal of the front license plate.
Even if you run A/C the car will shut it off automatically to try to cool a little better. Therefore, all overheats are without A/C by technicality.
There are many sports cars that can be tracked at max speed without overheating. Most manufacturers will have specific sports cars more robust for track use. For example, with Porsche you have to get GTS, GT3, or GT4 to make sure you don't overheat. With Viper, none of the models overheat. With BMW you have to get the M division model. With Corvettes you don't have a robust option, sorry.
#4244
Glad to hear you are not having problems. There seem to be a few of you out there in the minority. I know each car is different, but the cooling of these cars is not a variable factor, meaning the tolerances are basically the exact same... so that always leads me to ask how is it possible that a few are not having problems given the way was engineered for cooling?
Which would mean conversely if your car doesn't overheat, you're not competent. I had some surging at about the transition from boost to vacuum at high speeds if I had to hold that speed through a corner, but no idea what that was. Maybe it was pulling timing.
I pushed mine HARD in 90+ weather and only had problems with the AC on. I was passing GT3s and other exotica, but emblems don't mean they were being driven well. Still, I wasn't grandma.
I'd like to see us both on the same track. I'll just follow on your tail, presuming I'm able, and call out my awesomely cool temps. Well, to be honest, 195F would be awesomely cool but I'll settle for 230F at the track.
Sorry yours has trouble, glad mine doesn't, hope they're all like mine one day. Unless I become competent
[Edit: maybe we're driving different lengths of time - I'm maybe a dozen or so laps, under half an hour. But I'd think that'd get it up to wherever it's going to run, and another 30 minutes wouldn't matter. Could be wrong]
#4245
Granted my oil temps have been higher than I'd like, and I've never suffered a PS issue for which I thank you in part due to your modification that I adopted. But to state that everyone will have overheating issues at a >80dF ambient is simply untrue.
Bish
#4247
Location: Syracuse-Central Square New York Winer of the all Corvette race WGI 8/23!
This kind of blanket statement is nonsense. I am a "competent" driver, and even though I had taken a break from the road course for the last five years, in my two track weekends thus far this year, I have easily been the fastest car in my run groups. I have never had to 'retire' the car early due to overheating issues as I'm 'competent' enough to know how to drive around the car's limitations; i.e. short shift to take advantage of the torque characteristics.
Bish
Bish
Our Z07 has been driven hard and twice by a "competent" driver (not me although I wish!) that is about to take his class championship at VIR. We have always been the leader of the pack in a given group. We have not overheated once or a steering failure, period! In fact the highest coolant temps we've seen were 232 and oil 261. Big tracks and tight tracks it does not matter. I am willing to bet there are more C7's tracked without overheating or other issues than do. We don't here from them, their out having so much dam fun!
FYI, Just changed our rear Diff fluid and it did not look good at 6,800. The magnet had a lot of metal on it the color was gun metal grey. If your tracking your car I suggest getting it changed. We will monitor ours next season and probably do it again in 5k.
#4248
Bish
Bish
As you've stated, you drive slower to prevent overheating. Its not that the car is robust or that you are not a good driver, it doesn't overheat because you adjust your driving style to account for the car's deficiencies.
I agree with Bish, not all cars have issues and those that do were most likely either not prepped correctly or have there own specific internal problem.
#4249
As for diff fluid, Glad you mentioned the condition of your fluid.that makes it clear its something that needs attention.
#4250
That is an inaccurate statement. Stock C6Z06's driven hard by experienced HPDE pilots will overheat. Even with the ZR rad [Z07 pkg.]. Many if not most track rats install race rads in the C6's to overcome this issue. It is one of the commonly recommended mods by the better race shops such as Phoenix Performance in Philly.
#4251
*intercooler that blocks the entire front side of the radiator
*an in-block 2,900 psi fuel pump
*an additonal 145hp and 180tq
*an additional 350lbs of weight
*shorter gearing (auto)
*stickier tire (more of the power can be put to use)
*wider tire (more of the power can be put to use)
*eLSD (more of the power can be put to use)
*more downforce (more of the power can be put to use)
*TVS blower (generates heat through friction, and requires an additional 65 hp to spin)
#4252
SBC, For the record we have 4 cooling solutions we feel are helping. The 3 inch cooling duct direct to the oil cooler. The cat covers and the 90\10 water in the cooling system. The under body fresh air scoop to the steering actuator. If that's what works great but I think we need a bit more. If GM aint going to take care of something I will.
I've raced and had teams from snowmobiles, cars to boats for many years and some at high levels of competition. Never in even stock classes have we or anyone ever left anything "stock"! OMG you wouldn't last one round! Maybe its just me but I enjoy (to a point) making my stuff a bit better, faster, cooler and looking better than my competition and especially the factory boys.
On a positive subject to accomplish something here. We all have hot oil running in and out of our holding tanks behind the right front wheel. We thought if there is a way to keep that tank cool would also help drop the oil temps some. Its now encased in an area with little to no fresh air. The drag guys use cooling tanks with ice for similar issues. We have some ideas but again its an area to think about. This is a think tank, any idea may have validity lets hear them. We have resources to do some cool stuff that can keep our beasts out front at every track in the nation!
#4253
2015 A8 z06 with z07 option. Two track days so far, both at Miller Motorsports Park in Tooele, Utah. One in August and one in september. In august I had the PTM set to 'Track - Dry'. Ambient temp was ~ 90 deg F. Started to overheat at the end of my 25 min session. In September ambient was ~80 deg F. I set the PTM to 'Track - Sport 2'. I had a much better time around the track, but got the warning light after 5 laps or so. Other than overheating I couldn't be happier with the Zed, but considering the overheating I am starting to wonder if I should have went with Godzilla instead . I hope Chevy comes up with something soon. Some of the workers at the track mentioned that all of the A8 Z06's that have been at the track have had overheating issues. I'm sure being at 5000 ft above MSL isn't helping. Noticed that in sport 2 the computer didn't let the rpm's get below 4,000 very often. Haven't been to the chevy dealer yet, but need to do that just to make them aware of my issue. Showed the PDR video at work ... everyone was quite impressed with that option.
Also will be at spring mountain in October ... hope to see some of y'all there!
#4254
Folks will read this and think, oh, only a few Z06 have faults which lead to overheating. In truth, it's not a fault, it's a design limitation. There is a difference. Guys that had mishapped coolant tanks and water pumps desintegrate have faults, those are few. But every Z has the same cooling capacity with no faults and that is fixed, and inadequate. The fact that you have numerous cooling mods proves that the cooling is inadequate by design. Wouldn't you like to devote all that time modding for power or downforce? I know I would.
#4255
Bish
Bish
#4256
"I agree with Bish, not all cars have issues and those that do were most likely either not prepped correctly or have there own specific internal problem."
I guarantee I can take any freakin A* car you want and have it overheat within 3 laps at Nola Motorsports. forget all that pre talk and "specific internal problem" Damn it, you guys are off base totally, trying to make GM sound all fuzzy and warm. I love GM, but the FACT is, there is an inherent design limitation/flaw in this TRACK car. PERIOD!!! PERIOD !!!
GET it through your heads. Just because there are some (guys who really don't belong on a track, or with a real track car) out there that say "wow wee, my car did just fine....hmmmmmm, not sure how fast I was going, but Im betting I was flying...hmmmm, and when i looked at my temp thingy, it seemed just fine...hmmmmm!!!!
I'm glad you guys are happy putting around the track, (kind fast)
But this car has TRACK written all over it, for God's sake.
#4257
From your post it's obvious that you were leaving the A8 in 'D' mode. It has been documented time and time again that the A8 equipped car can be relied upon to endure a 20-25 minute HPDE session even in high ambient temps when you manually shift AND keep the revs down. Drive it with the torque curve and you'll enjoy it for the full session whilst waiting for the aftermarket engine oil cooler to be developed/sold. Which will take care of this ridiculous oversight from GM
Bish
Bish
#4258
#4259
The truly astonishing part about the C7 Z06 is that it can turn approx the same times in full showroom stock trim without the additions of any of the mods I listed above. Which to me says when the cooling issues are fixed the C7 platform is probably going to be consistently several seconds faster that pretty much everything. With the exception of true race cars and the new viper ACR
#4260
What part about my statement is inaccurate? All cars suffer heat soak - Period. Super charged cars suffer even more than naturally aspirated cars as you should know. Of course a better radiator like the LG Motorsports Super Cool Radiator (And other brands) will help as it will help all cars. But show me the guys with C6 Z06's that have the cooling issues that the C7 Z06 does (Stock vs stock)? Where is this data?
That is what I was discussing as well as SBC and others. The C6 Z06 does not have a cooling problem - Period. It has had other issues that are well documented, but cooling it does not.
