Pilot Super Sports evil in heavy rain
Just returned from a drive down I-95 to Florida in heavy rain. I took off my Pilot Sport Cup 2's and purchased the Super Sports because Michelin said that they were fine in rain. But in heavy rain when there was a small layer of water on the asphalt, the car really danced around and felt evil. Not fun
Interesting, I've driven the MPSS in pretty heavy rain and didn't think they were 'that' bad. Certainly they weren't as good as all season tires, but I wasn't dancing all over the road either. Either way, caution is the best approach in wet weather at 65-85 mph.
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
ibjimman
IMO the MPSS are the best rain tire you can run on a Z06 Corvette I've gone through about 5 sets between my C6 and C7. I have run many tire brands and the MPSS are hard to beat,...with that said you have a "stupid amount of power for the street and need to respect it in the rain". Yes the car does dart in the rain depending on your alignment and front "Toe" setting. Are you running zero Toe? You may want to check it, zero Toe is great for the track but sucks on the street. I run 1/8 toe in, which is standard for the street. It make a hugh difference.
2017 C4 of Year
I had the same issue going across Utah last year. A few times I just pulled off the road at the next exit and waited for the real heavy rain and pooling to stop and then get back on the road. I recorded it on the PDR just in case. I would post it but the amount of profanity may be an issue
I believe this is due to tyre width and not the actual characteristic of a specific tyre. In fact of all the street tyres available in OEM sizes, I'd bet the MPSS is the best all round tyre by far, including wet performance.
Bish
Bish
when I can. The non run flat SS is better in all respects.
I've been running the P-Zero runflats. They are pretty decent in the wet. My z07 is a daily driver so it hit a lot of rain.
However, the p-zeros have been a huge pain due to leaks. They just don't seem to like to hold air all that well, leaks all the way around randomly happen unless we seal it.
So I'm going to try the MPSS for the next set of tires.
The SC2's are for track only so those go on separate rims.
Reviews say they are the best not the PSS. I swapped mine to regular SS has less noise and better grip.
I've seen the exact same thing happen with my C5 and my Mercedes DD. Change brand/model of tires, but still the same size and see vast difference in driving(rain, dry, lateral grip, etc).
My experience is you MUST use weather mode. Makes a huge difference in controlling the power.
Other than that, drive conservatively and the MPSS is a great tire in the rain. I've had no issues with mine at all. Just remember, when it's wet, it's not a sports car anymore. It's a commuter with 650 hp.
2014C7 (01-21-2016)
If your still talking about the OEM goodyears (which I removed the first week on both my C6 Z06's 06 and 08) on a C6 Z06 your way way out of the loup! They were by far the worst OEM tire and nothing like the other tires out for last 7 years.
$Bill (01-31-2016)
