DeWitts Radiator & EOC install
#42
The new EOC will mount directly over the TOC (on A8) and uses the stock hardware. Same location for M7. The cooler is a dual pass, 38mm custom DeWitts heat exchanger and it mounts on the same angle as the radiator and SC exchanger. The connection are #10 AN male and the hoses are stainless steel braided lines to the oil adapter. It's all coming together nicely.
It will be nice when we see some before and after data log charts of the engine coolant and oil temps with this mod. Looks to me like the air entering the bumper inlet would just bypass the add-on cooler as it will take the path of least resistance, since this core has no shrouding, and the air will just go around the cooler.
#43
Former Vendor
Former Vendor
racerx8 (03-10-2016)
#47
St. Jude Donor '08
Tom,
I certainly hope that you get the level of orders on these products that you deserve for the amount of effort you have put into this project given the vocal but admittedly small market for these products. (Relative to the entire C7 market)
P.S. Had one of your radiators in my C6. Probably didn't need it, but it was a quality product.
#48
#49
Awesome!
The intercooler too:
https://www.corvetteforum.com/forums...tercooler.html
Yes sir, everything but the kitchen sink toward a difficult problem. Good Luck and that should work!
#50
What you are thinking is true. Most of the air does go around the EOC and that is by design. This is to insure the SC exchanger receives cool air and HP is not effected. The size, thickness, mounting angle, and face inlet pressure were all carefully selected by our team. We will report net results after a few hard races are completed.
Tom, Thats some nice looking aluminum from the welds to the machining!
So If i understand this, the EOC will not really be "stacked" horizontally over the TOC, it will be mounted above it on an angle to allow cool air to get to the radiator and the SC heat exchanger.
Looking forward to testing!!!
I doubt the market will be limited to the 'Vocal" Few because they are not that few. If that were the case, Bondurant, Spring Mountian and so many of the track day cars would NOT have the problem.
Best of luck on this!
#52
Former Vendor
As soon as we test the car. We should wrap up the install by Monday. Then we are going to release the car back to the owner to push it. I will have the the parts and pricing loaded on the website by 4-17. You will be able to place orders then.
The following 5 users liked this post by Tom@Dewitt:
fleming23 (03-10-2016),
foreverfuelie (03-10-2016),
Gomer (03-10-2016),
Jus Cruisin (03-12-2016),
Painrace (03-10-2016)
#53
I'm assuming that the OEM EOC 'brick' is replaced by an adapter with oil lines to your (far superior) EOC.
In the adapter is there a 'thermostat' that allows the oil to get to a set temperature before the oil is routed to your EOC, or is the oil path always open?
Bish
#54
Former Vendor
Tom quick ?:
Bish
Bish
The following 4 users liked this post by Tom@Dewitt:
#55
The C6Z06 really has a problem running too cool in the colder months due to this design. Even driving in 5th on the highway instead of 6th, the oil temps remained too low on my car.
#56
Received 3,805 Likes
"Ask Tadge" Producer
Define "too low" and how did it apply? Remember that one of Mobil-1's advantages is that it not only works well when it's very hot, but also when it's very cold. In fact that's how Mobil-1's advertising campaign started waaaaaaaay back in the day. So as long as you're using the right oil it probably isn't an issue.
#57
Will we know that it actually works on track to lower temps? The first radiator you guys put out did not seem to provide much cooling improvement, and then you went to version 2. So will you actually test this EOC and prove it works and provide data before releasing it?
#58
#59
That's exactly what one would hope for. It's easy to think that some brand new shiny aluminum parts are going to make a great improvement, but it's not the shine that counts. It's proven results. In my business, my small group of engineers and scientists test stuff constantly, and our success is measured by how well we actually perform, not by how well we claim to perform.
#60
From our experience above, I feel very confident that the DeWitt solution to the engine oil overheating in the C7 Z06 will work, and well. Why? Well because it takes one poorly engineered heatsink, the OEM water radiator, that is failing to cool both the water and engine oil on a road course in high ambient temps, and replaces it with two (excellent?) heat sinks, which are the Gen 2 water radiator and a dedicated EOC.
DeWitt is not HKS, and to expect them to take the same car with the same driver out on a road course before and after installation of their cooling solution in the same conditions is a bit far fetched. An excellent idea IF DeWitt's had the resources of HKS, but surely they don't.
I for one would be perfectly happy finding out how well their solution works later on this year, although I might do it in stages; i.e. Gen 2 radiator first, then the new EOC. My thoughts on their total solution will be guided by other accounts from Z06 owners using the DeWitt products, plus other cooling solutions like that from DBS if it's available when I'm ready to upgrade.
Wish
