C7 Z06 Blower upgrade?
I currently have a bone stock 2015 corvette z06. It's a seven speed car and I was very happy with 650 horsepower until I got used to 650 horsepower. I know they have pulley upgrades for the stock supercharger but as far as I know the TVS R1740 is already spinning at a little over 20,000 rpm and is nearly maxed out. I know pro charger has a few different kits available pushing past 1,000 hp but I don't want to switch to a centrifugal supercharger. Since I've started thinking about upgrading I've wanted to use the ls9's supercharger but since it uses port injection instead of direct injection and the heads aren't compatible I don't think this is even possible. I just want to know if there's any supercharger upgrades out there for these gen 5 lt4's without upgrading the stock blowers or switching to a pro charger. And also how much boost can I push on the stock motor? I know I'll need to upgrade the fuel system to some extent also.
Former Vendor
Little info on the 2300 edelbrock set up. some cases 120 rwhp increase over stock along the power band
https://www.corvetteforum.com/forums...6-upgrade.html
You also spin the 1.7 faster add a CAI and a tune and get 700 at the tires which will require running DR's on the street. Going much above the 700 level with a bigger SC, cam and headers to get to 800 will not be usable except a very high speed on the freeway.
The HP/TQ levels should be limited to the available traction levels.
DRLC5 (01-10-2016)
Vengeance Racing is all I got to say ... Don't try to piecemeal it. Do it right the first time . They answer there phones and do what they say they are going to do.
https://www.corvetteforum.com/forums...-pump-gas.html
My friend Ron had them do his Lt4 makes 750 wheel
Has anyone combined the magnuson setup with nitrous? I'm wanting a little more than 750 I've heard good things about the magnuson supercharger and that the drivability has little to no change with it.
Former Vendor
Whipple 2.9 is the one im waiting for but require taller hood or cut it like the callaway set up. The 2300 edelbrockwith 15psi/meth and 2" headers/no cats and the new borla 3 inch atak coming out that will keep the valves will do 800 just will need to keep a eye on fuel pressure
Former Vendor
The whipple 2.9 will make more power yes. 40-50 rwhp at same boost level vs the 2300s from what ive been seeing. Downside yes you do have to cut the hood but the whipple top i think looks better anyway.
Black will look killer on color
NYROBZ06 (01-10-2016)
I assume torque levels with be comparable.
Former Vendor
Yes it will. Overall more power options. Im looking into seeing if there is a interest for a 3.4L blower option also for us. If i can get a 3.4L made for us will give us so many power options and keep IAT temps down.
Are there any meth kits available that are compatible with magnuson 2300? And what kind've power gains would I be getting with the magnuson 2300 with the addition of water/meth?
Is any fab work needed to fit the f1x head unit on the lt4's? And what other upgrades would I really be needing to run it at around 20 psi?
Hey everyone! Went with the magnuson! Also gonna be ordering a set of LG motor sports longtube headers and full exhaust. At some point I plan on adding water/meth and maybe a little bit of nitrous! Thanks everyone for the help!
Former Vendor
Magnacharger doesnt have a bolt in unit yet.
