Starting Over: C7 Z06 Overheating Issues
#41
The car will not go into a limp mode at 256*. At 256* the car shuts off access to the A/C whether or not it is running, gives you an overheating warning, but let's you press further until 262*. This is all you wanted from me right?
However, the part about my PS overheating despite the A/C being off didn't interest you that much. You don't believe me. Ok, you can tell folks that as long as they keep their A/C off the PS won't go out on them. You can also tell them that the manual cars don't overheat.
This is really how you feel, as you stated:
"I am trying to temper this wild prevailing attitude that the car is untrackable as that is false."
So why not call the thread that? Why make it sound like you are trying to distill information for people when you want to put a spin on things?
I think it's obvious that just about any car is trackable with the right driving pace and style. But who gives a damn? Do you aim to drive this car like Pobst, and should expect 6 minutes of run time @85, or should you aim to drive this car like a beginner and run one set of pads every 20 track days? Who do you learn from, the beginner or Pobst?
What distilling the information should really say:
"Amateur drivers can easily overheat the coolant and power steering unit in the C7 Z06 on track days. This is true regardless of whether they optioned the car with a manual or automatic and turning the A/C off doesn't always work."
Do I care that not all amateurs can overheat the car? No, no I don't.
#42
#43
I think that by now we have ample evidences that the car, be that the base, the Z51 or the ZO6 variations are very prone to overheating. I see this statement, "wild prevailing attitude that the car is untrackable as that is false" simply ignoring the most obvious.
I tend to suspect more and more that there are no real individual cooling differences between cars. Given an aggressive driver, a track with ample low gear corners, pretty much all C7s will overheat. Two Edmund pro drivers overheated the Z51 within a dozen of 2nd and 3rd gear corners in mountain driving. Guess, what? I can replicate those exact same scenarios over my local canyon roads. Yes, I can keep my temps under the warning levels IF I chose to shortshift to keep the RPMs down. But, the fact is that the car still overheats when driven all out.
So, as I proposed before, instead of aiming to point out flaws in other people's experiences or observations, we should concentrate to make our cars NOT OVERHEAT, regardless of the track, the competency of the driver or the ambient temps. Plenty of cars out there can deliver exactly that, why not ours?
#44
Daaaamn. Everyone chill.
Remember.....us younger vette owners grew up with the internet's, and don't get offended by written word.
With that said, let's get back to the original issue.
On a side note: The latest ask tadge Q and A, both sidestepped the main issue.
That issue is: who is taking responsibility for this at GM. They can say they are aware of it......but who is responsible for the fix?
#47
I thought it would be a mistake to let people drive their cars up to 265* thinking that it's safe to do so.
I didn't think it would be wise to let people think they can avoid losing powersteering by simply turning off the A/C. Losing steering assist is not to be taken lightly, you can easily end up in a wall. I also didn't think it was fair for those that reported loosing power steering for people to think they were tracking with the A/C on. Most guys that track have the common sense to turn it off, especially in a car that is prone to overheating. Not that it should happen anyway, it's nuts to have electric powersteering cut off for any reason.
#48
Well, I tried. Correcting misleading information was my way of contributing.
#50
#52
Looks like this thread is going the way of the mega merge. I am going to post another overheating issue, my 3rd one for PS. Other one is on Mega merge. haven't seen anymore posts regarding overheats there. Last time I tracked the car I did the prep by the book, exactly they way GM says to do it. This time I did not run AC at all and went to 20/80 mix coolant/water. Didn't make a difference except maybe a couple of laps before it overheated
I was not pushing the car hard, its a very short track and in fairness there are 13 turns in .9 miles. But I know of many public road where I live that have that many turns in a similar distance. I reported this a couple of weeks ago, same track, 97 degrees and engine and PS over heated but couldn't get a picture.. This time I got pics. Not great ones, but best I could. Today as follows:
Ambient air 96degrees
Humidity 25%
Altitude 4500ft
Grand junction raceway
I was short shifting the car or it would have overheated too. water temps close to 265 degrees and oil up to 285 so I backed off. As you can see I got the PS warning at lower temps. What is the consensus at this point? they over heat if driven hard and we are screwed? I should have run it a little harder and got another engine over heat with pic to start building a case. 4 times is lemon law in Colorado. Love the car on the road and day to day, but I don't push the car very hard maybe 6/10-7/10 at track today? Lots of time going slow trying to hit the exact line.
Looking at recent posts, it looks like overheating is a given in many track scenarios. IS everyone resigned to that situation and looking at different radiators etc to make this car work? Are we stuck? Does GM give any indication of dealing with this?.....bob noob
Humidity 25%
Altitude 4500ft
#53
Brutal.
Brutal.
#54
Humidity 25%
Altitude 4500ft
Humidity 25%
Altitude 4500ft
What setting do you have your steering set on? I keep mine on race and have no issues. A buddy of mine had his on sport and has issues all the time
#55
You are right and the NHTSA agrees with you. They forced Ford to recall a large number of vehicles for a software change for this very reason. Electric PS that would cut out at high temp. Revised software shows a warning indication but does not shut it off.
The steering should protect the driver at all cost, never shut down a vehicle control system to protect itself.
I think folks that have experienced PS shutdown, especially if it has happened on twisty public roads, need to report this to the NHTSA. They take these reports seriously and can effect a fix from GM.
#56
Humidity 25%
Altitude 4500ft
Humidity 25%
Altitude 4500ft
"We have discussed the Z06 cooling robustness in this space before and are very concerned about what some customers are experiencing. We have built over 8,000 Z06's so far with the vast majority of them having no cooling issues. We are working to gather data from customers (some of whom may have posted here) who have concerns and are in the process of sorting through that. We have found a few build issues, a few prep issues, and some vehicle mods that have hurt cooling performance. An example of a build issue would be an improper bleed of the intercooler circuit. Even a small air bubble can impact performance."
Perhaps yours' is one of the build issues Bring it to the dealer you bought it from, show them Tadge's admission and do not take no for an answer.
Hate to read a story like this so best of luck resolving it.
#57
Humidity 25%
Altitude 4500ft
Humidity 25%
Altitude 4500ft
Have you thought about doing SBC and a Stick's PS mod that gets more air flow over the PS electric motor? Takes about 10 minutes when you have the parts ready to go, which cost about $5!!
Bish
#60
Hi Bish, thats the next step. When I was last under the car it looked pretty easy to do and ingenious! To be fair, the course I ran is slow and tight so one is not going to get a lot of air through the radiator, but anything would help. I have overheated engine and PS numerous times both times I was there. driving smoother lines on that course helps. Other corvettes run it with no problems according to the track manager and the western colorado corvette club races there a couple of times a year so its not all the track but it contributes. I am documenting these problems with a dealer that is willing to help me. My dealer closed 2 months after I bought the car. Double wammy! bob noob
