C7 Z06 Main Cat Delete Kit
#521
well I got it done. my pipes did not line up as great as everyone on here stated. I bought the corsa x pipe as well and they did not mate up. was off by about an inch. my passenger side cat delete didn't have the nice bell flare like the drivers side, but its all on there. sounds good.
because its me, and my awesome luck. in removing the pass upstream o2 sensor, I guess either heat or something had basically welded this thing in. it came out, but not without pulling the threads from the stock downpipe with it. but not loosely. they are like cooked and welded into the threads on o2 sensor. so had to order a new sensor, which I will pickup today.
put the big daddy cel sims in the downstream sensors and all seems well. somehow didn't even throw an o2 code for the front sensor. and it drove fine, although I didn't get on it really just out of precaution.
#522
Former Vendor
Every single kit ive done to date has bolted up no problem. 1 inch off now im interested in. Please pm me pics if you have on install because this is first in over 400 sets ive heard of it being off 1 inch.
thanks
thanks
#523
Maybe he didn't loosen the x pipe and readjust. That happened to me when I had the long tubes installed on my Z51. It seemed off and hit the tunnel plate but when the installer loosened up the pipe completely and readjusted it, all was good.
OP, I'm really considering going with the delete pipes instead of long tubes to save me about $500. How do you like them so far, is it loud AF?
#524
Former Vendor
#525
#526
as mentioned below, in touring and eco its decently tame. but valves open is #racecarlife
#527
I plan to install without lifting the motor and am trying to figure out if I need new bolts or not.
#528
#529
#530
Yep, done it several time .......just watch for the manifold gasket which usually stays stuck to the manifold.
#531
Made 602/643 on stock tune and afr was tapering down entire pull eventually to 11.4:1 at redline. This is also using a sniffer out rear of exhaust so probably a few tenths of a point even richer. Made 2 pulls back to back no cool on and were within 3hp and tq of each other.
93+ 1/2 qt of of boostane
ice filled granatelli tank
then today i threw reduced power code. Stopped in at chevy and they flashed the new tune in no questions asked. Id be interested to see if any changes happened, may go back to dyno
#533
#536
Former Vendor
it does not run lean. Ive done numerous c7 base and gs and z06s. Deleting cats on either version of the c7s does not run lean. Yes the light comes on dash if you dont use 02 sims or tune it.
I would not sell this delete kit as no tune needed if a tune was needed.
#539
Should have bought your pipes in hind sight. I would not have rusty pipes now! Cheaper isn't always better.
https://www.corvetteforum.com/forums...ting-pics.html
#540
Former Vendor
Should have bought your pipes in hind sight. I would have rusty pipes now! Cheaper isn't always better.
im a dealer for afe. My pipes clear the lines/cooler better. The inlet is much more smooth on mine also.
Sorry to hear your issues
