★C7 / Z06 Blockit Sound Deadening Mats- Reduce Interior Noise In Seconds!
Premium Supporting Vendor
Location: ★ Performance Parts & Accessories ★ 1800 778 9898
St. Jude Donor '07-'08-'11-'12-'13-'14-'15-'16-'17
Allow us to help create the perfect comfortable driving experience!
________________________________________ _________________
Blockit Quick & Quiet "Drop in" Pre cut mats
Reduce noise in SECONDS! (3 Piece Set)
Available In Coupe & Now Convertible
• Quiet down your Corvette interior in SECONDS!
• Pre - Cut & lays right over your factory carpet!
• 4 Infused Layers of REAL acoustical soundproofing materials
• Great for exhaust, tire /road noise and long trips
• UV protected top layer is durable & looks great
• Feel free to lay an aftermarket carpet on top!
• 3 Piece system!
• Helps keep your cargo or trunk area cooler!
• No Adhesive. All pieces are removable & reusable!
• All raw materials are from the USA!
• Made in the USA!
• Manufactured under strict ISO 9001 regulations
Reduce interior noise in SECONDS by simply dropping in the pre cut BLOCKIT sound deadening mats right over your existing carpet!
This is NOT a thin one layer mat.
The BLOCKIT is a unique 4 infused layer combination of real acoustical soundproofing which measures 1" thick!
It absorbs and suppresses unpleasant sounds that leak into your C7s cabin.
It’s perfect for taking that annoying edge off tire / road noise & some aftermarket exhausts.
NO need to rip out your carpet & interior! The precision pre cut BLOCKIT Sound Deadening System lays right over your carpet!
Fits C7 & Z06. One large piece fits perfect in your cargo area. One piece goes behind each seat.
For the Coupe, rather then large sections removed, we have small precise cut outs for the cargo hoops.
These maximizes the amount of sound deadening material for noise reduction.
The durable UV protected top layer looks great and allows you to still use your cargo area. Feel free to place an aftermarket cargo mat on top!
A huge hit when it was released for the C6!
Below is a list of some threads from many satisfied customers/forum members.
Within theses threads you will find a ton of others posting their positive results with the Blockit too.
http://forums.corvetteforum.com/c6-c...ation-mat.html
http://forums.corvetteforum.com/c6-c...e-product.html
http://forums.corvetteforum.com/c6-c...ning-mats.html
http://forums.corvetteforum.com/c6-c...d-deadner.html
http://forums.corvetteforum.com/c6-c...irst-ride.html
http://forums.corvetteforum.com/c6-c...rformance.html
http://forums.corvetteforum.com/c6-c...post1573973170
http://forums.corvetteforum.com/c6-c...-block-it.html
On Sale 10% off
★ For Coupes: Click here to check it out and order:http://store.tkoperformance.com/20c7blsodesy.html
★ For Convertibles: Click here to check it out and order: http://store.tkoperformance.com/2020bldinsod.html
__________________
Serving The Corvette Forum For 21 Years!!
Allow us to add you to the list of extremely satisfied customers.
Order Securely Online 24/7: http://tkoperformance.com/index.html
Feel Free To Contact Us By Phone: 1800 -778- 9898 Monday- Friday 9:00am to 4:30pm
Click Here: http://www.facebook.com/pages/TKO-Pe...e/367433626633
Some real positive posts I found
Having had Blockit in my Z06 - I thought it did a great job reducing noise so I added it to the C7 - Z51.
It arrived packaged well. Easy install with a precise fit. I was able to use the rings and shade. I found it able to make a nice noise reduction on all surfaces around Little Rock including interstate and different road surfaces including concrete and asphalt.
I'm very happy with the product!
Installed on my C7 Z06. TRANSFORMATIONAL! The reduction in tire noise is astonishing. Being an engineer I had planned to use my laboratory dB meter to measure noise levels with and without the TKO Blockit kit. As it turns out there is no need to do so because the noise reduction is truly dramatic. This kit is a "must have" for all but deaf C7 owners. I had a '14 Z51 which had hellacious tire noise. I was exhausted after driving it for 3-4 hours. The '15 Z06 was significantly quieter and rides more smoothly....think Chevy vehicle engineers softened the suspension bushings. Seems to be well known that the '15 is a quieter car. Just can't believe how such a relatively inexpensive and easily installed kit can be so effective. I could now drive the car across country....yes, it's that good.
Well, I had a chance to test drive my car on some roads that previously had some serious tire noise due to the road conditions. For the ease of installation and simpleness of the product; I'm very pleased with the it. I was able to lower my radio volume from where it used to be, and hold conversations without raising my voice. In fact I am now aware of other noises that I hadn't previously heard.
So bottom line: I'd recommend(your hearing my vary) .
I can't say it's equal to the kits that require full interior dis-assembly since I didn't do that, but I definitely feel there is value in the product. If you are in Southern Calif and want to try in your car, come by and we'll throw it in and you can hear for yourself. Or just take my car for a test drive.
Tom
Tom
Here are a few quotes I grab from another running thread..
Its been out since 2008. Below is a list of some C6 threads from many satisfied customers/forum members.
Feel Free to contact us if you have any other questions.
Thank you
Thank you
Thank you
Thank you
All orders have shipped!
Thank you.
Some answers to common questions:
Can I access my cubby compartments?- Yes. Simply lift the corner of the Blockit just as you would any mat or aftermarket carpet.
Is the Blockit Quick & Quiet hard to install?- Installs literally in seconds. Just place the pre cut cargo mat over your existing carpet.
The 2 rectangles drop in behind the seat.
How do the pieces behind the seat go?- Move your seat forward and place them behind the seat and against the carpeted wall. It leans on an angle to it stays up. Plus the foam against the carpet acts like Velcro.
Does it really work?- Yes. You will be surprised at how well it the Blockit suppresses & absorbs interior noise. You will notice as soon as you start the car. It won't turn your car into a Cadillac. But it does a great job with tire/road noise. Just ask anyone from TX
How does the top layer look? - Its a black textured layer which looks very nice and blends in very well. Any wrinkles you get (from being rolled when shipped) go away over a short time.
Can I still use my cargo area? Absolutely. The top layer is durable enough so that you can still use your cargo area. Its also UV protected.
How much does the quick & quiet system weigh? - Since we just added more barrier (for even more sound deadening) it weighs approx. 14lbs. However it weight is an issue (race, event...) just take it out. Takes seconds to remove it. Remember there's no adhesive, the system is removable and reusable.
How well is it made?- Very well. The layers are held together by a unique proprietary infusion process which prevents separation. No glue, so no smell.
All done under strict ISO regulations. All made here in the USA.
Can I use my cargo hooks?- Yes. We make small precision cut outs to accommodate the hooks. We make them dead on for size to leave more material to suppress & absorb sound.
I hope that helps. Any other questions, please feel free to contact us. 1800 778 9898
Thank you!
Thank you.
Thank you!
Block It
Installed it a few weeks ago. It eliminated much of the road/tire noise which interfered with listening to the radio or a passenger. I'm really happy with Block It-I can still hear enough of the exhaust to appreciate it.
TKO Performance (11-18-2015)
