Z06 four wheel alignment
Hey guys, can anyone confirm what is needed to properly align (4-wheel) my 2015 Z06. I replaced all 4 tires and lowered the car before putting it in storage last fall. My local dealer has an alignment rack but I was told that they needed a rear caster gauge adapter? Can anyone confirm. I want this done correctly so I don't chew through my new tires.
Thanks!
John
Thanks!
John
Turn 12!
Thanks!
John
Thanks!
John
Originally Posted by JackTripper
After I lowered my Z07, I had it laser aligned at a local speed shop. There are specs that are needed, but I cant seem to find them. Try searching under my user name.
Turn 12!
I would. Remember, the Corvette is an amazing car and its builtin its own factory, however, as far as service, Chevy techs are used to working on Volt's, Tahoe's and Malibu's. Bottom-line, its worth the drive.
Mad Dog 24 (03-03-2016)
Turn 12!
Received 8,928 Likes
Thanks!
John
Thanks!
John
As far as having a speed shop do the job there is no reason to think they are any better than somebody at the dealership. They all use the same machines and it doesn't take an ace to do an alignment. People can do an alignment in their garage quite easily with a few basic tools. The fancy machines just make it easier to do. The problem I have with the C7 is I can't set the rear caster since besides needing the bracket (I already have a digital angle gauge) I need a $12K alignment rack that lets me get under the car to see the gauge and to make adjustments while reading the gauge.
The alignment skill comes about when the driver comes in and says the car is doing thus and so in turns or when getting on or off throttle and the tech changes the alignment to fix that problem. Unless the speed shop is heavy into road racing the alignment guy will be just as much in the dark as the guy at the dealership.
Bill
JackTripper (03-03-2016)
Thanks guys. To be clear, I'm not looking for a "track" alignment. Just the alignment that it came from the factory. Want these new tires to last as long as possible.
The following 2 users liked this post by -HAIRBALL-:
JackTripper (03-10-2016),
PLRX (03-10-2016)
It may not take an ace to do an alignment but I have had enough wall jobs that I don't trust most dealers. They stick on gauges look and if it close they send you out never touching anything and your 2000 dollar tires are toast.
z51vett
Doug
z51vett
Doug
Supporting Vendor
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes
St. Jude Donor '08
You definitely want to find a shop/dealer that is familiar with them and has the digital angle gauge in their tool inventory. Any adjustments for camber or toe will likely effect the rear caster and it will need to be set back in spec.
Location: Syracuse-Central Square New York Winer of the all Corvette race WGI 8/23!
We bought the bracket to measure rear caster and a Long Acre digital angle gauge late last year. After getting it one could make there own its not rocket science! I think it was $100 for the bracket alone from the same co GM buys it from. The digital gauge GM recommends is was over priced go long acre or use an app on your smart phone.
I think the rear caster in our Z07 is not right a bit twitchy in the rear. We will find out find out when we do the track alignment soon for a Glen track day coming up. It doesn't say it in the recommendations above but you want the rear set at 0 caster.
Hint.. always ask for a before and after print out of your alignment. Post it here and you will get many many opinions, for sure.
I just had my car aligned by TPC (same folks making the DSC suspension bits). I had the dealer do a track alignment just before hand so the camber was pretty close but the front caster was at 6.8 and the LR was .5 degree leaned back when we started.
We corrected the caster and set the rear caster so that both of the rear shocks are leaned 1.0 degree back and the car has very different feel. Frankly I was surprised at how much different the car felt in street driving. The turn in is much quicker and the back end is much more controllable when you hang the rear out - even on cold MPSS tires.
I have a new appreciation for what a difference a quality alignment can make.
Painrace (03-28-2016)
Bill
He measured the toe curve with the shock neutral, forward a bit and backward and found the toe curve was best with a bit of a rearward cant - it wasn't what we expected. He also test drove his car in the various configurations and found the rearward cant works best.
Personally, I wasn't expecting to be able to tell much difference but it was very pronounced. I'll see how it feels on track next weekend.
I'm running the DSC shocks and controller. Mike is currently running the stock shocks and the DSC controller.
Ernie
Yes, the bottom of the shock is forward of the top of the shock . The angle is less than 1 degree.
