GSpeed C7 Z06 Cooling Development
#161
Supporting Vendor
For our third session of the day, we added the auxiliary radiator back in the car, plumbed just as it had been previously. Engine -> Primary Rad -> Aux Rad -> Engine.
In short, it worked awesome. Water temps stabilized under 220°, with 95° incoming air. Oil temps were a little over 280°, and transmission temps stayed below 250°.
For our last test of the day, we planned to re-install the OEM oil cooler and see how well it would work with the super beefy water cooling system. We'll have results of that test up in our next post.
#163
I really appreciate all the thorough research you guys are doing. I'm also someone who hasn't overheated the car to failure with the stock cooling. Since adding the secondary radiator all the temps have been fine except the trans temp getting a little higher than I like.
All that said, I've definitely noticed that the car makes less power when it's hot out and the lap times show it. I don't know that I'm experiencing heat soak per se as it seems to be relatively consistent through the session (most times) but it definitely is slower in the afternoon sessions than the morning sessions. If Aim can start logging IAT2 I'll start tracking that to see.
Given your latest post, what I'm wondering is whether simply replacing the GM secondary radiator with an equivalent sized intercooler laid flat would be a better solution that doesn't require cutting up the bumper. That would include removing the current intercooler from in front of the main radiator thereby making it more effective as well.
Do you have any thoughts on this? I realize that level I'm stressing the system is far less than you but for guys like me that might be a better compromise.
#164
Supporting Vendor
Our fourth and final test for the day involved a DeWitt 70mm prototype radiator, a GSpeed auxiliary radiator, and an OEM oil cooler (with no other changes to the supercharger intercooler system).
The intention was to find out whether or not we could get away with an unmodified oil system. The implications are two-fold. From a technical perspective, we can utilize more airflow on the other three heated fluids. From an ownership perspective, an unmodified oil system has less warranty implications.
We ran a total of 18 laps over 30 minutes, and did not de-rate once. Max speed at the end of the session matched the beginning.
However.
Fluid temps were through the roof. The OEM oil temperature sensor, as read by the ECU, will not read more than 302°F, or 150°C. You can see in the graphs below, the oil temps "plateaued" when temps reached 302°F. In all likelihood, they kept climbing a few degrees above that.
You can see in this IR picture the temperatures of the intercooler radiators match pretty closely, which is good. They're sharing the load well. It's also clear that the hood vent is far from cosmetic, and is radiating quite a bit of heat.
What does this mean for the average buyer?
In 96° weather, the car did not go into limp mode, or even de-rate significantly, with our intercooler and engine coolant package. Oil temps were NOT what we would consider acceptable for a dedicated track car, but for the average buyer, this may be a potential Stage 2 solution to accompany the supercharger intercooler system.
From here, we will address the engine oil cooler system and find a more production-friendly location.
Jake
However.
Jake
#165
Supporting Vendor
Trust me, we REALLY don't want to run the "cheek" intercoolers, but keeping the car cool & safe is a higher priority.
Jake
The following 2 users liked this post by GSpeed:
jbsblownc5 (07-16-2016),
Poor-sha (07-15-2016)
#166
Supporting Vendor
Fun fact- since June 30th, we've gathered 181 laps of data. Almost 310 miles of track time.
racerx8 (07-15-2016)
#167
Would the pump cavitation fix be part of your stage 1, intercooler only fix?
Stage two adds an aux radiator and upgrades the main radiator?
Stage 3 would be the addition of a plumbed air-oil radiator?
#168
Supporting Vendor
Theoretically, yes. Stage 1 would revamp the intercooler system entirely.
#171
Supporting Vendor
It's still single pass, but much thicker. Requires fan modification, and hood duct modification.
__________________
"Keeping You on Track!"
http://www.gspeed.com
877-512-5180
Instagram_Facebook_YouTube
GSpeed C7Z Cooling Development
2014 NASA Texas TT1 Champion
2015 NASA Texas ST1 Champion
2018 NASA TTU & TT3 National Champions
2019 NASA ST2 National Champion
2019 NASA Texas TT2 Champion
2020 SCCA Majors COTA GT2 pole sitter
2020 SCCA Trans Am Road Atlanta SGT Winner
2022 NASA National Champion ST2
2023 NASA National Champion ST2
2023 NASA National Champion TT2
877-512-5180
#172
2017 C5 of the Year Finalist
St. Jude Donor '08
Isn't this the same car and driver that has video posted on YT, doing super fast WSIR laps @ 1:30?
Been looking around for your car @ various local tracks when I run.....have some questions....
I'm thinking I can learn some things from running/following your lines......when is your next track day in that C5 beast?
Thanks.
Thanks.
I'm not a SCCA racer or anything, just club running, I've gone low1:32s...Not sure when I get out again, pretty soon though.
Here's a video from a little while back where I integrated the video from the Z06 that was following me, along with 2 views from my cameras.
Wally Z06 (07-16-2016)
#174
However.
Jake[/QUOTE]
If I understand this correctly, you have the intercooler temps under control, ECT temps are great, and consistent timing, but the oil temps are in the 300 degree range with the stock EOC. I gotta ask, and I understand you have some serious engineers on this, but would the cat wraps and oil line wraps help any? Its been discussed and many have dismissed it. I am just curious and it would not take much to test this mod. the warranty implications for the oil cooling mod I think are significant. Great work!!!
Jake[/QUOTE]
#175
I'd love to see a test done with the stock EOC and it's own dedicated cooling circuit. Separate pump and water to air heat exchanger. Pump controlled by oil temp (turns on at 180ish).
When driven hard, the stock EOC may not have the surface area required to show any gains in this configuration, even if it was supplied with coolant close to ambient temps. Be nice to find out though.
#176
#177
What I was trying to describe was a completely separate coolant circuit for the stock EOC. Stock EOC with a separate electric pump, coolant lines and air/coolant radiator.
Or, add another radiator to further cool the coolant after it leaves the block so that the coolant the stock EOC is supplied is at a lower temp.
Just curious to see if the stock EOC could keep the oil temps in check if it were supplied with lower temp coolant.
#178
Supporting Vendor
I could be wrong, that's why we test. Maybe we'll try that out.
Jake
rsilver (07-16-2016)
#179
The stock setup supplies the EOC with coolant from the left side of engine block (hot). I've wondered what would happen if the coolant supplied to the stock EOC was supplied with colder coolant. Is there a way to tap into the water pump to get coolant from the return side of radiator? Possibly the HVAC heater line? I don't know what the HVAC heater coolant flow is.
#180
Supporting Vendor
Your proposal would require a third coolant system. Engine. Supercharger. Oil cooler.
It's a good idea, ford employs a similar methodology on some of their trucks.
