'16 Z06 M7 trans and skip shift eliminator
Can't seem to find an answer to my question using the "search" feature. Regarding a 2016 Z06 with the M7 transmission, does that transmission still have the 1-4 shift pattern (2 & 3 gear locked out) when rpm's are below a certain level? Based on the readily available "skip shift disabler", I'm guessing it does but then I noticed the suppliers of these gadgets only call out the standard StringRay model and not the Z06. I already ordered one for my new Z06 (won't arrive for 8 weeks...crap!), but I've owned three 6 speed cars in the last 20 years and all of them had this skip shift feature, which I can not tolerate! Please advise...thanks!!
Received 8,928 Likes
If a person talking to a passenger or using the mirror to pick their nose forgets and shifts into 2nd in the forbidden speed zone the system will push the shifter toward 4th and all the driver has to do is push the shifter into third, pull it back out and move it to second which can be done in a second or two. CAGS doesn't interfere when you are running the car hard.
Get a refund on the one you ordered and forget about it.
Bill
Bill, thanks for the information on the skip shift.... I did not realize it is now based on speed and some other throttle criteria. I had to smile on your comment...."Why spend $20 on something that isn't needed?" I ask my wife that same question multiple times a day (more often than that, it has some zeros added to that number, as well)!
I'm OK with the luxury of buying the skip shift eliminator, besides that I've had some Amazon credit for month and that more than covered it. That's a feature I have zero use for and want to be able to shift to where ever I want to, when I want to, without the car talking back to me! Interestingly enough, it sounds like most of the owners do what you do.....that's OK, I don't mind being the odd ball! Thanks!!
Just my opinion. I had a C6 and HATED the skip shift, seemed to get in the way more times than not just driving around town. With the Z06, I find that I very seldom have it kick in. Nothing to prove it, but seems they adjusted it to be less intrusive on this car.
The Consigliere
Received 5,444 Likes
It's pretty much a non issue on these. I had mine tuned out, but that is only because I was already changing the stock tune, so tossed that out along with it.
ODEN2 (01-30-2016)
True on the more fun shifting at 40-50 mph. However, I am glad I did mine when I am in super slow gridlock type traffic or behind a slow moving/accelerating vehicle at a traffic light.
Just learn to drive it!
I agree. It's not as intrusive as the C6, and the C6 isn't as intrusive as the C5. It has gotten better with each generation.
I agree that with the C7 I never seem to encounter the "block". The shift gate, on the other hand seems way too narrow with the extra row for seventh gear; it seems too easy to skip a gear unintentionally on the 2-3 and the 4-5 upshift.
charles
First thing I do on an manual (which probably voids my warranty) is to load the calibration into HPTuners, turn off CAGS (the correct name for it) and save it back.
I haven't had skipshift for more than a few hours on any car.
If you're using the little dongle/circuit thing, I can only assume they're identical between the Stingray and Z06. I cannot think of a reason it could/would be any different.
If you don't drive in heavy traffic there isn't a need for the CAGS Eliminator since it should never activate accelerating at even a moderate rate from a traffic light or stop sign. However, as I said in my earlier post a person who can train themselves can avoid it just as easily. I firmly believe anything done to the car no matter how minor is a complete waste of time and money. On a priority list it falls far below making sure the shoe laces on 10 year old shoes are washed.
Bill
Bill
Interestingly, after about 2100 miles, I haven't had it activate once. I've seen the note on the display, but it didn't actuate. I guess I'm just too hard on the throttle. It did seem to engage more in my old C6....
SoCal traffic deems it necessary for me. I do agree, the C7 is much less obtrusive than the C6 was, which was less obtrusive than my 4th gen Camaros.
-Ron
-Ron
Bill.....Thanks for your wonderful insight and equally splendid image I now have in my mind. Unfortunately for stupid ole' me, I am still going to have the skip shift eliminator installed just in case I am not quite as coordinated as yourself and I will undoubtedly be stuck in traffic from time to time on those days I have given the chauffeur off.
I have noticed that some suppliers have a different skip shift eliminator for the C7, and I am wondering if the difference is the connector, OR if the C7 actually requires a different resistor to simulate the solenoid.
Does anyone know?
I have measured the resistance on a couple of the eliminators and one was 12 ohm, the other was 24 ohm. One seller listed the resistor as 22K ohm!
The C7 eliminator says it will not fit the C6 or C5???
http://www.northamericantuning.com/s...tor-cags/4574/
Does anyone know?
I ALWAYS install one on my cars, they cost practically nothing. It depends on how you drive, for me personally the 1-4 activates often. There is no downside to putting one on.
The following 2 users liked this post by BERETTA:
DSOMonster (02-01-2016),
tzoid9 (01-31-2016)
Received 1,984 Likes
