Sponsored by: GEM Motorsports
Official C7 Z06 Fast List - Provide all information and Slips/Video
Old 06-29-2017, 11:25 AM
  #321
mike123460
mike123460's Avatar
Originally Posted by Thomasmoto
I made a small improvement on my PB 6/23/17 at Zmax Dragway Charlotte NC in hi ambient temp of 88 degrees and very humid. Had a good time none the less.
I'm #4. Slight improvement on my PB.<br/>10.45@133.46 @ Zmax Dragway 6/23/17<br/>88 degree ambient temp
Mods since last PB post. Cam, custom Comp Cams grind, Kook's headers 1 7/8's & off road pipe, no cats,into stock NPP muffs, both blower pulley's, Halltech CAI, 100 octane unleaded fuel,head gasket insurance, custom tune-PCM of NC, 50 shot of nitrous for intercooling due to short cool down times between rounds at the drag strip and to aid heat soak issues. Nitto NT05R DR 345-30-19's at 25psi. DeWitt's Z06 cooling "kit" radiator, larger EOC and supercharger cooling heat exchanger.
TOUR mode TC off only.
I feel like you should be low 10s/high 9s with that setup. Expecting to run that, no cam, only upper pulley, no nos.
mike123460 is offline
Thomasmoto (03-26-2021)
Old 06-29-2017, 12:49 PM
  #322
Thomasmoto
Thomasmoto's Avatar
Received 1,505 Likes on 1,027 Posts
I agree with you. My tune is just too conservative and the trans needs to be tuned as well. I'm working on it. All in all it was too bad that day. I was still covering 2 Hellcat's, 3 hopped-up Mustangs, and was 1 of only about 3 different cars to get into the 10's. It was very hot and humid and the track wasn't prepped near what it should have been. That track lays dormant way too much. They don't have a weekend bracket program or regular test & tunes. It's really a shame.
Thomasmoto is offline
tail_lights (06-29-2017)
Old 07-09-2017, 06:52 PM
  #323
2015 Z0SICK
2015 Z0SICK's Avatar
Default 10.348@ 133.68
1st time at the track with my C7Z. Temps weren't great 85-90 degrees al day. My best pass was a 10.348@133.68 with a 1.594 60' My best mph was 135.76, this was on a 10.443 pass
Please add me to the list
M7
Bolt ons
lower pulley
e85
headers, X pipe w/ cats
cai
tune
drag radials
tank for heat exchanger
2015 Z0SICK is offline
Old 07-09-2017, 06:54 PM
  #324
2015 Z0SICK
here is the pass with the higher mph
  #325
2015 Z0SICK
thjis was at Atco
Old 07-09-2017, 07:04 PM
  #326
2015 Z0SICK
I calculated DA to be 1858
Old 07-21-2017, 05:42 PM
  #327
racedrvr
racedrvr's Avatar
It's been very difficult to follow this fast list. Has it been updated since last October, post 255?
racedrvr is offline
Old 07-23-2017, 04:14 PM
  #328
Higgs Boson
Higgs Boson's Avatar
Received 2,379 Likes on 1,238 Posts
Snorman sent me his last updated excel file last night. I will make an effort to fix the thread.
Thank you for your patience.
Higgs Boson is offline
The following 2 users liked this post by Higgs Boson:
OnPoint (07-25-2017), tail_lights (07-24-2017)
Old 07-23-2017, 11:05 PM
  #329
BooSSted
BooSSted's Avatar
Glad someone is heading this up!!
BooSSted is online now
Old 07-24-2017, 10:00 AM
  #330
Thomasmoto
Thomasmoto's Avatar
Default drag radials?
M7
Bolt ons
lower pulley
e85
cai
tune
drag radials
What drag radials do you have? Rims? Pressure? And what mode do you race in?
I'm finding that most of us drag race in Tour mode with just TC off, but I have seen a few lately that say they use Race mode and get higher shift points by doing so. I'm just wondering if that is accurate. My thought is that in Tour mode the car transfers its weight better to aid 60' time.
Old 07-24-2017, 12:48 PM
  #331
2015 Z0SICK
I ran Hoosier 315/30/18 on C5 Zo6 wheels in rear and Race Star 18x5 w/ M&H tires on front. I ran 17psi in rear, 45psi in front. I raced in Track mode with PTM in Race. My car is a stickshift so I can pick my shift points, but i powershifted right around 6600
Old 07-24-2017, 03:59 PM
  #332
C7/Z06 Man
C7/Z06 Man's Avatar
Default Thomasmoto
If you don't spin, it does not matter what mode your in. The 60' 'should' be the same, by using track mode with an A8 it 'may' have firmer (more trans pressure for less internal slippage, Humm) quicker and higher shift points. However, I am not sure of these 'A8' statements.
I just rotate the **** to Track Mode and push the center button once to turn TC "off". I have tried touring in the past because it makes sense but found it not to really preform as well. 1.53 60's on the MPSS tires have always happen in Track Mode. Drag radials should be a piece of cake i.e. 1.4's/1.3's if you have the power which I believe you do! One last suggestion, my best 60's come when I launch with some rpm's, usually the higher the better, say 2000 and then experiment +/- from there. Loading the suspension may be the better thing to do.
Bill
C7/Z06 Man is offline
Quick Reply: Official C7 Z06 Fast List - Provide all information and Slips/Video
