View Poll Results: If you've Overheated What is Your Stage Aero 1, 2 or 3
Stage 1 Aero
23.81%
Stage 2 Aero
19.41%
Stage 3 Aero
56.78%
Voters: 273. You may not vote on this poll
ZO6 overheating issues ***MEGA Merge***
Old 03-27-2015, 01:51 AM
  #1821
Lavender
CF Senior Member
Originally Posted by chevyfanatic View Post
Wow. I dont track my cars but thats total BS ! I mean the car has oil coolers on top of oil coolers in it ! wtf !
And never herd this about the ZR1 or even old Z06 although it gets toasty in traffic. lol
Then you didn't try hard enough I've had my dads both C5Z and C6Z overheat couple of times on me.
Lavender is offline
Old 03-27-2015, 02:55 AM
  #1822
Kingspoke
CF Senior Member
Kingspoke's Avatar
Isn't 18-55 PSI oil pressure a little low under race conditions? Interested to know.
Kingspoke is offline
Old 03-27-2015, 03:37 AM
  #1823
heavychevy
CF Senior Member
That is disappointing if true.
Ask Tadge?
heavychevy is offline
Old 03-27-2015, 06:21 AM
  #1824
descartesfool
CF Senior Member
descartesfool's Avatar
Ask Tadge?
descartesfool is offline
Old 03-27-2015, 07:51 AM
  #1825
Fastmikefree
CF Senior Member
Fastmikefree's Avatar
Originally Posted by VY427 View Post
Well said.
I fully agree with what you said.
However, I am still worried since we are in winter and overheating after a lap might impact all the non pro driver that we are in summer time. What will happen when simply stock in traffic jam or trying to have fun in a hot day?
Wait and see...
Fastmikefree is offline
Old 03-27-2015, 08:18 AM
  #1826
Lavender
CF Senior Member
Originally Posted by RedLS6 View Post
It's well known on the C5Z. I overheated both my engine oil and my transmission oil in my C5Z at VIR, running it bone-stock with tires, at a 2.07-2.08 lap pace. With a separate engine oil cooler, my oil still hit 275-280 degrees. My manual tranny would routinely throw an overtemp warning at ~276 degrees, but it usually took me ~20 minutes to get it there.
Sometimes when you can't complete a single BTG lap @ Nurburgring in a C6Z because its overheating... You know it's time for some upgrades.
Lavender is offline
Old 03-27-2015, 08:21 AM
  #1827
DerStig
CF Senior Member
Originally Posted by descartesfool View Post
FYI the Z06 and Z51 use the exact same radiator, part #23217826. I confirmed this with GMPartsDirect.
Z06 had 650 HP and Z51 has 460 HP.
That cannot be right, can it?
DerStig is offline
Old 03-27-2015, 08:37 AM
  #1828
skank
CF Senior Member
Originally Posted by DaveN007 View Post
I can also assure you that there was a Z06 on the track. A8. Laguna blue. Yellow calipers.
Dave, any specific reason why your using both ChrisN123 and DaveN007 to get this overheating point across? We all know that you are "The Most Interesting Man In The World Of Storage"
skank is offline
Old 03-27-2015, 08:41 AM
  #1829
GP1224
CF Senior Member
Well said.
You dont sell a product claiming what isnt true. The Z06 with skilled drivers that run TTR or TTU even will have this car on its knees in a few laps. All that is asked is better cooling!!!
GP1224 is offline
Old 03-27-2015, 08:45 AM
  #1830
DerStig
CF Senior Member
JESUS! 302 oil temp? BMW and Porsche's oil temperature gauges do not even have a range that covers 302 degrees!
DerStig is offline
  #1831
Fastmikefree
CF Senior Member
Come on, see the positive side! 5 laps is one more than Randy!!!
Let's call the Guiness ;-)))
Old 03-27-2015, 09:21 AM
  #1832
peterjank
CF Senior Member
Originally Posted by quick04Z06 View Post
Hoping to see similar products available for this Z, that they solve the problem, and some indication adding them won't kill the GM warranty.
Before taking delivery of my new Z06, I asked my salesman to check if adding an aftermarket radiator and spacers between the supercharger and engine block would impact my warranty. I received an e-mail back from the head of the dealer's service department that installing those items would not impact the warranty so long as they did the install.
peterjank is offline
Old 03-27-2015, 09:31 AM
  #1833
etekberg
CF Senior Member
etekberg's Avatar
Probably not at 302 degrees!!! The oil probably has the viscosity of alcohol at that temperature.
From an article I read, Mobil 1 was tested to start thermal breakdown at 265 degrees.
etekberg is offline
Old 03-27-2015, 09:35 AM
  #1834
Babaron
CF Senior Member
Babaron's Avatar
Was this car prepped for the track and if so, how? Mileage?
Babaron is offline
Old 03-27-2015, 09:45 AM
  #1835
Crabbers
CF Senior Member
Crabbers's Avatar
Originally Posted by ChrisN123 View Post
The PDR wasn't in lap mode, so just a blob of laps...Anyone know how to specify start/finish after the fact?
Anyway, screen shot show max Oil temp 302; Max water 262; Max Trans 212
Crabbers is offline
Old 03-27-2015, 09:54 AM
  #1836
harlold
CF Senior Member
Those temps, can't be good for longevity - lord.
harlold is offline
Old 03-27-2015, 10:15 AM
  #1837
Fastmikefree
CF Senior Member
That is why GM is working on a solution! They have reduced the warranty period
Old 03-27-2015, 10:33 AM
  #1838
quick04Z06
CF Senior Member
quick04Z06's Avatar
Well, 99% of the street cars in the world will overheat at the racetrack, be they American, European, or Asian. I've seen many cars running hot at Road Atlanta, Roebling, and Barber, of all makes. I had just hoped this car, at least in Z07 guise, would not overheat because this was a known issue with the C5 and C6 Zs and I had hoped Chevy would address it, like they have done with many other issues.
We'll just have to wait for the aftermarket to catch up like we did with the C5 and C6 Z cars.
I am tired of beating this horse, so I will check out on this issue. It really isn't that big a deal. As the saying goes now, "it is what it is...." The C7Z is still a fantastic car....
quick04Z06 is offline
Old 03-27-2015, 10:37 AM
  #1839
QUIKAG
CF Senior Member
QUIKAG's Avatar
Ouch!!!
262 coolant and 302 oil temp in 5 laps at Laguna in 80F temps is just unacceptable.
QUIKAG is offline
Old 03-27-2015, 10:42 AM
  #1840
ChucksZ06
CF Senior Member
Have you looked at the size of the coolers? They are way to small. The aftermarket will solve this with larger coolers and additional oil capacities and aftermarket radiator. Great car but gm missed the boat on cooling capacity for track use...that is obvious. I do not expect significant changes in the next model years as far as the overheating issues are concerned. The car is selling well and most owners are not tracking car so if you are gm why change.
ChucksZ06 is offline
Quick Reply: ZO6 overheating issues ***MEGA Merge***
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
