WTF.... service brakes worn
#41
Location: Syracuse-Central Square New York Winer of the all Corvette race WGI 8/23!
Hey Bish, MartyBMW ^ got his replaced under warranty, cheap fix.... new pads. Worth the try and has me thinking as I have had the same issue at the track.
thebishman (05-08-2017)
#42
6th Gear
Brake Sensor
I had the same warning light on my '15 Z06. It first started at 7k miles. I took it to the dealer who said there was a service bulletin that addressed the problem. They ordered new sensors for both front brakes. Never had a problem since. That was 6 months ago. The tech that worked on it said it was the 3rd brake sensor replacement he'd done in the past 30 days. Must be a semi-common problem.
#45
#46
There is a GM part number, but you cannot buy the sensor alone. You have to buy pads to get the sensors. My GM parts guy said when you look up the part number on the sensors it is listed as not available.
#47
Perhaps his repair used a different part number. If the dealer can order it for a repair, its available. That is why I asked. Not the first time GM gave a dealer a part number that was not shown in the parts lookup. Happens all the time in service bulletins.
#48
hopefully he will reply with updated info.
#49
I stopped this message from coming up, as I posted earlier it is a continuous loop that goes out and goes through all 4 brake pad sensors and back. I had ohmed both the front and rear sensors and could not find an open, I even wiggled and tugged on them and they never opened. On a hunch I simply bypassed the front pad sensors. I disconnected the front sensors at the harness to get better access to them and simply jumped the 2 wires together just before where the sensors plugged into the harness to eliminate as much of the sensors wiring as possible, and then just plugged the sensors back into the factory harness connector. This does not effect the rest of the wiring harness on the car, only the pad sensors. No reason to buy a $700.00 set of pads just to stop the light unless of course you can get them warrantied. If you keep an eye on your brake pads (as you should) there is no need for the sensors. When it comes time for me to replace the front pads they will come with new sensors anyway. I have driven the car several times after this and no more annoying light!
#50
Former Vendor
All covered under the factory.
#51
From my understanding, there is bulletin on this issue. I took mine in with the service brakes message at 7,000 miles. Dealer installed new set of pads under warranty. It is definitely a faulty sensor problem.
#52
My car is modified and not sure if they would warranty it for me. I am just offering an alternative to getting rid of the light.
#53
Leeds.io
St. Jude Donor '14-'15-'16
FWIW I took the car to the dealer for this issue. My car is a Z07 with 41k miles.
They replaced the Electronic Brake Control Module saying it had an internal short. They did it under warranty too. Part # 22782245
Best,
Gene
Best,
Gene
mjdart (08-24-2018)
