View Poll Results: If you've Overheated What is Your Stage Aero 1, 2 or 3
Voters: 348. You may not vote on this poll
ZO6 overheating issues ***MEGA Merge***
#5541
Would this new radiator require a high volume water pump also?
#5542
So my local dealer has ordered the parts for the "upgrade" I was told it includes only the new radiator and a re-flash of the transmission...
Anyone know exactly what is done under this new extended warranty?
A parts list would be nice if anyone has it!
I also had to provide a receipt from the track to prove I was on a track... One would think that the PDR video would suffice... anywho any more info would be nice
I still am unsure if I want to have then do it or not, as it seems it really won't improve the situation
#5543
The 2017 supercharger is the same supercharger as the 2015/16 model. The base assembly with the rotors is the same exact part number right down to the revision level. The difference between the two units is with the intercooler bricks, instead of lying flat in the supercharger base, they are tilted toward the front with the rear of the brick being quite a bit higher than the front. This is what necessitated the larger supercharger cover. Tilting the bricks improves airflow to the two rear cylinders Vs the flat bricks which don't provide as straight of a shot of air into the two rear intake ports. In the old version cylinders 1-6 have air blowing directly into their intake ports but the bricks end before they reach 7 and 8 so the air has to come out of the brick, make a right angle turn, and travel through a small channel before it gets to the intake port where it needs to make another right angle turn to go into the port.
Bill
Bill
#5544
I had concerns about this with a triple pass radiator and could not find any definitive answers, so I ended up going with a DeWitts 1139114M C7 Z06 radiator.
It's absolutely gorgeous, crafted by an expert in Michigan using industry-leading manufacturing equipment, and holds four more quarts of fluid than the OE radiators. While this bulletin called my attention to how paltry my OE radiator was I came to the conclusion that even the proposed GM replacement was going to be inadequate for me in Central Texas. While the revised and improved size of the MY19 radiator would surely be better than the one I have, I have this problem on my Corvettes where I quickly suffer from egregious scope-creep when I get into a particular project.
Sure, we all have our limits (a.k.a. the budget) and we always have to manage the bang-for-your-buck ratio, but when I did my LS7 heads on my 2012 Z06 for example, I ended up going with the NASCAR quality PSI 1511ML valve springs, Johnson 2110 lifters straight out of the COPO Camaro, Moldstar 90 valve guides on par with Formula One, an 8620 Carburized Nickel-Chromium-Molybdenum camshaft, superior Powerbond balancer, etc. You get the point.
I've always felt like if I'm going to go in and touch something on my Corvette then I don't want to reinstall it if I know there is something substantially better out there, particularly if I know it's part that GM consciously choose to skimp out on. Look no further at the current C8 LT2 valve spring issue (also affects the 6.2L V8's in the trucks and SUV's,) not to mention this entire drama over cooling issue on our C7 Z06's, (particularly so with the Z07 track package and A8's.) What're a few hundred bucks on a vehicle with an MSRP in the six figures? And my time isn't exactly free, either.
I ordered my radiator direct from DeWitts who has an annual sale going on right now through February 19, where they offer 12% and free shipping with discount code SUPER12.
After much research, I also figured I may as well do the heat exchanger at the same time while I will already have my radiator out and I need to pull my front bumper anyways to replaced a damaged lens one of my front parking cameras. I ended up going with an AFCO HX as I learned that DeWitts actually builds the core for the AFCO HX and then puts a baffle in it in order to create for a dual pass HX.
AFCO as I learned from a YouTube video when Vintage Motors toured the facility in 2019, purchased DeWitts in 2015. AFCO has an entire page in their 2021 catalog about their aluminum brazing equipment and their core standards, and this is actually all DeWitts. AFCO overall is a pretty cool company with a lot of cool products.
I attached the bulletin to this thread and here are the summary of parts for both A8 and M7. I'm sure the GM radiators are alright, just know that there are better ones out there and then it's up to you to decide what you put in your Corvette.
The following 2 users liked this post by BigVette427:
Fastmikefree (02-14-2021),
kdochert (09-15-2023)
#5545
My 1st Z06 was a 2015 M7. It never overheated with me, but that was because I didn't have enough experience driving the car to take it to it's max. I only kept that car 3 months and got a new 16 A8 that I learned to be able to take it to it's max and it overheated every time I took it to the track. I only drag race now so it's no longer an issue for me.
The following 2 users liked this post by 360Lemans:
Dane@LGmotorsports (04-05-2021),
firemark2643 (04-22-2021)
#5546
Update on the upper air baffle, GM PN 84872137. Save your money because it's the exact same upper air baffle that is already on my MY16. GM just superseded the part number, it's the identical mold with a sticker over the stamped PN. Waste of shipping and restocking fee on my end. Little reason that GM would suggest replacing it unless it's broken; it really doesn't need to be in the above bulletin.
#5547
I had my Auxiliary radiator installed this week. Took a bit to get GM to approve the "upgrade" but after a few days waiting on parts, they installed in a day. here's the kicker though, I swear there would be some kind of cut out under the splitter tray but I guess not? is there supposed to be?
here's a couple of pics: You can see the new radiator down there, the second is the splitter tray/1st belly pan but there is no cutout. I wasn't sure if there should be.
#5549
Just got mine fixed as well. Took about 2 weeks for the parts to come in, and my dealer had the work done in about 2 days. I won't be able to get to a track day until August, but will report back if I overheat on the same track with approx same ambient temps.
Boat Racer (05-18-2021)
#5550
Received 8,919 Likes
I think the kit that GM is installing is using some sort of bracket that gets inserted into the hole in the main inlet duct that stiffens the bottom of the duct. The GMPP Secondary Radiator just had two small brackets that clamp the secondary radiator to the bottom of the duct with two bolts on each side that are about 3 inches apart.
Bill
Telepierre (06-22-2021)
#5552
Don’t get your hopes high. I had them do the new radiator etc. Laguna seca yesterday started in the 60s and foggy. 15 minutes and I was at 250 degrees coolant ☹️ Im intermediate only running 1:43s. Paddle shifting and I was even short shifting mostly. I never tracked it without the upgrade to compare. All I can say is this certainly doesn’t “fix” the issue. Really pisses me off. Have to spend $4k minimum and hack the front bumper or spend triple that for something that looks better. 😠
#5553
New to this forum. I have owned multiple corvettes over the years. My latest is a 2015 Z06 A8. Been reading about overheating issues for a while but figured GM wasnt going to address it until enough people complained.
Heard that a class action lawsuit on this issue was recently dismissed so I didnt have high hopes. Yesterday I get a letter from GM saying that if I can prove that my Z06 overheated during spirited driving they will upgrade the cooling system and change transmission shift points. No specifics. I was excited and called the dealer to make an appointment for the upgrade but was told that I either had to have photos or video of the overheat condition or a computer fault code that had come up and could be retrieved. Otherwise no go. So its obvious that GM knows there is a problem but they dont want to dish out money to fix it unless you can prove you have had an issue with your car.
They should do this for every customer who wants it done. Should be a recall. It’s total BS. Every auto will overheat on track unless you shift at 4000-4500 rpm maybe.
#5554
#5555
90+ and very humid. I think it was closer to 100 at the track.
https://youtu.be/UKewxFsNHwA
Recent mods:
New 170 tstat
90% water, 10% coolant, Water wetter
Cut away the fan shroud
sealed up bottom of engine
full mods:
LG cooling kit including oil cooler
OEM supercharger hex as secondary radiator
Haltech intake.
#5556
#5557
I also upgraded the HX to an aftermarket dual-pass unit with more coolant capacity as well, but I think about the only other reasonable thing one can do is ensure that your CAC reservoir is properly bled, something that I don't believe any of the C7 Z06's were from the beginning. It's hard to imagine that the CAC reservoir issue could be the underlying sole culprit but every C7 Z06 I look at has a CAC reservoir with too much air at the top. Who knows, to each their own, I'm not tracking my Z07 much more than a few laps or quarter miles passes, anyways. (But that doesn't mean Tadge should be left off the hook, either.)
#5558
My car is getting done as we "speak". I got the letter and thought GM was just going to do it, but they do require proof. I am not a big "track day" guy but overheated on the 3rd lap. It never occured to me to record it or take a picture. I was a bit nervous at the time and didn't want to blow a head gasket. Being a technician myself, i just wanted to get off the track and cool it down. It didn't need to be a recall, but sending the letter to us AND requiring proof seems strange to me. At least they are trying to help. And to the other guys, just install a Cordes ice tank. It looks nice and adds capacity enough that it won't overheat. If it's in the budget, add an AFCO heat exchanger and you wont have any issues. I was afraid the tank would void the warranty, but it wont. I'm gonna stick to drag racing it now, anyway!
#5559
