View Poll Results: If you've Overheated What is Your Stage Aero 1, 2 or 3
Voters: 348. You may not vote on this poll
ZO6 overheating issues ***MEGA Merge***
#5082
When z06 first came out, on youtube highway race it would not have any power or pretty slow vs a similar or lower close hp car, is it the same issue? This was awhile ago.
Any other major problems for the 2017 z06?
#5083
Alright, quick update on my 16 A8 overheating. Got to run at NOLA last weekend. Weather was almost even cold so it wasn't the best to gauge the problem with, but I really feel like it is now covered and won't be an issue anymore. I had the Dewitt's "KIT" installed. The radiator, large EOC and larger intercooler heat exchanger. On the 700 mile drive there, and on the return trip back, the coolant pretty much stayed at 188 and oil temp 157-171. I will know for sure the first weekend in June at the NCM track as that is usually our hottest temp weekend anywhere we go for Optima. I hope this helps. I feel like it was money well spent.
#5084
2. what was the ambient @ NOLA?
3. do you have your on track max temps for oil, coolant and trans?
#5085
These are list prices. PM if you really want to purchase and I can help you with the prices.
2. 68-78 degrees-like I said "almost cold", but I was able to drive the car hard enough to tell a difference
3. oil=261 coolant=237 trans=184
this info is from the PDR using the Cosworth Toolbox
I'll have the latest HP Tuners outfit for data at my next track day. I think I can do some fine tuning as well. I'll be drag racing every week until June 3-4. Might learn a few things there in the meantime.
#5087
Didn't they fix 15,16 already? with 2nd cooler?
And it's a small percentage 5%, but is it 5% of people that tracked the car or 5% of all z06 owners?
#5089
Sure it's great on the track, but it's bad for wear on the street. Oil is designed to run 200+ for good wear protection.
#5090
Oil temp
I agree with you about the oil temp, but it does come up at lights, drive throughs ect... With the a\c on. Which I use year round. 180's to 190's. Enough to evaporate condensation.
#5091
1. rad=$799.99 EOC=$899.99 & Z06 CAC=$599.99
Interesting. Oil seems right in the sweet spot, coolant a bit on the high side but the trans temp is very, very low.
How many sessions did you do? 25 minutes each?
BTW: almost cold here in CT low 40s.
#5092
15 min sessions. Tried 3 of them, but still went into reduced power due to IAT's going too high. We think the intercooler pump is failing at times.
#5093
overheating
ok so , i'm a little behind on the overheating issue , i've got a 15 Z A8 and iv'e done several track days with it but mostly in feb , mar here in Texas ambient temps around 50ish degrees and no problems and I just ran COTA this past weekend and it was about 90 degrees and it didn't take long to realize car could only run about 4 laps and the oil temp went 300 , coolant temp was off the charts and of course it told me reduce speed and idle until eng temp is reduced, needless to say in the back of my mind i knew this might happen and not to mention most if not all other stock Z06's out there had the same issue, so i guess my question is what are most folks doing to correct the problem? does GM offer a kit to resolve it ? is the aftermarket the way to go ? has it be corrected on the 17's ? any thoughts would be greatly appreciated
#5094
Yale (05-04-2017)
#5095
I am interested in the Gspeed aftermarket solution. The amount of data they collected is substantial. They also discovered the water pump shut off issue that lasts for 3minutes if the system is not air bled properly. They ran an automatic in D at Cora for 40 minutes with now overheating issues. They have posted on the forum the work they did to deserve GM their package.
#5096
Supporting Vendor
Send us a PM if you're interested in any aspect of our kit, or feel free to give us a call at 877-512-5180
We have every possible corner covered to make these cars run right on track, with temps all under control.
__________________
"Keeping You on Track!"
http://www.gspeed.com
877-512-5180
Instagram_Facebook_YouTube
GSpeed C7Z Cooling Development
2014 NASA Texas TT1 Champion
2015 NASA Texas ST1 Champion
2018 NASA TTU & TT3 National Champions
2019 NASA ST2 National Champion
2019 NASA Texas TT2 Champion
2020 SCCA Majors COTA GT2 pole sitter
2020 SCCA Trans Am Road Atlanta SGT Winner
2022 NASA National Champion ST2
2023 NASA National Champion ST2
2023 NASA National Champion TT2
877-512-5180
#5097
17 supposedly gets significant cooling upgrades
the A8 only receive minor cooling upgrades.Those torque converter transmissions creates massive heat.
LG motor sports will set you up with a nice cooling system unfortunately warranty is voided if mod is added 17 7M car with significant cooling upgrades.
This is GM's passive aggressive way of saying we build a 1 lap track ready car in 15/16
If GM is redesigning the cooling process this is obvious fault.
Yale (05-17-2017)
#5098
Location: Syracuse-Central Square New York Winer of the all Corvette race WGI 8/23!
the 17' 7M is the only c7z that is truley track capable.
This was before the fins
#5099
z06 automatic is what I plan to buy in the next couple days... they have 0% on the 16's right now. I can pick one up, or go for a 17. Is it worth it to pay extra for a 17 vs a 16, or can i just fix the 16?
#5100
yes you can fix it, but I think it voids the warranty. sorry that's all I know.
