Any more thoughts on leaving track alignment for street
Last posts I could find on this were in May. Just curious if anyone has put some miles on the street with the track alignment and how did the tires wear? I read that some think track alignment is ok for street and won't wear your tires that bad.
If I wanted to keep changing the alignment, its a long way (2hrs) and expensive. I read the suggestion that setting camber somewhere in between like -1.7 instead of -2.0. may be a good compromise, but others have said that running full track alignment on the street isn't that bad on wear (inside). Also, does more negative camber make if difficult to drive uneven crowned two lane roads? The stock specs work very well for that. Any new thoughts on track alignment for the street? thanks............bob
I set mine to -2.0 front and rear a couple of weeks ago and intend to leave it that way. 3-4 track weekends per year and less than 5,000 street mile per year anticipated (2,000 at this time). Have not noticed any negative aspects RE uneven surfaces, straight line tracking on highway, etc. Only have couple hundred miles on alignment so far so can't comment on tire wear. None showing so far.
My Z07 tires were wearing very fast! all street driving no hard turns! I had Stacek chevy in Wheeling IL (very Experienced corvette dealer) same guy doing corvette alignments for 20 years He said my car was set up for aggressive track and that's why the tires were wearing so quick (only 2300 miles) he then gave me a street alignment test drove 3 times to be sure all was good.. tires should last much longer now? I dont track my car so this is a good idea if not tracking your car $$$ my new alighnment seems great no pulling stays straight as a arrow!
I have mine set to -1.3 on all wheels for road usage. I do not track my car but, most of my driving is spirited winding, mountain roads. With my other cars that I've owned for longer years, I had my cambers similarly at -1.3 and -1.4 and got perfect wear out of them across the full thread. Again, that is by doing mostly winding road driving.
-1.7 is not considered extreme for the road, particularly for the front. For the wider rears -1.7 may show some extra wear for the inside edges. I would probably go -1.3 for the rears. Unless you track a LOT and drive very competitively, these values should work for you quite well.
Also, the camber should not give you any issues with the road conditions you describe.
100 bucks for alignment or over 2000 for tires hmm.
z51vett
Doug
z51vett
Doug
I'm thinking about setting mine to track alignment... the difference was immediately noticeable on the Spring Mountain cars. The car feels more responsive and just wants to turn with track alignment. I liked it.
The inside of the PSS tires are harder rubber than the outside, so perhaps the wear issue won't be that bad?
Great comments from all. Sounds like a mixed bag.
JTSZ07, do you have the cup 2 tires on for street? They will wear very quickly, I have read here they are good for about 5K max on street.
Davester, I expect I will do similar, 3-4 track days/yr and about 5K on the road give or take. Let us know how you do as you get some miles on the street.
AXR6, I drive like you on the street here in colorado. So a compromise might work. I believe Bish suggested in May Post -1.7front/-1.5 rear so if I do a compromise might try somewhere in that range.
No doubt, best to do track alignment and then switch back after each track day, but I don't have access to anyone within 2 hours plus it takes another hour to get it done if they aren't busy. so each track day would cost me a day just to get alignments done. I can't get it done here for $100.No doubt they will wear very fast on the track if you DON'T to it!
I have to take car to dealer anyway for dead USB ports, and power steering overheats and engine overheats so might get track alignment done and see what happens. I know they won't be able to help me on the over heat stuff, but i am going to keep reporting it, and its not only on the track thanks all. ....bob
I have mine at -1.7 and with 6100 miles over 7 months on PSC2's and 1 track day. Just got my PSS's in, the cup's still had a bit of life in them, probably could have done another track day. I'm pretty easy on them with street driving but the alignment hasn't seemed to do too much damage with street driving.
I use the Cups and have not noticed street wear to be a big deal. The track weekends destroy the tires and especially the outer sides a lot faster than the effect of the increased camber on the tire street wear.
I leave mine in track alignment all the time. I have about 7000 street miles that way on the car. It handles fine on the street, but does feel quite a bit more "twitchy" and will follow street camber more. It's not a big deal though and you get used to it real fast.
Tire wear with specified track alignment
I just had the dealer replace my brake fluid with Wilwood 600 for upcoming track days. I have a 2016 Z06 and had dealer do a track alignment at 3600 miles. I did 2 road course dates and 1 track day on the Tri-oval of Pocono Raceway. car has 5900 miles on it and the front tires are COOKED. so, the track alignment per the manual was kept on the car for just 3 track dates and around 2200 street miles and the steel belt is exposed on the inside of both tires. (see pics). Replacing tires tomorrow before Pocono on Labor day and have decided to go back to regular street alignment. I can deal with replacing tires once a season but every 3000 miles? Plus, Chevy charges $250 for an alignment because they claim it takes more work and had to remove some washers from the upper control arms.
Depends on how much driving you're doing. I personally keep the track alignment on (-2 camber front, -2 camber rear) I've had my C7 since Feb '16 and it has 4,600 miles. 1,000 of which are track miles. I only ever drive it on the weekends to car related events and the occasional joy ride. Inside of the tires look fine, but again I'm not putting a ton of miles on it. If it is your daily driver or you drive 8,000+ miles a year then you may consider reverting the alignment, especially if you do not do many track events.
i will have to get the alignment checked then. I drive the car HARD on the track but would have ASSumed the tires would last a little longer than, essentially, 2300 miles (300 on track and 2000 street). I might use the PFadt Performance numbers which is middle ground between stock alignment and track alignment.
Received 8,915 Likes
Bill
tires
No, .05 degrees toe in per manual. ASSuming dealer was accurate. Getting alignment done by high performance shop. It will be interesting what they find.
The cars handle better, even on the street. with a track-ish alignment.
It really depends on your usage. If you get to the end of your tire life and the tires wore pretty evenly overall with street/ track/ canyon then your alignment was a great compromise for your application.
If your tires are corded on the inside and still have tread on the outside, well you either need to adjust your alignment for street usage or drive faster at the track.
I get pretty even wear doing a few track days but mostly straight line street driving. Toyo R888s, about 5K miles, running -2.1 F and -1.6 Rear.
I've found that I always wear out the outside of the tires even on my street driven cars. So...
I just put a more aggressive alignment on the car and intend to street and track drive it. Decided on an in-betwee of -1.5deg camber all around, 0.05 toe in front and rear. Camber in the back should now be +0.8 assuming they did it correctly.
I left the track alignment on and with one track day and 5200 miles i was into the wear bars with no cording and actually the outsides i think were more worn than the insides. PSC2s. recommended minimal toe in 0.5 and -2.0 front camber -1.7 rear camber with 0.8 rear caster from memory.
I think I couldve taken them to 6500ish but have been traveling with my kids a bunch long didstance so was a sissy.
I think half the tread is below the wear bar.
